Nick's Motor
Nick's Motor
Postby Rpz123isme » Sun Jul 22, 2012 2:18 am
I'm going to do this mainly for Nick because today he dropped off his Alltrac motor at the shop I work at and has given me the honer to rebuild it for him :D . Depending on how pissed my other half is that I stayed home instead of going to San Diego tonight. I will have Pics of the progress Monday If she does not kill me. or Tuesday if she flips a lid.
Anywho Nick your motor is in great hands.
It was nice to finally meat you, and get this going.
-Robert
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby Rpz123isme » Wed Jul 25, 2012 1:28 am
Until you get your project thread
Some valves are thin :(
I have been told I have this magic touch on old parts.
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby celica_gtx » Wed Jul 25, 2012 2:00 am
Awesome dude ill end up linking it to the rest of my build.
FYI to others Im doin the 215 fwd LSD trans swap
the LSD is debatable but i will provide info and make your own
decision , its goin in my 90 GT.
got good pics comparing parts.
soon to come.
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Re: Nick's Motor
Postby celica_gtx » Wed Jul 25, 2012 10:25 pm
teaser
celica_gtx
Re: Nick's Motor
Postby Rpz123isme » Wed Jul 25, 2012 11:31 pm
The valve cover still has some pitting but its a million times better
Into the oven the block goes. Ill have clean pics tomorrow night
Random shot of the rip down
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby Rpz123isme » Fri Jul 27, 2012 12:15 am
All the paint and rust has been burnt off.
Then it was shot peened
Crappy shot because of the glare
Some of the other parts I cleaned today
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby celica_gtx » Fri Jul 27, 2012 2:30 am
damn shit cleaned up good!
celica_gtx
Re: Nick's Motor
Postby Rpz123isme » Thu Aug 02, 2012 11:20 pm
On the bench ready for grinding
blued and ready for final seat cuts
seats are done
shiny new ex valves
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby Rpz123isme » Thu Aug 09, 2012 3:01 am
Ok the kit is here
Im doing a shimless conversion on this build, nick asked me to share some details about the conversion benefits and how to adjust the valves in the future.
So Ill start with the basics, the shim over bucket makes for easier future valve clearance but you run the risk of spitting a shim out of the bucket when you start modding your motor or running high rpms.
some people already know this but toyota changed to a solid bucket in the newer celica motor, and low and behold the buckets are the same size as 2nd gen 3sgte. the thickness of the buckets are different however, and now instead of adding a thicker shim you have to replace the entire bucket with a thicker one if your valve clearance becomes to tight. but in the 3sgte world most of our motors spin rod bearings or crack before a valve adjustment is needed.
The shimless buckets are also a little lighter making higher rpms that much safer.
The way I personally shim a toyota motor after a valve job, Since the new 3 angle seat grind sinks the valve in to the head a few thousands of an inch you essentially close the valve clearance, so I assemble the head with out springs and retainers push the valve against the bucket and hold it firmly and use a feeler gauge to determine how much clearance is currently there. once I determine the current clearance I grind the stem of the valve .001" at a time until I have the recommended clearance. then the head is disassembled and springs and retainers are put in and the head is reassembled and clearances are rechecked to ensure the spring pressure does not change your clearance.
So all in all shimless is much safer for a modded motor and high rpms.
the shimless bucket is on the left and nicks old shim over bucket is on the right with the shim out so you can see what the shims look like.
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby Rpz123isme » Sat Aug 11, 2012 2:24 am
Boring the block with a brand new auto blind hole cutter
Honing
The block has been decked and painted Ill post those pics tomorrow
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby Rpz123isme » Sun Aug 12, 2012 12:46 am
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby 4rsnduction » Sun Aug 12, 2012 1:33 am
Its the bore and hone machine that makes me happy :)
Nice run down of the shimless setup, cheers :D
4rsnduction
Nick's Motor
Postby celigts » Sun Aug 12, 2012 2:22 am
That looks awesome!
3SGTE project motor very slow
celigts
Re: Nick's Motor
Postby Rpz123isme » Fri Aug 24, 2012 1:46 am
Ok his motor has been completed and he picked it up today.
Head completed
More parts
even more parts
short block assembled
The head is on!
Coming together
Timed
That's a wrap
Hesperia, CA
Rpz123isme
Re: Nick's Motor
Postby 801Alltrac » Fri Aug 24, 2012 2:06 am
:shock: :notworthy: :shoots:
OMG very nice I like the cam pullies one stock one hks
801Alltrac
Images: 13
