1991 RC recovery mission - "Rebel Scum"
Re: 1991 RC recovery mission - "Darlinda the Tie Fighter"
Postby underscore » Sat Sep 15, 2012 8:03 am
Shiny! Poor lighting but you get the idea.
Postby underscore » Sun Sep 16, 2012 9:07 pm
I miss this noise viewtopic.php?f=44&t=44216
Also added my goal for the project to the first post.
Postby celi_wabbit » Tue Sep 18, 2012 12:54 pm
Hey Undescore... did you happen to have a gap issue between ur rotor and ball joint? I have the Porsche kit also and I'm having a slight rubbing inside part of the rotors. Did you have to get the rotor shaved and if so, how many MM did you have to shave?
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
Postby underscore » Tue Sep 18, 2012 2:25 pm
Nope mine seem to fit just fine. It's close, close enough that I ended up cutting the dust shields off because I couldn't bend them enough while still on the car, but it fits. How do your rotors line up with the calipers? Are you sure you've got the right rotors? Which ones did you get?
Postby celi_wabbit » Tue Sep 18, 2012 3:42 pm
underscore wrote:Nope mine seem to fit just fine. It's close, close enough that I ended up cutting the dust shields off because I couldn't bend them enough while still on the car, but it fits. How do your rotors line up with the calipers? Are you sure you've got the right rotors? Which ones did you get?
It's not a problem with calipers lining up to rotors. My DRT rotors has a mm and half clearance when jacked up but, I think it's less when the tire is on the ground. I see a slight rub mark inside the rotor just even to the ball joint. By the way, I have no issue with the dust shield.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby underscore » Tue Sep 18, 2012 3:52 pm
I know, I was using the comparison to the calipers to help gauge if the rotors are incorrect. I haven't lifted my front end back up since I put the brakes on, so I'll have to see how close they come. Maybe I'll use some putty or something to check if there is contact.
Postby celi_wabbit » Tue Sep 18, 2012 4:16 pm
underscore wrote:I know, I was using the comparison to the calipers to help gauge if the rotors are incorrect. I haven't lifted my front end back up since I put the brakes on, so I'll have to see how close they come. Maybe I'll use some putty or something to check if there is contact.
You'll know if you see some mark on your inner rotors. You probably don't have to lift it. Just need to lay and reach but, if your going to measure it, then, you may have to put it on the jack.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby underscore » Tue Sep 18, 2012 5:01 pm
I think I want to measure it, I'm not too familiar with suspension geometry, will this gap change even more once I lower the car/push it through corners?
Postby underscore » Thu Sep 20, 2012 3:16 am
I gave the RC the ol' reach around, and it feels like they might be touching. Hard to tell, as the ball joint is curved, so Ill do some measuring.
Postby celi_wabbit » Thu Sep 20, 2012 11:30 am
underscore wrote:I gave the RC the ol' reach around, and it feels like they might be touching. Hard to tell, as the ball joint is curved, so Ill do some measuring.
Keep me up to date! I know when I installed mine, I thought I had enough clearance between the rotors an d the ball joint. But I noticed that as soon as I dropped the car and had load on the wheels, the gap got smaller and noticed that had some rub mark on the inner rotors. I'm thinking of just getting a 3mm spacer and put it between the hub and rotor to push the gap 3mm more. Not sure if I need to extend the studs?
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby underscore » Thu Sep 20, 2012 1:27 pm
I was thinking the same thing, the studs should be fine, but I'm assuming we'd need to move the caliper as well. Which would mean shaving down the bracket 3mm.
I think a couple people are driving on this setup, I wonder what they and gtfourtc have to input on this?
Postby celi_wabbit » Thu Sep 20, 2012 1:38 pm
underscore wrote:I was thinking the same thing, the studs should be fine, but I'm assuming we'd need to move the caliper as well. Which would mean shaving down the bracket 3mm.
I think you can flip the bracket around and just put washer to space it out. From what gtfourtc was saying, its pretty close.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby underscore » Thu Sep 20, 2012 2:19 pm
I think I've already got my brackets flipped with the holes as far out as they go, I don't know for sure though. I might take it apart tonight.
Postby celi_wabbit » Thu Sep 20, 2012 2:38 pm
underscore wrote:I think I've already got my brackets flipped with the holes as far out as they go, I don't know for sure though. I might take it apart tonight.
That's the thing, Ive been searching and have not found anyone saying anything.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby underscore » Thu Sep 20, 2012 4:10 pm
Hmm, I guess it's up to us then. I'll lift it up and take the wheel off and see what happens when the suspension is at full compression.
