1991 RC recovery mission - "Rebel Scum"
Postby underscore » Wed Apr 25, 2012 4:27 am
I picked this up off here about a year ago, from a member down in Van. It was in rough shape, but I was determined to save it from the scrapper. Long story short it now runs fairly well after a few fixes to get it running and a lot of fixes to clean it up. Now it's getting close to where I will consider it stable enough to run in some King of the Hill, AutoX, TSD, 1/4 mile, 1/8 mile and any other racing that will happen in my corner of the world, along with cruises and meets.
The goal: To build an RC that keeps all the RC-specific parts intact (turbo, AFM, ECU, transmission, rear diff, etc) while upgrading as much of the rest as possible, to make the RC the most it can possibly be.
The goods:
Engine & Performance
- Mahle pistons
- Brian Crower valves/springs/guides/keepers
- King bearings
- ARP head studs
- 3rd gen headgasket
- 98+ 5SFE oil pump
- ACPT carbon driveshaft
- ASI 56mm radiator
- Mishimoto radiator fan
- Mishimoto radiator cap
- Mishimoto cap on water-to-air intercooler
- AEM 3" air filter
- AC delete
- Civic battery
- BWR battery tiedown
- rewired OEM intercooler sprayer
- Samco T-coupler
- HKS SSQV
- Vibrant MAF adapter
- Speed Source poly motor mounts
- xiiimotorsports aluminum north-south crossmember bushings
- xiiimotorsports solid shifter bushings
- DIY catch can
- ATS 3" coated downpipe
- Blitz NUR Spec midpipe and axleback
- Deutschwerks 320 fuel pump
Handling & Braking
- ACE Engineering front chassis brace
- TechnaFit SS brake lines
- Porsche/Brembo 4 pot front calipers
- PowerSlot STi front rotors
- gtfourtc's Porsche caliper adapters
- Enkei RPF1's (17x8 et45)
- Kuhmo SPT's (245/40R17)
- GT4 Racing suspension front & rear poly bushings
- GT4 Racing swaybar bushings
- GT4 Racing swaybar endlinks
- BC Racing RAM Type coilovers (10k/8k springs)
- Ford Probe/Mazda MX6 rear strut tower bar
- Whiteline-style front strut tower bar
- xiiimotorsports aluminum rear diff mount
- xiiimotorsports delrin rear subframe bushings
- 8mm front wheel spacers
- 25mm rear wheel spacers
- SP Performance slotted and diamond dimpled rear rotors
- Hawk HPS rear pads
- ARP extended front wheel studs
- Whiteline rear sway bar
Interior & Electrical
- Autometer 30 PSI boost Gauge
- Varns Electric Division SLC-302 top speed de-limiter
- RAZO RE30 Turbo/lap timer
- TRD shift knob
- TRD seatbelt pads
- Innovate LC-1 wideband
- aftermarket horns
- Clarion MAX385VD head unit
- stock System 10 amp and speakers
- NRG Gen 2.5 quick release
Exterior
- FET driving & fog lights
- JDM front marker replacement
- JDM taillight vent replacement
- BWR lug nuts
- RallyArmor UR mudflaps
On order/not yet installed
- ORC 409 Super Silent clutch
- AEM water/methanol injection
- TechnaFit SS clutch line
- brushed aluminum gauge surround
- new-to-me cup holder
- Alpine subwoofer amp
- Clarion 10" sub
- Bassworx ported box
- Oil filter relocation
- Turbo oil supply/drain braided line kit
- 3rd gen cams
- Mario's upgraded viscous coupler
- STRI boost gauge
- Hella SuperTone horns
- HDi electronic boost controller
Future
- AE92 Corolla steering rack
- 6th gen GTFour big brake kit (rear)
- GTFour RC decal replacement
- misc. bits powdercoated gloss black/red and satin red
- custom 2-step launch controller
- Ultra Racing rear floor brace
- Ultra Racing lower side braces
- Ultra Racing fender braces
- replace lower front grille mesh
- relocate fog lights behind mesh.
- replace all 10 speakers
- GT4 Racing fiberglass RC hood
- GT4 Racing fiberglass front fenders
- semi-racing seats
- Corbeau seat rails
- different steering wheel
- larger water-to-air intercooler core (6th gen GTFour?)
- Custom front/rear skidplates
- Custom rear diffuser?
- 4th gen GT digital or AP1 S2000 cluster conversion
Shitty cell phone pics:
Re: 1991 RC recovery mission - "Darlinda the Tie Fighter"
Postby underscore » Tue May 01, 2012 4:43 pm
Just picked up some 17x8 Enkei RPF1's in gold off a friend of mine, real pics to come but they look loike this:
Postby underscore » Wed May 02, 2012 3:36 am
To play it safe I test fit the rims to be sure they clear the calipers, they came off a WRX with an STi brake conversion but you never know.
old caliper & bracket vs new
old rotor, new blue brake fluid & RallyArmor mudflaps
new SS brake lines
fitment sans rotor, should sit about flush with the rotor on
money shots
Now I just need to pick up some washers & tires, shave down the caliper pins, clean up a few things and the put it ll together for real. I think I'll save the good brake fluid until I'm sure these calipers are good, plus I'd like to remove & paint them up a bit better when I get coilovers.
