Just curious as to why you're running a dual rail setup?BADNEW5":3ahrxcua said:The dual rail got done yesterday.
GT4_DRED":n3l8kftf said:Just curious as to why you're running a dual rail setup?BADNEW5":n3l8kftf said:The dual rail got done yesterday.
BADNEW5":35ygtyl1 said:I have an Aeromotive Eliminator. It's being fed by two -8 lines Y'd together into one -10. Then I'll have a -10 feed all the way to both rails.
gearhead313":21wff0ra said:running e85 then??
Just a word of warning, I run one of those in a c6 vette we have and im on i believe my 3rd pump. For some reason, unknown to me, they start to get really noisy and just quit. The current one in there now has been ok, but it barely has 100mi on it.
I was thinking that same thing, I would say 700AWHP could be a reality with that setup on 91.l0ch0w":3m53wuib said:Your setup should be capable of well over 700whp then... You should try to bust the 1000awhp barrier... 2700cc per cyl is enough to develop like 1200+ crank HP on e85... What can your turbo handle? You running l19 head studs?
BADNEW5":2f5xafq8 said:My current turbo the GT4088R. The most I have seen on a AWD dynojet is 766 horsepower in SAE correction. Usually people post in STD on a dynojet cause your get about 3% more power. So 766 X 1.03=789 in STD. Most ever was 790 FWHP in a civic. It was Geoff at Full-Race's personal Civic. But the average for people who goto to 35+psi is 690-720.
Link to Civic: IMDELETINGPICTURETOCUTSPACE
And here is the 1997 Eclipse GSX
*Engine: 7-bolt, 2.3L Stroker with Eagle rods and Ross pistons, FFWD Butcher crank, BSE kit.
*Head: 1G unported, Crower single springs and retainers, stock size valves, stock lifters, HKS 272/272 cams, 2.5” IC pipes with a 1G stock throttle body.
*Turbo: Garrett GT4088R with T4 0.95 A/R divided flange
*Exhaust: 3.5”-to-3” Race Exhaust with muffler.
*Fuel Management: AEM EMS
*Fuel used in tuning: VP Racing Q16 – 117 Octane oxygenated race fuel:
The biggest turbo I would put on my car would be the PTE 6766 which my guess would be a max of 900 AWHP on a dynojet in my car. Not that I would make that. But that is my guess of the absolute max it would EVER do in my car. I really like the PTE 6466 which I would think maxing that one out would be around 850 AWHP. I think the most I'll ever make with the GT4088R is 750 AWHP. The PTE 6466 would give me pretty similar spool to my current, but give me about 50+ additional horsepower.
If I don't make over 700 awhp on the GT4088R I'll be upset. I'm expecting 700-750 awhp. And if I do 750+ awhp, I'll be ecstatic.
l0ch0w":3qmofms1 said:Ive ridden in a corn fed 6766PTE MR2 before. It developed 675 at only 23psi on the dynojet... I got to ride in it up to 40psi, which should have put it well into the 800s. Time wasn't recorded, but it walked a 10 second bottle fed trans am...
Both Pat (alltrac101) and Trevor (tjdouble07) have dynoed well into the 800s and 900s...
Pats 1/4 is 10.1 on street tires and 217mph texas mile... so if fastest 1/4 is part of your goal, then good luck...
BADNEW5":qvty7gae said:l0ch0w":qvty7gae said:Ive ridden in a corn fed 6766PTE MR2 before. It developed 675 at only 23psi on the dynojet... I got to ride in it up to 40psi, which should have put it well into the 800s. Time wasn't recorded, but it walked a 10 second bottle fed trans am...
MR2Josh had his boost that high? I thought in his last build he kept having problems so I figure he never went that high. Why didn't he dyno it higher than 25psi than? With 675 @ 23psi, he was on pace for 980whp at 40psi. If 675 @23psi is correct. He was making 17.9 horsepower per psi. granted the efficiency of the turbo would go down slightly with higher boost. But 40psi on that size of a turbo is not over doing it. So I would think he shouldn't of fell more than 30 horsepower off the equation. Putting him at 950whp.
It was my goal when I was younger for a fast 1/4 mile. Not anymore. Now I just want a good street car. I do like power but my lag is getting up there for the street. That is why I really don't want a bigger turbo. I'm actually considering the PTE 6266 cause it would make the same power as my GT4088R but have faster spool for the street. Doing a 40mph roll I've raced an EVO and a V6 swapped MR-2. Both pulled a full car length on me during my lag in 2nd gear. Granted once 2nd gear was over I had made up that car length and more. But my point is that it takes awhile for it to hit in low gears like 1st and 2nd, unless I'm pretty high in the rpm band. 1st gear doesn't even have enough load for me to make more than 20psi max unless I start with the 2step. 2nd gear at 40mph in the ST185RC trans put me at 4400 rpm. I really needed 44mph or 4800 rpm for 2nd gear to not have horrible lag. With my friends V6 MR-2 at 45mph, he didn't get an inch on me. At 4800+rpm in 2nd gear the turbo responds like it should.
With the ST185RC trans my 1st gear ended at 48mph. So that had 2nd gear starting at 5200rpm. I only have like 300rpm more lag I can sacrifice in 2nd gear before it starts affecting my 1-2 shift. Sure my car is fine on the highway for racing from like 50+mph. But the low speed stuff is starting to get bad for the street.
Plus Marius (Sleeper) on the board has ran a 9.89 @143.5mph in the 1/4 mile. I'm pretty sure he is the fastest on the Alltrac board. Unless anyone else knows of someone faster? And he did it with a PTE 6262 @33psi on drag radials. He has yet to dyno his car. His buddy may have just purchased a dyno so hopefully he can tune it out better and give us some numbers.
Sleepers videos:
http://youtu.be/UaMHliEemas
http://youtu.be/UmJP99igr2o
