SCCA ST165 finally begins
Re: SCCA ST165 finally begins
Postby eric thompson » Tue Apr 12, 2016 2:08 am
Sent from my XT1080 using Tapatalk
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby eric thompson » Tue Apr 12, 2016 2:09 am
ST165-PARTS-RED
eric thompson
Images: 6
ST165-PARTS-RED
eric thompson
Images: 6
Postby 88st165 » Wed Apr 13, 2016 2:50 am
I'm drooling over this car... :o
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby RedCelicaTRD » Mon Apr 18, 2016 1:59 pm
I'm afraid to know what the final bill is going to be :doh:
Postby MWP » Mon Apr 18, 2016 3:49 pm
Holy hell that is clean! :shock:
Amazing work, and a LOT of hours put into that.
Kudos.
Postby eric thompson » Mon Apr 18, 2016 3:53 pm
Time frame pushed back again... No test day this Friday and First event in 3 weeks is scratched... Hoping to do first race weekend in June with a test day that Fri.
This is the problem with a car like ours. Everything is basically custom and takes triple time... Stressed out now!
Thank you to everyone for the support. I'll keep updating as usual
ST165-PARTS-RED
eric thompson
Images: 6
Postby MWP » Mon Apr 18, 2016 3:56 pm
Yeah, i know the feeling doing a complete custom engine/car build like that.
You never realise how complicated, and time consuming it is until you give it a go.
Sometimes actually doing the work is the easy bit... working out the best way to go about doing something and design is the hard bit.
Only one thing i would change... use a +98 5S oil pump, a +98 crank angle sensor, and a Caldina/BEAMS crank cam belt pulley :)
No need to run that finger destroying toothed wheel then.
Postby eric thompson » Mon Apr 18, 2016 3:58 pm
On a 2nd Gen 3S? It all fits?
ST165-PARTS-RED
eric thompson
Images: 6
Postby MWP » Mon Apr 18, 2016 5:18 pm
Yup, did it with my 5S build.
The sensor isnt bolted up in this photo, but you can see where it sits inset into the 5S oil pump at about a 4 o'clock angle from the crank pulley.
The Caldina / BEAMS oil pumps cant be used as they need the accompanying alloy sumps to clear the sensor with it at the 6 o'clock position.
Its a normal 36-2 wheel. The tooth position is offset due to using the 5S sensor position and the Caldina pulley, but any decent ECU can take care of that (Megasquirt3 for me).
This plus the stock cam pos sensor in the Caldina head is easy to set up and gives factory level reliability :)
Postby RedCelicaTRD » Mon Apr 18, 2016 6:21 pm
MWP wrote:Yup, did it with my 5S build.
What timing belt and oil pump gear did you go with?
Also, do you have any other info on the Caldina setup? That's the one I'm interested in but I'm not sure what combo of parts I'll need. I'm thinking 3rd gen pan, Caldina pump, and Caldina crank gear but I am unsure what oil pump gear will get be used so I can use a stock belt.
Edit: After looking at some pics it looks like I'd need the 4th gen pan also.
Postby eric thompson » Mon Apr 18, 2016 6:27 pm
Gates Racing Tbelt and crank pulley is Ross Tuffbond from Australia...
ST165-PARTS-RED
eric thompson
Images: 6
Postby MWP » Tue Apr 19, 2016 5:19 am
RedCelicaTRD wrote:What timing belt and oil pump gear did you go with?
I used a 205 belt and a 205 oil pump pulley on the +98 5S oil pump.
You cant run a 205 sump and Caldina oil pump... they wont align properly.
... yes, your edit is correct :)
Or run a redtop beams oil pump and sump if you can find those.
Postby eric thompson » Sat Jul 16, 2016 12:37 am
ST165-PARTS-RED
eric thompson
Images: 6
Postby eric thompson » Sat Jul 16, 2016 12:38 am
Last edited by eric thompson on Sat Jul 16, 2016 12:41 am, edited 1 time in total.
ST165-PARTS-RED
eric thompson
Images: 6