Postby ZeroDrift » Wed May 02, 2012 4:13 am
Looks good!
Postby tubasteve » Wed May 09, 2012 5:10 am
can you explain "installed 3rd rear seat belt"? and show with pictures? not that any of my fat ass friends could fit there, but if what im guessing is correct
tubasteve
Postby underscore » Wed May 09, 2012 1:14 pm
It came with the car, I think it's some weird JDM thing. There's basically a lap belt that uses the same mounting bolts as the left and right seats, the straps even come out of the same holes. I'm pretty sure it's something someone did on their own and not a factory thing. I was just going to use it to strap down a fire extinguisher.
Postby Corey » Wed May 09, 2012 2:47 pm
^ its a factory belt. I removed mine - weight savings :wink:
Corey
Images: 50
Postby underscore » Wed May 09, 2012 4:13 pm
Well I know it's an OEM Toyota belt but is it really for the GTFour? I'd doubt that you can use the same anchor bolt for two different seatbelts - plus who the hell would want to sit up on that hump?
Postby UtahSleeper » Wed May 09, 2012 4:41 pm
It's stock. My old celicas and protege's had the same setup, using the same anchor bolt for 2 belts.
UtahSleeper
Postby underscore » Wed May 09, 2012 4:53 pm
Well then I stand corrected. I guess it's for families with 3 kids where one is either a lot shorter or loved a lot less than the other 2 :lol:
Postby nebvan » Wed May 09, 2012 5:55 pm
How do you make the waterspay work? Did you rewire it, with a new relay or just add a switch to the existing wire??
nebvan
Postby underscore » Wed May 09, 2012 6:04 pm
I first tried applying power to the small plug that was tucked near the motor, apparently my relay was shot and that relay is 1) expensive 2) only used on the RC in Japan and a couple cars in Europe, making a replacement hard to find, and 3) buried in the bloody fender behind the corner light, so I snipped the larger wires that run from the relay to the motor and wired it to a new relay near the battery. Eventually I'll get a new relay from Europe and wire it back the way it was originally wired, which would just need a small switch and the right kind of plug.
Keep in mind you also need to redo the hose so that it shoots out the sprayers, a write-up I read online said this can be done with the bumper still on but I can't see how on earth anyone could do it with the bumper attached to the car.
Oh and lastly be sure to use a momentary push button, not a switch, as the pump is very powerful and shoots A LOT of windshield washer fluid (I'm not sure if the OEM relay is supposed to restrict the power to it or something).
Postby nebvan » Wed May 09, 2012 7:23 pm
Are you sure that the relay behind the corner light is the one for sprayer.... I think it's the one for the windshield nozzle... 'Cause if I follow the wire from the sprayer pump, it doesn't seem to be plug into it...correct me if I'm wrong but it look to goes straight on the harness to the main fuse box...
nebvan
Postby underscore » Wed May 09, 2012 8:20 pm
The main pump should go to the main harness, the extra pump on the bottom for the sprayer went up to this relay, which went back down to the small plug I found. I think my relay was damaged when the car was hit on that corner, try hooking a 12V wire and a ground wire to the small white plug and listen for the pump if your hoses aren't swapped yet.
Also, if you look at the parts diagrams, "85942‑33010 RELAY, CLEANER CONTROL" is listed as "Not Applicable" for the regular GTFour, and on the diagram itself it has a small * next to it, denoting that it is only on the RC. From the looks of things it mounts to the top of the tank, I'm not sure if you can drop the washer tank without removing the fender though. It also looks like you had to have a rear wiper (which I guess was optional only on the RC?) to get the tank that allows this all to be hooked up, so any RC without a factory rear wiper may not have the bumper squirter pump.
That relay is listed as $178.19 (ouch) and the pump itself is $153.96.
Postby underscore » Tue May 29, 2012 6:30 pm
Small update, just ordered Kuhmo SPT's in a 245/40R17 off 1010tires.coma rear strut tower bar off eBay, a new turbo & near rear rotors off here. I got the calipers pins filed down (grinder > file) and the drivers front brakes all buttoned up. I've been busy at work lately but hopefully this week I can get the passenger side together, then once my tires/turbo/rear rotors arrive button it all up and get it driving. The RallyArmor flaps will wait until I get/build some coilovers, as where I place them will depend on my ride height.
Oh, and hopefully get the meth kit in as well. Too much to do, too little time!
edit: new O2 sensor for the wideband is on the way as well. Speaking of, I need to find some good electric gauges, hopefully for under $100 a piece (AEM and Defi are too steep for me).
edit 2: added some new plans to the list
edit 3: just won $300 to a local shop that specializes in high-end European cars. Good thing I've got those Porsche brakes! Time to stock up on brake pads.
