700AWHP or Bust
Re: 700AWHP or Bust
Postby BADNEWS » Fri Feb 15, 2013 10:51 am
Take a plastic cup. Now pretend that is you cylinder wall. If you try to move it like squeeze and stuff it moves easily. Now put the bottom half of the cup in cement. Everything flexes less. So it's just for support. I just went the extra step since I already cracked a block. Trevor is the only other person that I know of that has a 5S block half filled also.
My machinist does a ton of 4G63's. And he was telling me the rule for those blocks are, if you are running 40psi or more you need to to a 1/2 filled block or you'll crack it. And for 50+psi or the 1000+awhp they always do a fully filled block where coolant only goes through the head.
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby sleeper » Fri Feb 15, 2013 11:11 am
rm2932 wrote:Take a plastic cup. Now pretend that is you cylinder wall. If you try to move it like squeeze and stuff it moves easily. Now put the bottom half of the cup in cement. Everything flexes less. So it's just for support. I just went the extra step since I already cracked a block. Trevor is the only other person that I know of that has a 5S block half filled also.
Looking forward to seeing how the cooling will be at normal cruising. 8) If i ever rebuild my engine to 1000+hp i guess i will have to do that to..
sleeper
Re: 700AWHP or Bust
Postby BADNEWS » Fri Feb 15, 2013 2:11 pm
sleeper wrote:Looking forward to seeing how the cooling will be at normal cruising. 8) If i ever rebuild my engine to 1000+hp i guess i will have to do that to..
Fully filled is a drag race setup only. No more street driving with that.
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby sleeper » Fri Feb 15, 2013 2:15 pm
I know, thought about a half filled if i rebuild my engine for more hp. ( mine still needs to be a daily driver, and able to do road racing sessions.. ) :D
sleeper
Re: 700AWHP or Bust
Postby BADNEWS » Fri Feb 15, 2013 11:12 pm
For fun I ordered a oil pump from a 2001 Camry part #15100-74030
Here is a list of every vehicle that pump was in along with a price of $128.97:
http://www.toyotapartszone.com/Page_Product/PartsFits.aspx?partNumber=15100-74030
I already had the ATS HV Oil Pump with a price of $169.00
http://www.atsracing.net/Parts/Details/E-OILPUMP
Please note I had already put my front seal in my ATS pump (it doesn't come with it). To me it looks like they buy the 5S pump and take the gear off it. Next grind the two spots where it says Toyota on it. Then sell it.
Toyota 5S pump in the box:
5S pump alone:
ATS pump alone:
Pumps apart side by side, ATS left vs 5S right:
5S rotor:
ATS rotor:
Relief Springs side by side, ATS left vs 5S right:
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby Spectra1 » Fri Feb 15, 2013 11:30 pm
Sneaky buggers. You should post this over on mr2oc where they are vendors to see what they say.
93 St185 DD
90 ST185 - Project
Spectra1
Re: 700AWHP or Bust
Postby sleeper » Fri Feb 15, 2013 11:41 pm
sleeper
Re: 700AWHP or Bust
Postby underscore » Sat Feb 16, 2013 3:36 am
Wow you can actually see where they ground off TOYOTA
Re: 700AWHP or Bust
Postby RedCelicaTRD » Sat Feb 16, 2013 3:41 am
Depends on where ATS buys them from. Their source might be the ones who grinds the Toyota off. It's not uncommon.
Re: 700AWHP or Bust
Postby l0ch0w » Sat Feb 16, 2013 4:37 am
If you wanna see real difference in pump volumes, look at the gen 4 pump, that thing is super deep...
Andrew
1991 Red Alltrac
l0ch0w
Re: 700AWHP or Bust
Postby gearhead313 » Sat Feb 16, 2013 12:22 pm
any reason the crank wasnt debured, polished or knife edged? no rem coat?
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Re: 700AWHP or Bust
Postby BADNEWS » Sat Feb 16, 2013 12:45 pm
Cause I have already cracked a 5S crank. Didn't want to go nuts on it with a knife edge to have it crack again. if I crack another one I will be getting a Brian Crower Billet Crank.
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby BADNEWS » Sat Feb 16, 2013 9:47 pm
Took out my rear Factory LSD today to replace it with my new Cusco. I bought the diff brand new from Toyota, but now I have been hearing that people at my power level break the stock one. So I now have a factory rear LSD for sale that has about 2,000 miles on it. lol
Anyway took it out and put the new Cusco in. Monday I'll take it by my buddy who is a tech at Toyota to check back lash, bearing preload, and how the gears mesh. Once that is all in spec I'm going to completely disassemble it again to have it sand blasted to prep it for power coating. Hopefully it will be bolted back into the car in about 2 weeks.
Diff housing pulled out of the car:
Just opened it up and pulled the bearing caps to looked for the c clip for the axles. Only to learn the LSD is like the front axles, They have a snap ring so they just "pop" in. So with a little fineness with a hammer we got the axle ends out:
Diff pulled out:
Cusco left vs stock right:
You can see the clutch discs of the Cusco:
Cusco installed:
865AWHP, 591 torque
BADNEWS
Re: 700AWHP or Bust
Postby l0ch0w » Sun Feb 17, 2013 3:03 am
^now that is awesome! What color you PCing it?
Andrew
1991 Red Alltrac
l0ch0w
Re: 700AWHP or Bust
Postby BADNEWS » Sun Feb 17, 2013 3:46 am
l0ch0w wrote:^now that is awesome! What color you PCing it?
Black. My buddy sand blasts it at his work. Then his neighbor tapes it off and coats it at his work. He does industrial stuff so I only have 2 options. Black or Wrinkle Black. If I want colors I have to go to a normal place.
Here is the case blasted:
And the Trans case with wrinkle black powder coating:
Transfer case coated:
865AWHP, 591 torque
BADNEWS
Users browsing this forum: saved_1992 and 2 guests
