Jeff's 1989 Black ST165
Re: Jeff's 1989 Black ST165
Postby sinerasis » Mon Jul 14, 2014 3:51 pm
Got the engine out this weekend. It only took two months since starting! It sucks only being able to work on it a day or two every couple of months. Makes progress seem even slower than it is. Oh well.
Got held up taking the transmission off. I got it to separate about half an inch and now it doesn't want to budge. Need to read up. Starting to think I must have missed a bolt somewhere.
The passenger side motor mount is stripped out. Previous owner put a long carriage nut/bolt in there instead. Might be able to re-tap it and get the correct bolt in there. Drivers motor mount is pretty rusty, will see if I can get one in better shape from the junk yard. Radiator top mount/brackets are like that too.
If someone knows the specs on the bolts used to mount the trans to the block I could use that. I need to get some bolts for the engine stand and forgot to bring the trans bolts with me. Trans bolts are too short for my stand I think.
Glamour shots:
Jeff
1989 ST165 Black
sinerasis
Postby sinerasis » Sun Jul 20, 2014 3:35 am
Two weekends in a row! Holy crap!
Got the trans and engine apart today. Got the engine on a stand. Found a Clutch Masters clutch hiding in there...
Used a one man method I'm going to call the "reverse missle silo". Used the cross member mounts and lifted the trans off the engine with a crane.
The clutch:
Flywheel:
...and finally on a stand:
The trans/transfer/diff assembly just for good measure:
Jeff
1989 ST165 Black
sinerasis
Postby sinerasis » Sun Jul 20, 2014 7:58 pm
Still tearing down... But had to stop to post this picture.
This is why you use RED Toyota coolant and NOT GREEN:
Jeff
1989 ST165 Black
sinerasis
Postby sinerasis » Sun Jul 20, 2014 11:47 pm
One more of coolant sludge
Jeff
1989 ST165 Black
sinerasis
Postby phattyduck » Mon Jul 21, 2014 3:53 pm
Also why it is very important you don't mix them...
Hopefully you can get it cleaned up! You'll have to do the radiator and heater cores too. :doh:
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby sinerasis » Mon Jul 21, 2014 5:13 pm
phattyduck wrote:Also why it is very important you don't mix them...
Yep! I wasn't initially going to do a full rebuild, but I'm glad I kept taking parts off... looks more than necessary. Radiator is getting replaced. Trying to find a place that'll dip the block or something. Will probably just flush the heater core myself, but we're a ways off from that right now.
Jeff
1989 ST165 Black
sinerasis
Postby 88gt4DE » Tue Jul 22, 2014 10:49 am
Wow ... nice work ... I'm assuming it was overheating ...
Postby sinerasis » Thu Jul 24, 2014 3:30 pm
88gt4DE wrote:Wow ... nice work ... I'm assuming it was overheating ...
Probably, but I've not had the car running long enough to know.
Jeff
1989 ST165 Black
sinerasis
Postby sinerasis » Tue Sep 23, 2014 1:13 am
No updates other than I bought a cover for it. A little more sitting shouldn't hurt it.
I've relocated to Maine while the car is still in Washington (in parts no less). Hopefully when things settle down a bit, something else will happen...
Jeff
1989 ST165 Black
sinerasis
Postby sinerasis » Thu Jul 30, 2015 5:11 pm
Planning to trailer the car to Maine in September. Should be able to work on it a lot more regularly at that time! :D
Jeff
1989 ST165 Black
sinerasis
Postby Heat » Sat Dec 24, 2016 1:12 am
I need this fuel tank.do you sell it?
Heat
Postby sinerasis » Sat Dec 24, 2016 3:12 pm
No I don't sell gas tanks.
To update this thread, I sold the car to user Tecker185 who had an engine ready to drop in. From what I've seen this car is driving around New York now :)
Jeff
1989 ST165 Black
sinerasis
Postby Tecker185 » Sun Dec 25, 2016 12:17 pm
Yupp took me about 6 months to get around to putting the motor in. Drove it up until we got snow. Next year think im going to put a gen4 in it. Here are some picsImage
Donor car
ImageImageImagemImage
Ill start a project thread next year if i find the funds to go gen4. If not ill just enjoy driving it.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
