FIRE! Pics! Racecar Build. Video Added Jan 31 2013
Re: HELP! FIRE! Pics
Postby underscore » Thu Dec 20, 2012 5:54 pm
You know you're going full race car when you've got race car wheels! Nice work!
Postby klue » Thu Dec 20, 2012 9:45 pm
looks great james!
Postby phattyduck » Fri Dec 21, 2012 5:38 pm
yota 3.0 wrote:When i took apart the rear sub frame, the rear toe adjust arm bushings were toast. Made some from oilite bronze for both sides.. should be nice and tight.
More coming!
~James
Solid bushings for the suspension scare me. You'll need to allow for some small amount of movement in the directions other than the standard rotation of that bushing... If you want solid, figure out a good way to do a pillow-ball/heim joint there.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby yota 3.0 » Fri Dec 21, 2012 5:47 pm
It is just the toe adjust side that will be solid.. I'll let everyone know how it holds up!
I don't think it will be an issue
~James
Mechanical Engineer ;)
yota 3.0
Postby rallygarage » Fri Dec 21, 2012 6:03 pm
If you dont need A/C don't put back the original HVAC. Use this instead.
http://www.ebay.com/itm/Flex-a-lite-640 ... 6d&vxp=mtr
This is a Flex-a-lite Mojave heater. It is a size of a shoe box. You can hange it on the fire wall with simple brackets. They have a hardware kit to attach it to defroster ports in dash board. Very popular with professional rally car builders here and in UK. I believe JEGS has something very simular under their own house brand. Plumbs into OEM heater plumbing. Comes with a heater valve and a fan speed selector switch.
You will have more room to mount all the computers etc. on the fire wall. Very clean install.
rallygarage
Postby yota 3.0 » Fri Dec 21, 2012 6:10 pm
Oh sh*t!
Wow thanks for the link! Definitely seems like the way to go... I'm trying to cut as much weight as possible..
Thanks again
~James
yota 3.0
Postby rallygarage » Fri Dec 21, 2012 6:19 pm
This is Jegs house version of the heater. Even nicer, comes with brackets and much cheaper. Also has install plumbing.
http://www.jegs.com/i/JEGS-Performance- ... oreDetails
You can run a cage pipe across under dash without worry about the HVAC in your way. You can attach or refabricate steering clumn better when you have a cross pipe under the dash....
rallygarage
Postby yota 3.0 » Fri Dec 21, 2012 6:29 pm
Ohhhh I like that a lot better..
Purchased! lol
Thanks!
~James
yota 3.0
Postby rallygarage » Fri Dec 21, 2012 6:59 pm
Also in my rally car I don't use the valve at all. When the fan is off you feel no heat at all. Instead of a their fan speed selector I used a 3 positin switch. Off, slow, fast. That is it.
rallygarage
Postby yota 3.0 » Fri Dec 21, 2012 8:30 pm
Thanks for all the tips rallygarage!
:D
~James
yota 3.0
Postby yota 3.0 » Sat Dec 22, 2012 1:26 pm
Cage almost done! Such a good feeling.
Rear sub frame and diff strap back from powder coating, and Klue's solid bushing and mount and installed my ST205 diff
TWM short shifter with shifter extension, most contradicting purchase I've ever made lol
Solid shifter bushings and mounts
Old shifter
More comin!
~James
yota 3.0
Postby toayoztan » Sat Dec 22, 2012 6:38 pm
Did you get the 2 solid rear diff carrier bushings too? (the strap you refer to)
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby yota 3.0 » Sat Dec 22, 2012 7:15 pm
yes i did but you have to use the big ugly washers on top lol or else the bolts are too long.
yota 3.0
Postby klue » Sat Dec 22, 2012 11:16 pm
your cage looks great, im going to get into building mine soon I hope!
Take some more pics when your done :)
Postby warracer » Sun Dec 23, 2012 2:42 am
Wow awesome work !
I love the fact that you are using grade A parts ! :notworthy:
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
