ST185 CS restoration and full rebuild
Re: ST185 CS restoration and full rebuild
Postby brutekiller787 » Wed Jun 26, 2013 11:19 pm
Another wise member finds the benefits of a side feed. I think its stupid that people run front mounts with center feed when side feeds are so easy to come by
brutekiller787
Postby 90CelicaGt4 » Wed Jun 26, 2013 11:33 pm
Simply love it.
90CelicaGt4
Postby MWP » Thu Jun 27, 2013 3:38 am
Meurz wrote:The cylinder head comes from a new 3rd generation Euro spec crate engine. It has been mounted, but as shown by the paint on the valves has never run. After several years of storage I will disassemble it for a thorough clean and will rebuild it with upgraded parts.
Interesting... it has Caldina cams.
Postby GT4times2 » Mon Jul 08, 2013 4:34 pm
brutekiller787 wrote:Another wise member finds the benefits of a side feed. I think its stupid that people run front mounts with center feed when side feeds are so easy to come by
Agreed!!!
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby aus jd 2703 » Mon Jul 08, 2013 8:53 pm
find me a caldina manifold then?
not as common as the gen 2 sidefeeds
aus jd 2703
Postby brutekiller787 » Mon Jul 08, 2013 10:45 pm
Ebaying or forum hunting will find you what you need. I'm just saying they are easier for front mounts which I'm sure you won't deny
brutekiller787
Postby GT4times2 » Mon Jul 08, 2013 11:18 pm
You can always build your own side feed set up. Problem solved
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
Postby DeeCee » Tue Jul 09, 2013 12:54 am
Approx $300NZ for manifold and tb on Trademe when they come up.. you could have just asked your neighbours
If you are serious I can chase one local for you. I don't believe he sold the setup
DeeCee
Postby CSAlltrac » Sat Jul 27, 2013 3:28 am
Meurz, beautiful as usual. I love the build plan, simple, responsive, and reliable. That game plan will have amazing results. Keep the pics coming! On the side feed topic, it is a better design for front mounts but center feeds work. My center feed has worked for years, high HP and low HP. For some, like me, its just not worth the trouble of changing out manifolds, changing IC piping design, and then a retune. Cuz to fully optimize the benefits of the side feed a proper tune for it should be implemented. It's a ton of hassle for not much gain.
Postby Punknoodle » Sat Jul 27, 2013 11:36 am
^^ Unless you implement it in to the design stage, in which case you get a much better looking engine bay from not needing an intercooler pipe running on top of your engine, and it doesn't require reworking anything as everything is made to fit that manifold. That's the way I'm going to go.
Punknoodle
Postby Meurz » Sat Jul 27, 2013 6:32 pm
CSAlltrac wrote:Meurz, beautiful as usual. I love the build plan, simple, responsive, and reliable. That game plan will have amazing results. Keep the pics coming! On the side feed topic, it is a better design for front mounts but center feeds work. My center feed has worked for years, high HP and low HP. For some, like me, its just not worth the trouble of changing out manifolds, changing IC piping design, and then a retune. Cuz to fully optimize the benefits of the side feed a proper tune for it should be implemented. It's a ton of hassle for not much gain.
Thanks man. Center feed sure works, but since I started from scratch (sold the old engine) I went for this (specially because I went gen3 as well).
Turbocelica.nl
Meurz
Postby aus jd 2703 » Tue Mar 11, 2014 5:17 am
whats been happening Rene?
8 months no update?
dieing to see what you have been doing over the winter!!!
aus jd 2703
Postby Corey » Thu Apr 09, 2015 6:22 pm
Update!?
Corey
Images: 50
Postby CSAlltrac » Thu Apr 09, 2015 9:12 pm
Corey Darling wrote:Update!?
This
Postby Insanity-74 » Sat Apr 11, 2015 8:21 am
This
That.
Insanity-74
