FIRE! Pics! Racecar Build. Video Added Jan 31 2013
Re: HELP! FIRE! Pics
Postby Ironchief » Sun Dec 23, 2012 3:59 am
Looks like she's coming along nicely. Kudos!
1990 CDM All Trac
Ironchief
Postby yota 3.0 » Mon Dec 24, 2012 1:52 pm
Thanks Guys!! :D
Intercooler core showed up, yup im building my own!
This is the biggest top mount intercooler you can fit (height wise) i could of went wider but i didnt feel i needed to with the current output of the engine. Some of you might wonder why I didnt go front mount, well in ice racing, if i hit a bank of another car, it would be the first thing to get damaged.. Its nice and safe under the hood haha.
Started to mock up some tanks
More coming
~James
yota 3.0
Postby Meenya » Tue Dec 25, 2012 2:48 pm
Great work!
I plan to do Zinc plating from here http://www.mmplating.com/index.html for all the hardware pieces including these big washers when I do my bushings.
I'm sure there are other places that can do that as well.
yota 3.0 wrote:yes i did but you have to use the big ugly washers on top lol or else the bolts are too long.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby rallygarage » Wed Dec 26, 2012 3:34 pm
Instead of using shifter extender raise the entire shifter asembly off the floor by machining 4 cylindrical spacers about 2 inches long. Shifter extender creates alot of slop. That is a common Evo Celica rally mod.
rallygarage
Postby yota 3.0 » Thu Dec 27, 2012 1:51 pm
^ I agree there is more slop with the extension on. Thanks for the tip, ill have to make some spacers to raise the mount and remove the extension.
~James
yota 3.0
Postby yota 3.0 » Fri Dec 28, 2012 1:51 pm
Well since I am making my own intercooler i also made an adapter for the throttle body as it was ripped and at one point someone tried to repair it with electrical tape.
And i finally finished the cage, notice how tight everything is and how the main hoop is right centered between the small window and door frame. My gf spent 2 days painting for me as i spent enough time in there welding lol
let me know what you guys think :)
~James
yota 3.0
Postby Tecker185 » Fri Dec 28, 2012 2:10 pm
I think it looks great! Will you be running door panels? Or any interior for that matter? I like the way that looks I'd like to do something similar when I cage my car but would like to keep my interior.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby yota 3.0 » Fri Dec 28, 2012 2:22 pm
thanks!
The dash will be going back in and the parts around the shifter. No door panels, the cage tubes actually go inside the doors, this helps with room inside the car and more importantly helps protect me from a side impact, should something like that ever happen.
yota 3.0
Postby athousandleaves » Fri Dec 28, 2012 5:10 pm
Amazing work so far!
You should keep making those throttle body adapters, I'm sure a lot of us would like something better than the stock one as it is prone to breaking.
How are you keeping the windows up with all the window hardware removed?
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby yota 3.0 » Fri Dec 28, 2012 5:57 pm
I guess if there's enough interest I could make a few more, I don't mind helping people out.
lol there are no windows in the doors ;) those are just the frames I made to support the Lexan when it goes in
~James
yota 3.0
Postby yota 3.0 » Mon Dec 31, 2012 1:04 am
Well it's getting closer to being complete!
Made spacers for the shifter mount and got rid of the shifter extension
Finally got the interior back together
More updates comin
~James
yota 3.0
Postby RallyX-GT4 » Mon Dec 31, 2012 8:13 pm
Almost didn't click on this thread - so glad that I did. Awesome work thus far... And a cool girlfriend! Can't wait to see more!
1988 - ST165 - RallyCross #3
RallyX-GT4
Postby yota 3.0 » Fri Jan 04, 2013 4:11 pm
^ Thanks! I might change the name of the thread actually, now that you mention it.
Small update:
Got the side windows done
And the rear window
more updates comin
~James
yota 3.0
Re: FIRE! Pics! Racecar Build
Postby rallygarage » Fri Jan 04, 2013 6:01 pm
Nice windows. If you take the old door cards and cut off the flat part leaving just the round part on top. When that is installed back on the door it will protect hands from inner door metal.
rallygarage
Postby rallygarage » Fri Jan 04, 2013 6:04 pm
Are you allowed hydraulic hand break?
rallygarage
