Dred's Rahtid 165
Re: Dred's Rahtid 165
Postby monkey8oi » Fri Jun 12, 2015 9:42 pm
Subscribed to see badass 165 progress.. =)
monkey8oi
Postby GT4times2 » Fri Jun 12, 2015 9:53 pm
Looking good Dred!! Can't wait for these two, to be on the road. Georgia/NC/Tennessee back roads!!!
Frantz
12 Toyota Sienna LE (The Daily Pacifier)
05 Toyota Avalon XLS
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby klue » Sun Jun 14, 2015 12:49 am
Badddd ass.
Love the video going to post it up online :P
Postby CMS-GT4 » Wed Jun 17, 2015 6:25 pm
That sexy manifold. I need to get my car down to TN and we can all ride the back roads together.
Re: Dred's Rahtid 165 - 2016 Updates
Postby GT4_DRED » Tue Jan 05, 2016 7:11 pm
Been busy working on the car the last few months, so here's a bit of an update on whats been happening. changed fuel rail in late summer and unknowingly pinched two of the injector seals, which led to a lean condition. Two pistons were melted and the head got a bit damaged as well. Decided to go late model 5s block, rebuild the head, go full sequential, and install the Electromotive TEC3 I had sitting for a bit. I also took the opportunity to put a new pad on the flywheel and clean up the wiring with a tuck. Here's the progress so far:
Pinched Injector seals that led to the pistons melting..
2001 5S block modded for diff housing clearance. Notice that there are no mounting points for the diff-to-block bracket on the far right
Holes drilled for the bracket (pictured). They were tapped later.
Head repaired w/ 1mm o/s Ferrea comp valves, dual springs (head modded to fit the seats) and new shim-less buckets
Rotating components and assembly
Difference in the wrist pin walls (new vs. old)
TEC3 setup, related setup and custom harness. Built the relay/fuse/power harness vs. paying the $130. My cost was $22 :shock:
60-2 and cam trigger setup from Racerx allowing for full sequential
Decided to do a quick disconnect bulkhead setup to ease pulling the motor and tuck the harness
Believe it or not, the harness on the left is all that will be on the engine (less the alternator, wideband and EGT harness)
Decided to ditch the re-plenum manifold, so picked up the RacerX kit on Black Friday
Will be SCCA'ing the car this season, so went with a smaller PTE 5857 billet dbb turbo vs. the 6266 dbb. Looking to give the EVOs and Subies HELL!
Completed and ready for install
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby msanders2 » Tue Jan 05, 2016 8:40 pm
Wow! Great job bud! Can't wait to hear it run.
msanders2
Postby FC Zach » Wed Jan 06, 2016 4:02 am
Very nice looking engine! !
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby Awesome-Trac » Wed Jan 06, 2016 6:10 am
This motor is scary and I like it!!!
•Daniel
Awesome-Trac
Postby GT4times2 » Thu Jan 07, 2016 5:33 am
Just like Perry, I can't stop looking at the pics on the phone. Coming along!! And strong! Making me feel like I'm at a standstill with the other two. If this and other projects aren't inspiring, I don't know what is. Keep it up.
Frantz
90 ST185 Gen4
GT4times2
Postby BADNEWS » Thu Jan 07, 2016 12:35 pm
Looks great. When my Alltrac was white I painted my valve cover a very similar color. I loved it in a white car.
What size injectors? And what type of fuel? I can send you my TEC3 map and tweak it for your stuff. It should get you to be able to start the car and drive decent right away. Obviously you'll have to make changes but it would be a great base tune to work off of.
865AWHP, 591 torque
BADNEWS
Postby GT4_DRED » Thu Jan 07, 2016 2:54 pm
Thanks guys!
BADNEWS wrote:Looks great. When my Alltrac was white I painted my valve cover a very similar color. I loved it in a white car.
Didn't realize you did a color change on your car; there's no evidence of white that I've seen.
I'm still planing to reach out to you regarding building the plug wires, but I saw that you've gone back to the Magnecor; I know you hated the color in the past. I have a set of universal Taylor 8.8s (blk), so hopefully those will work for the time being. On the old setup I was running the timing map I got from you and it worked really well, while still being conservative. I have access to both 104 oct and E85, but want to get familiar with the system using 93 and 104 first. I'm running a set of 1500cc for now until I decide on 2200cc or a dual rail setup using injectors I already have. I already have the extra rail and injectors, so it would just be a matter of getting the bosses and fabbing it up. I would definitely appreciate help getting it setup and running while I learn to navigate the system.
'91 MR2
GT4_DRED
Postby 88gt4DE » Sat Jan 09, 2016 2:11 am
Very nice work man ... Beautiful :smokes:
Postby ChrisD » Sun Apr 03, 2016 3:05 pm
How's progress going? Keenly interested as the build is so close to mine... :)
1988 ST165
1994 ST205 WRC
ChrisD
Postby GT4_DRED » Wed May 18, 2016 3:38 pm
Making some progress on the car, but between work/home and being a bit anal with the build, it's taking a while :doh: . I didnt want to mount anything forward of the shock towers, so It made for limited real-estate. :shrug: Finally picked up a tig welder as well :D
Redid the wiring, since its over 25 years old and took the opportunity to do a tuck as well
22 pin bulkhead connector (connects to the engine harness to make removing the motor easier)
Not fully seated..
Completed the fuse and relays for the standalone and mounted up the FPR
Didn't want to weld a TB bracket to the manifold, so I fabbed up one that mounts using one of the TB mounting bolts. Also wanted the cable to be somewhat hidden
Took a while to figure out a location for the DFU (coils) and had to fab a bracket for them
Next was figuring out a place for the catch can and fabbing a bracket
Painted white to help the bracket disappear on the tower
Should be able to get it done in the next few weeks and will try to keep the updates coming!
'91 MR2
GT4_DRED
Postby msanders2 » Wed May 18, 2016 11:12 pm
You're so awesome! Love this build
msanders2
Users browsing this forum: Bing [Bot], Punknoodle and 6 guests
