1988 Alltrac - Fiona - Running and doing just fine
Re: 1988 Alltrac - Fiona v2
Postby UtahSleeper » Thu Aug 23, 2012 3:54 pm
Also, I am considering getting a known good, used engine from someone locally and just replacing gaskets and such on it and replace the motor. That way I can keep the trac moveable while freshening a motor.
Honestly, I have no real clue what I am going to do yet lol. This is all new to me. I have done basic backyard mechanic stuff, never a motor and that honestly scares me. Have to get big boy tools to even consider this whole thing.
On the oil pressure concerns, is there anything you would suggest to bring the pressure up to see if the loudness on start goes away?
UtahSleeper
Postby ZeroDrift » Thu Aug 23, 2012 5:34 pm
I have some experience with what you describe. Done years ago u was helping my younger brother swap a turbo on his ST185 and it sat for a week. Upon startup it had rod knock for the first few seconds until oil pressure stabilized and reached the bearings. The engine was fine and never have us any trouble from then on.
If you have only started it for a few second, the oil system had not yet had a chance to fully circulate.
Hope that helps!
Postby UtahSleeper » Thu Aug 23, 2012 5:38 pm
I will check it again when I get home. Yesterday I started it a couple times with it doing the same noise. Each time it was left running for a couple minutes and one time I drive it in my driveway to manuever it so I could back into the garage. Guess I will see in a few hours lol.
UtahSleeper
Postby UtahSleeper » Sat Aug 25, 2012 3:30 am
And more bad news for this engine. It now has 3 oil leaks and I tried to drive it with horrible results. No power and alot of stuttering. May try my other ecu, but since the CEL comes on, I think this ECU is fine. This motor may just be at the point of no return with the oil issues and previous rebuild issue.
UtahSleeper
Postby 801Alltrac » Sat Aug 25, 2012 4:28 pm
:x no fun :cry:
801Alltrac
Images: 13
Postby Redrkt01 » Sat Aug 25, 2012 8:23 pm
Yeah, I think you're looking at a tear down and rebuild. These days I'm at the point that if I pick up an engine or a car from someone the motor will automatically be given new gaskets and seals. Otherwise I get caught up in the kinds of problems you're dealing with.
Word to the wise: don't try to convince your self that there's and easier/cheaper option. I know you want the car running and I know you want it done without a lot of money sunk into it. But you're past that now. Supposing it passes a compression/leakdown test you should go ahead and order the Toyota gasket kit. IIRC it's about $150.
Pull the engine and change all the gaskets. While it is out you should check all the vacuum lines and replace as necessary. You can also check the harness (although I'm thinking you bought a replacement). Replace the injector insulators and o-rings. Replace the fuel filter for good measure.
If you do that then you shouldn't leak air or oil and should have sufficient fuel supply to the engine. Right now you're looking at either investing time or money into the car to make it run. If you don't have money (or don't want to spend it) then I think this is your best option. We already know its leaking oil out the ass.....so just get it over with already and pull it ;)
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
Postby UtahSleeper » Sun Aug 26, 2012 2:05 am
Yea. I am prepared to pull the motor soon-ish. My current plan will be to buy Rob/Luni's mr2 motor off him when he pulls it, freshen it with new HG and seals and run that for awhile while I slow build the spare second gen motor I have.
This is all hypothetical at the moment.
UtahSleeper
Postby Rick89GTS » Sun Aug 26, 2012 3:31 pm
Dracov wrote:.....Oh and I've had the engine just sitting on the east/west mounts before. It's fine, doesn't hurt anything and lets you tilt the engine back and forth if needed
Good info to know for future use. Thanks :D
Rick89GTS
Postby Redrkt01 » Sun Aug 26, 2012 11:36 pm
Rick, you don't want to do this for any length of time. I let mine sit of the E/W mounts for too long and they failed. I can take pics if you like....
1989 ST162
1988 ST165 Black
Redrkt01
Postby UtahSleeper » Thu Oct 18, 2012 3:35 pm
Well, small update.
Over the last month or so I have done the following:
Removed the sunroof and sanded off all the rust spots. All rust was surface, so I sprayed converter after grinding off, primed and painted black. Just rattle can as the car will get a full repaint after Milla(Corolla) has her paint done.
Replaced the fuel filter and tried to investigate what appears to be a heavy PS leak. Believe its my PS pump, but could be rack too. I will investigate it next year as the car is about to get put back together and parked outside under a car cover for the winter. Again, Milla gets the best treatment, so she gets the garage so I can finish installing some bushings, cut springs and maybe install the ebay turbo I have, as well as other little tasks. Trying to milk the last bit of life from her motor before rebuild.
Also, after some reading, I think my wastegate gets stuck open after hitting boost. The few times I have been able to hit boost has been good, but right after there is no boost till after she sits for awhile.
On thge agenda if winter isnt too bad:
Replace the coolant temp sensor.
If driving issues continue, check the AMF/MAF and TPS.
Get some 6th gen celi wheels.
Hopefully next year put together a more trust worthy motor.
Pics of current status to come later, not like much has changed lol.
UtahSleeper
Postby JohnNK » Thu Oct 18, 2012 3:45 pm
Please let me know if you happen upon a local motor and you don't plan to buy. I am always looking for a spare on which to work. My ST165 is doing fine as a daily driver but it would be nice to have a backup. Thanks.
JohnNK
Postby UtahSleeper » Thu Oct 18, 2012 4:02 pm
I will do that. When I get a spare motor I will be trying to sell the one in the car. Still runs, but I think it needs some work since it doesnt have the right oil pressure and it seems like its always starting with no oil for the first couple seconds. So, when the time comes, if interested, I would sell you mine. Thats if you want something to rebuild.
I willl be moving to a second gen motor as the one I might get is a second gen 3s motor, and I have a spare head and block for a second gen I plan to rebuild fully.
UtahSleeper
Postby UtahSleeper » Sat Oct 27, 2012 1:01 am
So, I have a winter project for my trac. I am going to make a fiberglass hood vent over the turbo. The plan will be to make it a bolt on until I get the ambition to try and make a fiberglass hood.
Here is the practice canvas:
The stuff to build/play with:
Ideas. Remember, these pieces will be triangles and connected lol. Just trying to figure out the path I want to take with looks.
Option 1:
Option 2:
Option 3:
Option 4:
Option 5:
Option 6:
UtahSleeper
Postby UtahSleeper » Wed Jan 09, 2013 5:28 am
Well, small update.
-I have made to skeletons for a vent and screwed both up lol. Need to find a better way to make the base.
-She developed a rod or something knock when I was trying to troubleshoot her rev issue. She is officially parked till I get a different motor to put in her.
-For xmas I got an engine stand and hoist. That will help with the above.
-Also got some 15" steelies off a camry, so just need to find some cheap tires to throw on her for now, then I can sell the bling rims.
I hope to be able to bring her back into the garage in March/April. I am hoping that is when the snow will go away and I will be willing to park the Corolla outside.
UtahSleeper
Postby toayoztan » Wed Jan 09, 2013 6:12 am
Which design did you end up going with, or tried making a skeleton for anyway?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
