1991 RC recovery mission - "Rebel Scum"
Re: 1991 RC recovery mission - "Darlinda the Tie Fighter"
Postby celi_wabbit » Thu Sep 20, 2012 5:09 pm
underscore wrote:Hmm, I guess it's up to us then. I'll lift it up and take the wheel off and see what happens when the suspension is at full compression.
I can't take mine apart yet bc I'm going to the NE meet! so, I'll be doing it after then. I was also thinking of cambering it to see if that's enough to move it away from the ball joint. If that works? then I'll go with that. Just have to re-align the wheels again.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
Postby underscore » Thu Sep 20, 2012 6:11 pm
Ah gotcha, so is it just barely rubbing?
Postby celi_wabbit » Thu Sep 20, 2012 6:35 pm
underscore wrote:Ah gotcha, so is it just barely rubbing?
Yup!
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby underscore » Fri Sep 21, 2012 4:11 am
Tore the rest of the rear end apart, and broke bolt #2. Oh well, good excuse for some new hardware. Tomorrow it's all off to the shop to get new bushings pressed in, and to have the rear axles rebuilt, as the boots are all dried out and cracked.
Postby underscore » Tue Sep 25, 2012 9:49 pm
Rear end is at the shop, front control arms came out Sunday so they're off to the shop tonight.
Also I've been offered some free 680cc top feed injectors. I was planning on eventually jumping to 550's anyways, so how would the car handle these 680's? Obviously a new rail and FPR would go in with them.
Postby pintoBC_3sgte » Tue Sep 25, 2012 10:21 pm
may have missed it but what are you going with to tune?
pintoBC_3sgte
Postby Overtriped » Fri Sep 28, 2012 9:35 pm
Nice project! I was thinking of getting the Porsche brakes with sti rotors as well, trying to get a set of brackets. ill keep the inner spacers in mind. I would use lock washers with thoes brackets(if ya dont.) Keep up the good work!! Thanks for checking out my build!
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Postby underscore » Fri Sep 28, 2012 10:12 pm
Thanks! I removed the wheels and jacked up the suspension as high as I thought it would go without lifting the rest of the car up and it looks like I have ok clearance back there, but I'll still be keeping an eye on it.
pintoBC_5sfte wrote:may have missed it but what are you going with to tune?
Stock RC ECU and maybe a piggyback, but only if I really really have to.
Postby underscore » Tue Oct 02, 2012 11:55 pm
I've been informed that my bushings should be done, I also got some welding done to the front control arms while the bushings were out to stiffen them up, apparently some JDM racing team does this to all their GTFours and it helps a lot, so we'll see.
I'm also going to be entering some local Time Attack style racing coming up at the end of October. I really want to take the RC but k.beaty is making me want to take my GTS. I'm not sure if the poor thing would be up to that though.
Postby underscore » Thu Oct 04, 2012 7:34 pm
Apparently it took 6 hours to press the old bushings out and the new ones in...damn. I might have to buy a press to DIY the subframe bushings & the ones for my GTS.
Postby underscore » Sun Oct 07, 2012 8:25 pm
Got a couple parts installed today, I ended up having to add a couple washers under the swaybar mounting nut and bolt to prevent squishing the bushing too much:
BC Racing RAM Type coilovers
Brembo/Porsche Calipers
Powerslot/STi rotors
Technafit SS brake lines
GT4 Racing swaybar endlinks
GT4 Racing swaybar bushings
GT4 Racing front control arm bushings
Postby underscore » Sun Oct 07, 2012 8:38 pm
I also ran into a small problem. The small bracket that connect the rear mount for the front LCA, to the large bracket that the front mount connects to, won't line up. It's off by about 1/2" and I have no clue what to change to fix this:
Circled in red:
Postby gt4tified » Mon Oct 08, 2012 1:46 pm
Subscribed.
gt4tified
Images: 5
Postby DTE » Mon Oct 08, 2012 5:00 pm
underscore wrote:I also ran into a small problem. The small bracket that connect the rear mount for the front LCA, to the large bracket that the front mount connects to, won't line up. It's off by about 1/2" and I have no clue what to change to fix this:
To me it looks like you can flip "48075" and the hole would line up.
Devin
88 Celica All trac
DTE
Images: 5
Postby underscore » Mon Oct 08, 2012 5:46 pm
The problem is it's somehow now too short to reach and I have no clue how or why
