3SGTE Rav4
3SGTE Rav4
Postby jacubillo » Thu Feb 28, 2013 6:06 pm
I just bought a Caldina ST215 3SGTE to rebuild and then swap into my Rav4. The car will also have Alltrac drive gear to convert it to AWD.
I will start disasembling the engine tonight and will be posting updates/pictures. I will aim for 350HP with a custom MegaSquirt ECU
Any suggestions for the rebuild?
- Juan
1997 Rav4
Soon to be 3SGTE swaped...
Soon to be AWD converted...
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby Awesome-Trac » Thu Feb 28, 2013 6:27 pm
There's someone on this forum that has a 3sgte rav4 so you might want to check out his build thread
•Daniel
Awesome-Trac
Re: 3SGTE Rav4
Postby MWP » Fri Mar 01, 2013 2:55 am
Which model RAV4?
And is it one of those weird FWD versions??
Re: 3SGTE Rav4
Postby jacubillo » Fri Mar 01, 2013 9:08 pm
Awesome-Trac wrote:There's someone on this forum that has a 3sgte rav4 so you might want to check out his build thread
Thanks... I'll look it up!
MWP wrote:Which model RAV4?
It's a 1997 RAV4. Manual FWD transmission and a 3sfe engine that can barely pull itself. I started disassembling the exhaust manifold and the turbo is damaged :shock: and needs replacement. Since it's a caldina engine the turbine side comes attached to the manifold so now I need to source a new turbo and a new manifold as well. I'll probably go for an ST205 part since it shares the same bolt pattern. Suggestions for a 350HP capable turbo that is not *THAT* expensive?
I also sold the AWD auto transmission for $150 and the ECU for $400 and bought a megasquirt2 to tune the engine to my needs.
No pics from the progress since the camera was acting weird last night but I'll try to get some today with another camera.
- Juan
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby MWP » Fri Mar 01, 2013 9:29 pm
Yup, its a weird FWD model :(
Well, weird to me anyway... Toyota werent stupid enough to release a 2WD RAV*4* in Australia :twisted:
IMO you should find a gen3 manifold and ct20b or ct26 and use that for the moment.
It's a relatively big build so you should try to simplify it as much as possible. Do the big power stuff after youve got the engine in and all running.
MS2 has no problems with running two VR sensors, 4 inj & 4 cop in sequential?
Im not familiar with the abilities of the MS2, only the MS3.
Re: 3SGTE Rav4
Postby jacubillo » Fri Mar 01, 2013 11:12 pm
MWP wrote:Yup, its a weird FWD model :(
I always thought Rav4s where all AWD until I got mine to play and noticed it's the couldn't-afford-the-real-one version. So I'm stuck with FWD and can't offroad any more than a few bumpy roads. That's why I decided to swap and "street" the car.
I'll look for the manifold and turbo here in Costa Rica... otherwise I'll buy it in US&A and ship it over here.
The MS2 is capable of handling dual VR sensors, and 4 sequential CoilOnPlugs with minor hacking and a MS2-Extra firmware. My main concern is getting the base map to tune once I get to that stage.
Meanwhile... I have a slight question... Inspecting the damaged turbo and some minor damage on the engine ancilliaries, it seems the car it came from was in a frontal crash (probably also the reason why the engine was sold :x ...). I would prefer to fully inspect the engine prior to installing it just to find out something is not working properly. I already dismantled most of it but got to this point where I can't remove the main pulley. The bolt is simply not moving at all! I remember hearing about some pulley bolts that are screwed backwards... is this the case with the 3sgte?
Pic of my problem:
551
To remove the main pulley I have to unbolt the center bolt right? clockwise or counterclockwise?
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby 88gt4DE » Fri Mar 01, 2013 11:18 pm
Should be regular thread. I never know toyota to use backwards on anything. What you using to try to remove it ?
Re: 3SGTE Rav4
Postby jacubillo » Fri Mar 01, 2013 11:28 pm
Regular 20cm ratchet wrench with a 19mm socket + a #12 wrench to lock the flexplate on the other side of the engine so that it doesn't move. I guess the ratchet is too short and I need more torque... I'm going out to buy a breaker bar to fix this!
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby 88gt4DE » Fri Mar 01, 2013 11:34 pm
Yeah gonna need something bigger for sure or a 1/2 impact with about 100 psi ...
Re: 3SGTE Rav4
Postby jacubillo » Sat Mar 02, 2013 12:28 am
Ok, I just bought a 50cm breaker bar and the bolt (regular thread) came out easily.
But I still can't get the pulley out! :shrug:
It seems to be stuck in there... is there any special tool or something else I need to get this thing out of my way?!?!
552
Sorry if I ask lots of questions... I'm mechanically inclined but this is the first time I get into rebuilding an engine.
Should I just spray some WD40 and leave it soaking overnight?
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby MWP » Sat Mar 02, 2013 1:39 am
Can pick up late 90's 4WD RAV4s for not much money here now.
$4k will be a half decent one :)
I dont know how popular they were in the America, but there are *heaps* on the road here.
jacubillo wrote:It seems to be stuck in there... is there any special tool or something else I need to get this thing out of my way?!?!
I use a general purpose puller like this:
Handy to have in the tool box. Cheap and has many uses.
Re: 3SGTE Rav4
Postby jacubillo » Sun Mar 03, 2013 1:51 pm
Ok, got the puller for about $20 and now the pulley is out! :D
Offtopic: The general purpose puller name in spanish is : Telextractor. Coo huh?
I was adviced not to pull the whole engine apart but rather give it a tuneup... change the water pump, pulleys, spark plugs, etc.
What do you guys think? Remember that my turbo was really damaged... The compresor had it's wheel all f%&ked up and I'm affraid some metal bits might have gone into the valves/cilinders. It kinda looked like this:
(Not the original image since I already threw it away).
Should I disassemble the whole engine to inspect it? or just a tune up and hope no metal pieces might damage it's internals?
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby 88gt4DE » Sun Mar 03, 2013 2:17 pm
Well that turbo wheel dont look too pretty. Since yer trying to not take it apart , do you have access to a borescope ?
Re: 3SGTE Rav4
Postby McKenzieJr18 » Sun Mar 03, 2013 2:45 pm
put a transmission on it and compression test it before you put it in
92 alltrac 3rd gen 3s
McKenzieJr18
Re: 3SGTE Rav4
Postby jacubillo » Sun Mar 03, 2013 6:12 pm
I don't have access to a scope and I also don't have a spare transmission. I guess I'll just pull it apart and check every component. At least I'll have a chance to upgrade certain parts...
1997 Rav4
jacubillo
Images: 16
Users browsing this forum: Google [Bot] and 4 guests
