FIRE! Pics! Racecar Build. Video Added Jan 31 2013
Re: FIRE! Pics! Racecar Build
Postby yota 3.0 » Fri Jan 04, 2013 6:19 pm
yes, nothing in the rules against it
yota 3.0
Postby l00k0v3rth3r3 » Fri Jan 04, 2013 6:24 pm
love this thread!
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
1953 Dodge B4B 1/2 Ton Pick up - Currently Lawn Art
l00k0v3rth3r3
Postby 801Alltrac » Fri Jan 04, 2013 7:54 pm
Love the windows cage looks great love that blue keep on keepn on
801Alltrac
Images: 13
Postby rallygarage » Fri Jan 04, 2013 8:16 pm
I think 2 piston ST205 calipers will work well with hydraulic brake. You just need spare rotors. There are many hand brake designs. I like long and vertical. To the right of the shifter. Mounted on transmission tunnel.
rallygarage
Postby yota 3.0 » Sat Jan 05, 2013 12:22 am
will i be able to fit a 15" rim with 205 calipers though?
i thought i couldnt
~James
yota 3.0
Postby klue » Sat Jan 05, 2013 1:13 am
yota 3.0 wrote:will i be able to fit a 15" rim with 205 calipers though?
i thought i couldnt
~James
nope :(
Postby CMS-GT4 » Sat Jan 05, 2013 3:13 am
Wicked cage work.
Postby Insanity-74 » Sat Jan 05, 2013 7:53 pm
It would help if you could add some extra bits into the cage and tie in the rear sub frame mounting points.
helps stiffen things up a bit.
Insanity-74
Postby yota 3.0 » Mon Jan 07, 2013 2:23 pm
Thanks everyone for the comments and interest :)
Insanity - this is acutally a really good idea, however we are fresh out of tubing and my first race is this sunday the 13th. also keep in mind that i am trying to keep the car as light as possible, but if i feel it is needed after a few races then i will for sure be adding more tubing like you did :) nice work by the way!
ok so the suspension has arrived and all i can say is, BEEEEFFYYY! KSport designed these things for some serious abuse. just look at the size of the shock shaft.
Window nets and belts are in
here is the belt i used for my A/C delete if anyone is interested
also have B&G lowering springs that i took out of the car, make an offer if you are interested
So this was a bit of a chore, but since i am so picky on how the car looks as much as function, i took the time to break the old glass out of the trim and replace it with lexan for that factory look (almost) lol
more updates coming
~James
yota 3.0
Postby toayoztan » Mon Jan 07, 2013 6:22 pm
For the AC delete, did you use the original pulley and get a 3sge non AC ribbed pulley?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby rallygarage » Mon Jan 07, 2013 8:07 pm
If everything works out LSD in the rear diff and the improved Visco coupling will help alot with ice racing. You are very very handy. Have fun !!!!
rallygarage
Postby Insanity-74 » Mon Jan 07, 2013 8:57 pm
yota 3.0 wrote:Insanity - this is acutally a really good idea, however we are fresh out of tubing and my first race is this sunday the 13th. also keep in mind that i am trying to keep the car as light as possible, but if i feel it is needed after a few races then i will for sure be adding more tubing like you did :) nice work by the way!
~James
Thanks James :D
Good luck in the race on Sunday. Be sure to take lots of pictures if you have time 8)
Nial.
Insanity-74
Postby RallyX-GT4 » Mon Jan 07, 2013 9:29 pm
~James
Thanks James :D
Nial.
Pictures??? Heck, I want video!
1988 - ST165 - RallyCross #3
RallyX-GT4
Postby yota 3.0 » Tue Jan 08, 2013 1:39 pm
toayoztan wrote:For the AC delete, did you use the original pulley and get a 3sge non AC ribbed pulley?
Bryan
I just ran it over the smooth pully until i can find a reasonably priced ribbed one, the dealer wanted $263.00 for the pully... i think NOT!
rallygarage wrote:If everything works out LSD in the rear diff and the improved Visco coupling will help alot with ice racing. You are very very handy. Have fun !!!!
Thanks Man!! :D maybe when the engine comes out ill send the center diff away for better viscus fluid.
RallyX-GT4 wrote:
Insanity-74 wrote:Thanks James :D
Nial.
hahaha i will do my best to get as many pics and video for you guys. i will post soemthing in this thread for sure.
~James
yota 3.0
Postby yota 3.0 » Thu Jan 10, 2013 2:50 pm
Bit of an update:
i got my ATS downpipe and test fitted it. the quality and ceramic coating is super nice, too bad i will be cutting the flange off and TIG welding a vband on it. also put on a Royal Purple oil filter and filled the motor with Amsoil 10w30.
Tires showed up.... came all the way from Sweden..
also put my numbers on
things to do:
make aluminum exhaust
install wideband
mount fire extinguisher
new wiper blades
finish intercooler (hopefully by the next race)
try to change rusty, original fuel filter
... i know im missing something....
more updates coming
~James
yota 3.0
