1988 Alltrac - Fiona - Running and doing just fine
Re: 1988 Alltrac - Fiona - Engine dismantle
Postby UtahSleeper » Tue Feb 04, 2014 3:45 am
Here are some random pics to show that I have accomplished a little bit since the last update.
The empty engine bay.
General pic of her current progress.
The engine before any real dismantling happened.
Inside the exhaust port.
Goodies for future use. I need to learn to weld cause my Alltrac(Fiona) and Corolla(Milla) need some exhaust work.
Dismantling in progress.
A bunch of the parts.
More dismantling.
And the trans, all by its self.
My next plan is to remove the clutch and flywheel, check their condition, and then get the engine on the stand for the full tear down to see where the knock started.
Hoping I have time this week or weekend to do that.
UtahSleeper
Postby 88gt4DE » Wed Feb 05, 2014 3:23 am
Ahhh I see its yer turn .... :doh:
Postby UtahSleeper » Wed Feb 05, 2014 6:07 am
Unfortunately, yea lol. One of the PO's did a poor rebuild and I am out to do it right. This car needs to see consistent drive time. From what I know if it's history, it has seen maybe a 100 miles in the last 4 to 5 years.
UtahSleeper
Postby 88gt4DE » Wed Feb 05, 2014 12:22 pm
UtahSleeper wrote:Unfortunately, yea lol. One of the PO's did a poor rebuild and I am out to do it right. This car needs to see consistent drive time. From what I know if it's history, it has seen maybe a 100 miles in the last 4 to 5 years.
Sounds familiar ... just a thought but consider upgrading yer turbo feed and return while yer out. Those flex feeds are prone to leak but you prol know that already.
Postby UtahSleeper » Wed Feb 05, 2014 2:30 pm
Sounds familiar ... just a thought but consider upgrading yer turbo feed and return while yer out. Those flew feeds are prone to leak but you prol know that already.
Yea, I was planning on replacing it. After I dismantle and see what the rods/pistons and block condition is I am going to make a list of items to buy and then probably ask others for what else I should do.
UtahSleeper
Postby 88gt4DE » Thu Feb 06, 2014 1:37 am
Dump the butterfly screws and flaps on the TVIS ... those suckers killed me on my nice fresh 6,000 rebuild
Postby UtahSleeper » Thu Feb 06, 2014 1:44 am
88gt4DE wrote:Dump the butterfly screws and flaps on the TVIS ... those suckers killed me on my nice fresh 6,000 rebuild
Yea, I read that. They will be gone. I have a couple of the plates holding the valves that I am going to try and use to remove the valves and rod going through it.
UtahSleeper
Postby 88gt4DE » Sat Feb 08, 2014 9:59 pm
I left the rod. It aint hurting anything ....
Postby UtahSleeper » Tue Feb 18, 2014 6:06 am
Well, I dismantled more and here is what I saw.
The flywheel in all its glory lol. Still see the resurfacing marks.
The clutch. One of the PO's told me it had some performance clutch in it. Not really sure how to tell. Also, does this appear to still have enough meat to even consider reusing?
The motor on the stand.........SO EXCITING!!!
Chunks in the oil screen. Always a sign of a motor in top shape :)
Here is the overall motor. I tried to move all 4 connecting rods at the crank and all 4 move slightly. I thought normally when you have a rod issue(rod knock), it's 1 rod... Assuming that the belief that the rods should have no play at the crank.
Lots of sludge and debris in the oil pan.
The head, which looks to be in great shape.
I assume this is a cam part number(88360).
And a question. I have a head from a spare motor and the head that came off my alltrac. The cams have one difference on the surface. The alltrac head has protruded metal around the cam at the back of both cams. The other head has a a metal notch protruded in the same area. Are they the same cams or are they something else?
Alltrac head:
Spare head:
UtahSleeper
Postby MWP » Tue Feb 18, 2014 4:07 pm
UtahSleeper wrote:And a question. I have a head from a spare motor and the head that came off my alltrac. The cams have one difference on the surface. The alltrac head has protruded metal around the cam at the back of both cams. The other head has a a metal notch protruded in the same area. Are they the same cams or are they something else?
Take a photo. Its hard to work out what you are describing.
... it almost sounds like you are describing the gen4 cams though.
Postby UtahSleeper » Tue Feb 18, 2014 7:31 pm
What came off my motor. Circled in red on both pics.
The spare head I have.
UtahSleeper
Postby 88gt4DE » Sun Feb 23, 2014 4:03 pm
Any numbers on the cams with the protruding parts ?
Postby UtahSleeper » Thu Feb 27, 2014 1:02 am
88gt4DE wrote:Any numbers on the cams with the protruding parts ?
Not that I have found with some quick looking. I will try and search a little harder, but there is no number as obvious as what is on the original head.
So, took the pistons out. Piston 4 has markings on the top from metal making it there it seems. Plus it seems like one of the PO's marked the pistons with scrapping. Figure I need new pistons or use the pistons from the 3sge that I dismantled. Here is the shape of the pistons and crank. All 4 pistons had movement at the crank, so it was pretty mangled.
In order of front to back.
Piston 1:
Piston 2:
Piston 3:
Piston 4:
So, judging by the crank, would you say this should probably be reuseable after a machine shop visit?
I was honestly surprised not to see more carnage with all the crap in the oil pickup and pan.
So, now I need to start contacting machine shops and get quotes. My plan, theoretically, get a full rebuild kit, reuse the 3sge piston, 5s oil pump(anything needed to make it work) and look into cleaning up one of the heads. My goal is to try and do everything right, but obviously want to save on costs.
The goal is for a stock rebuild. The only performance stuff I plan for later is bolt on(exhaust, front mount, etc).
UtahSleeper
Postby 88gt4DE » Thu Feb 27, 2014 1:57 am
I would think the crank could be re-used. Machine shop can tell ya for sure though. May want to re-think the oil pump reusing ... hell that could be why the bearings look the way the did. that and the sludge in the pick up and pan ...
Postby UtahSleeper » Thu Feb 27, 2014 2:05 am
88gt4DE wrote:I would think the crank could be re-used. Machine shop can tell ya for sure though. May want to re-think the oil pump reusing ... hell that could be why the bearings look the way the did. that and the sludge in the pick up and pan ...
I actually planning on going 5s pump since I hear they have higher pressure. My first alltrac was always low on pressure and that concerned me.
UtahSleeper
