700AWHP or Bust
Re: 700AWHP or Bust
Postby sleeper » Tue Jun 16, 2015 8:07 am
underscore wrote:Is the ARP washer problem only something that happens at high power levels, or at any power level? I'm about to put ARP hardware in but I'll stick with the stock washers if the ARP's might cause problems.
i`v seen it on as low as 397awhp... ( daily\trackday car)
sleeper
Re: 700AWHP or Bust
Postby BADNEWS » Tue Jun 16, 2015 9:28 am
athousandleaves wrote:Be careful with the higher pressure springs in the head, I recall a post over on one of the MR2 forums where they attributed the frequent breaking of camshafts to higher strength springs...
Not sure if this is the right thread but theres some good info about the valvetrain there anyway. http://www.mr2oc.com/showthread.php?t=4 ... ics/440599
Amazing you were doing this well with bent valves all along...
I already looked up the specs of about every valve spring for the 3S-GTE. The problem I found is that some companies have about the same pressure as the GSC Beehive I'm getting but with the bigger (standard size) retainer they are not meant for the rpm I am turning. All the companies were claiming that they are only good to the 8000-8500rpm and like 35psi. GSC is the only company that had a spring/retainer setup that was designed to handle 9000-9500rpm, 40-45psi of boost, with a 272 10.4mm lift cam. Below are the specs of all the valve springs I found. If the companies website didn't list their spec I emailed them for it. Only the Engle one I got from the exact forum thread you linked but I had read that and got the info on them before.
Brian Crower
Seat-1.350” (34.3mm)-85lbs
Open -.900” (23mm) (11.5mm lift)-200lbs
Coil Bind- .820” (20.8mm)
Engle (ATS sells these)
Seat-1.358” (34.5mm)-78.5lbs
Open -.900” (23mm) (11.5mm lift)-132lbs
Coil Bind- .857” (21.8mm)
Ferrea Dual Springs
Seat-1.378” (35mm)-65lbs
Open-.984” (25mm) (10mm lift)-185lbs
Coil bind-.591” (20MM) (15mm lift)
GSC Standard (rated to 8200 rpm and 32psi)
Seat-1.354” (34.5mm)-74lbs
Open-.921” (23.5mm) (11mm lift)-200lbs
GSC Beehive (don’t sell this kit anymore) (rated to 9000rpm and 35psi)
Seat-1.354” (34.5mm)-70lbs
Open-.954” (24.2mm) (10.3mm lift)-173lbs
Coil Bind-.590 (15mm)
GSC Beehive (revised with 2JZ Springs) (rated to 9500rpm and 45psi)
Seat-1.354" (24.5mm)-82lbs
0pen-.954' (24.2)-205lbs
Open-.904" (23mm)-225lbs
HKS
Seat-1.394” (35.4mm)-55lbs
Open-.972” (24.7mm) (10.7mm lift)-155lbs
Coil Bind-.941” (23.9mm)
Jun
Seat-1.36” (34.5mm)-66lbs
Open-.965” (24.5mm) (10mm lift)-160lbs
Kelford
Seat-1.42” (36mm)-85lbs
Open-.900” (23mm) (13mm lift)-175lbs
SuperTech Single Spring (was told "couldn't" handle my needs)
Seat-1.368” (34.75mm)-59lbs
Open-.896” (22.75mm)-175lbs
Coil bind-.815” (20.7mm)
SuperTech Dual Springs (was told "maybe" these could handle my needs)
Seat-1.398” (35.5mm)-77lbs
Open-.925” (23.5mm)-222lbs
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby BADNEWS » Tue Jun 23, 2015 12:44 am
My GSC stuff came today. Tomorrow i'll drop it off at the machine shop and then it's a waiting game again.
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby BADNEWS » Tue Jun 23, 2015 10:42 pm
Machine shop just tested one of my new springs.
@ 1.354" or seat pressure is 90lbs
@ .954" or 10.15mm of lift is 220lbs
They said when they break in they may come down as much as 5 lbs of tension. But still this is a big jump vs the Ferrea set I had before.
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby BADNEWS » Fri Jul 17, 2015 9:14 pm
Stopped by the machine shop today. I found out they had to machine the ID on the spring seat area to fit the GSC beehive springs. They have that all done. They also already installed all my new exhaust valve guides. They were starting on my valve seats to repair them but it was cutting like crap. Then the guy noticed that he was to bare aluminum in one. They looked closely and it seems Toyota has a coating or spray on material for the valve seats vs press in ones and mine is all gone. They have never seen anything like it before. So they are now changing them to press in ones like the video below.
https://youtu.be/wnDDpTBYMS4
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby CSAlltrac » Fri Jul 17, 2015 11:28 pm
I love seeing when things are perfected down to the smallest detail.
Re: 700AWHP or Bust
Postby Mr Alltrac » Sat Jul 18, 2015 2:23 am
It was fun watching the video of the machine cutting that seat. That was my job (except on ls motors) when I worked at Texas speed and performance. I would knock in the new seats, do the valve job, blend the heads, and reassemble.
Thanks for bringing back memories ha.
Mr Alltrac
Re: 700AWHP or Bust
Postby BADNEWS » Sun Oct 25, 2015 11:11 am
Finally got the car all back together with the new valve train and .051" (1.3mm) head gasket. The thicker head gasket brings my compression down to 9.7. With the thicker head gasket my cam gears had to be moved to retarded 2 degrees for both intake and exhaust for the cams to be at HKS spec.
Here is a video of it running at idle:
https://youtu.be/ZWrXF19V20s
Here is a video of me free revving it (it was raining so I felt I needed to have some fun):
https://youtu.be/gDspwPb2EAU
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby CSAlltrac » Sun Oct 25, 2015 10:56 pm
:D
Re: 700AWHP or Bust
Postby aus jd 2703 » Thu Nov 12, 2015 5:35 pm
Hey Ryan reading back you plastigauged your mains to 0.002"-0.003" oil clearance.
Couple questions. Are the rods and crank mains about the same clearance?
Did you notice a drop in base oil pressure? As stock are 0.0009" to 0.0017" from memory.
About to set my motor up and deciding on main clearances
aus jd 2703
Re: 700AWHP or Bust
Postby GT4_DRED » Thu Nov 12, 2015 7:39 pm
FWIW.. I'm running 0.025mm (0.001”) extra clearance on both rods and mains without a drop in oil press (un-shimmed camry pump with 3s gear). Ryan's running looser specs based on what he's doing, but also has more pump as a result.
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Re: 700AWHP or Bust
Postby aus jd 2703 » Thu Nov 12, 2015 8:22 pm
So dred. Your total clearance would be about 0.002"?
aus jd 2703
Re: 700AWHP or Bust
Postby BADNEWS » Tue Nov 24, 2015 1:18 pm
Dyno is scheduled for Wednesday.
Follow me on Instagram @badnewscelica for up to date results!!!!!
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby CSAlltrac » Tue Nov 24, 2015 6:19 pm
Is it wrong to wish you luck? Hope all goes well, you know Ill be watching! Image
Re: 700AWHP or Bust
Postby aus jd 2703 » Wed Dec 02, 2015 1:40 am
congrats on the 800AWHP!!!!
whats next apart from fixing ignition?
im jrp444 BTW on instagram
aus jd 2703
Users browsing this forum: Google Adsense [Bot] and 8 guests
