St215 motor + st205 gearbox into St165 JDM build
Re: St215 motor + st205 gearbox into St165 JDM build
Postby GT4times2 » Tue May 01, 2012 7:56 pm
I'm loving the work. Glad to see an ST165 getting some attention. Why don't you post this build in the "Projects" section instead? More views on that end. Really nice project you have going there. I love ST165s, ST205 and ST185 (in that particular order).
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby bmt » Wed May 02, 2012 6:08 am
Good idea. How do you move the entire thread to a different forum? Is it something only a moderator can do? Help?
bmt
Postby GT4times2 » Wed May 02, 2012 2:17 pm
I took care of it. I moved it to the "My Project" section.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
Postby bmt » Thu May 03, 2012 5:21 am
Awesome thanks!!
bmt
Postby bmt » Sun May 06, 2012 7:54 am
So on with the plan. I have been working on my cooler ducting.
These are the pieces that I made to duct the air from the bumper to the air box and the transmission cooler.
This is them in place. Except the base piece for clarity shown from underneath. You can see my trans cooler mounted in front of the wheel.
With base piece fitted.
bmt
Postby bmt » Sun May 06, 2012 8:12 am
Continuing
Front view of bumper ducting. The idea is that the large hole will take air straight to my airbox. The smaller hole will take air to flow over the trans cooler but what doesnt go through the cooler will be available to the airbox.
See that triangular hole next to the cooler? It goes into the airbox. With the inner guard in place the air will have access to the airbox.
Looking into the airbox from above. At the bottom of the picture you can see the triangular hole and to the left is a larger hole that I cut into the inner guard to allow more access for the spilled air. Oh and where does the air that has gone through the cooler go?
bmt
Postby bmt » Sun May 06, 2012 8:39 am
Glad you asked!
Out through here. The sharper eyed of you will recognize that louvre as a St185 bonnet louvre. I had bought them earlier for my bonnet but decided against using them but they were perfect for this job. The air should have a path out through here and the spinning wheel should help generate a venturi affect to help pull it through as well.
On the other side I have ducting for the oil cooler.
I dont have the flex yet so its not in place and I haven't plumbed the lines yet but you get the idea. I hope!
Same deal as the other side. It also has a louvre on the inner guard. See next post.
bmt
Postby bmt » Sun May 06, 2012 8:49 am
You can see the cooler through the louvres.
What the front looks like now.
On the ground.
bmt
Postby GMan » Sun May 06, 2012 1:34 pm
bmt wrote:
Anyone know what this is/does? It was bolted to the bonnet catch stay.
I was going to Guess a temp sensor for the automatic AC.
(At least look like it, not sure if it was only a US market part ?) :-)
Aftermarket alarm mercury switch ???
Awsome Build ! :notworthy:
Where are you ? Helps to put at Least a country (w State or town? ) in your sig. :shrug:
It IS a World W I D E forum after all...
(http://www.importperformanceparts.net/)
Flatlander Racing
24 Elm Street
Plaistow, NH
03865
You live around NH ? Hope to see the project sometime.
Rare to see Any 4th gen Celicas getting any love. 8)
Regards;
Boston, MA USA
6gc & ST185 owner...
GMan
Postby bmt » Mon May 07, 2012 5:07 am
Cheers for that. Sorry I live in New Zealand, but you are still welcome to come and have a look! :wink:
bmt
Postby 801Alltrac » Mon Aug 06, 2012 3:14 am
I'm in love all the metal and duct work that is awesome
What's your hp goal
801Alltrac
Images: 13
Postby bmt » Mon Aug 06, 2012 7:27 am
Could you see the pictures ok? Nobody else could :shrug:
I am aiming for 300 plus at this stage. I would like to go above 350 but wont know until I finally get it going! I will try and get some more photos up soon. Just doing my exhaust at the moment, 3" stainless up to the down pipe, then a ceramic coated steel down pipe up to the turbo.
Thanks for your interest!
bmt
Postby UtahSleeper » Mon Aug 06, 2012 4:40 pm
Damn!! The air box and catch gan look great!!! And I may have to look into the radiator option since I would like more room between the trub and radiator. Great job.
UtahSleeper
Postby celigts » Wed Aug 08, 2012 1:42 pm
Man that intake box is magnificent!! I too was thinking of making all the stuff your done for my build. Started mine mainly cuz I got it free from an old job.
Amazing motor rebuild and project in general! Kudos
3SGTE project motor very slow
celigts
Postby ZeroDrift » Wed Aug 08, 2012 2:51 pm
Progress is looking great! Nice idea with the oil cooler and ducting!
Users browsing this forum: No registered users and 7 guests
