St215 motor + st205 gearbox into St165 JDM build
Re: St215 motor + st205 gearbox into St165 JDM build
Postby bmt » Thu Aug 09, 2012 8:09 am
Thanks for the comments guys :D Appreciate it. You've inspired me to get my ass into gear and get some more photos up! Check back soon!
Cheers
bmt
Postby ZeroDrift » Fri Aug 10, 2012 4:57 pm
bmt wrote:Thanks for the comments guys :D Appreciate it. You've inspired me to get my ass into gear and get some more photos up! Check back soon!
Cheers
Looking forward to see more pictures!
Postby bmt » Sat Aug 11, 2012 8:33 am
Took some pics today
My bumper with mesh in the holes.
Unfortunately it seems like the hot glue is not doing the job :doh: so I will have to readdress that problem!
This is my inlet side
Same thing looking down from above
The blowoff valve is adjustable from full recirculating to full atmosphere. I directed the recirculate back towards the turbo as a kind of cheap anti lag! I hope anyway. :twisted: The little container next to the Radiator cap is my custom overflow bottle.
bmt
Postby bmt » Sat Aug 11, 2012 8:47 am
Onwards,
This is my down pipe looking from above
Looking from the side
Looking from underneath
So it's a 3" downpipe with a separated waste gate pipe that is 41mm, (1 5/8"). There is a divider in side so the exhaust is totally sealed from the waste gate side. I will probably send it out this week to get it ceramic coated.
More soon!
bmt
Postby bmt » Sun Aug 12, 2012 2:43 am
More,
Down pipe out of the car
Downpipe showing divider
The divider pokes into the exhaust side of the turbo to separate the exhaust gases from the waste gate gases.
The "Mid" pipe
3" stainless all the way including the flex.
bmt
Postby bmt » Sun Aug 12, 2012 2:56 am
Showing the mid pipe in the car
Looking up from underneath
I welded a little skid plate on to the cross member to protect my flex from scrape damage. They're
expensive!!
Fraser
This is what I build for a living. They are called a Fraser. They are a series 3 Lotus 7 replica. We build everything inhouse. It is my job to skin the cars in alloy.
bmt
Postby bmt » Sun Aug 12, 2012 3:06 am
Bit more on my part on the Frasers. I know off topic but I thought you guys might be interested and yes we do export!!
Freshly skinned car
Everything is done by hand.
Rear of the car
This is the most labour intensive part of the car as all the curved parts have the alloy wrapped over the chassis tubes. LOTS of shrinking by hand with a hammer. My workmates hate me when it comes to this part of the skinning, bang bang bang for most of a day!
bmt
Postby ZeroDrift » Mon Aug 13, 2012 2:52 pm
Exhaust and downpipe look great! Also great work on the Lotus Rep. I've had a ride in a Super 7 with a rotary engine in there and it was a fun little car.
Image The Miata was the Mrs' old car and we were out auto crossing.
Honestly I'd be interested in getting a downpipe and mid pipe from you if you ever decide to make a spare setup! Assuming it'd fit the stock turbo...
Postby GT4times2 » Mon Aug 13, 2012 9:09 pm
It's coming along quite nicely! Loving the work on the car. Glad to see ST165s under the knife.
ZeroDrift wrote:Honestly I'd be interested in getting a downpipe and mid pipe from you if you ever decide to make a spare setup! Assuming it'd fit the stock turbo...[/b]
Get it done locally. It's cheaper than having pipes shipped from NZ. Just saying... :|
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby bmt » Tue Aug 14, 2012 6:45 am
GT4times2 wrote:It's coming along quite nicely! Loving the work on the car. Glad to see ST165s under the knife.
Thanks guys. ^^^^Totally agree!! Support your local industry! Otherwise when you want it, it wont be there and wherever you have been going
can hold you to ransom.
Fitted a Whiteline sway bar tonight. Part number BTR29Z. Rear sway bar for a St185/St205, fits perfect if your St165 doesn't have the ABS bulge.
bmt
Postby bmt » Sun Sep 23, 2012 9:28 am
Update! Surge tank
The other alloy plate is to cover the bigger hole that I cut out above the fuel tank. I can pull everything out of the tank without dropping the tank. I just thought it would be easier!
The High pressure pump
You can just see it poking out from behind the surge tank. So behind the surge tank and in the cavity above the wheel well is a prefilter from the surge tank into the high pressure pump then through a post filter and onto the motor.
bmt
Postby bmt » Sun Sep 23, 2012 9:37 am
My down pipe came back from the coaters and it's on. Yay!
From underneath
From the side and underneath
Man these engine bays get full!!
bmt
Postby bmt » Sun Sep 23, 2012 10:03 am
Oh I changed something.....
Before,
After,
Another view,
I just wanted something different. It came up on our version of ebay . If you dont know it's from a St162 Corona. I had the grille dechromed and painted it black as were the indicator lense surrounds. I saved a bunch of weight by getting rid of the pop up lights as a bonus.
I have plans for the bonnet including a colour change!!
bmt
Postby Rick89GTS » Sun Sep 23, 2012 2:06 pm
Great build. And I thought my stock 165 engine bay was tight! Nice headlight conversion. We don't get the ST162 Corona in North America, so it's not an option for us.
Rick89GTS
Postby GT4times2 » Sun Sep 23, 2012 5:05 pm
bmt wrote:Oh I changed something.....
Before,
After,
Another view,
Looks cool, although I prefer the pop up lights on the ST165. I always said, if I got a (88-89) Celica GTS coupe, I'd look for that front end conversion. Always keep the original in case you want to change. Keep up the good work.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
