92 ST185 E85 project
Re: 92 ST185 E85 project
Postby kilt88 » Mon Nov 04, 2013 4:32 am
AlltracAvenger wrote:Bumping just to subscribe. It's awesome you've kept the '185 after it sitting around for so long. Any progress to report?
Yep. I have the engine block and head back. I need to test fit it to the tranny, and grind a rib or two or three off, then paint the block after that.
I'm trying to get pumps ordered, oil cooling sorted, etc.
Josh
from 185 Performance, many moons ago
92 ST185
Current Project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=46970
Duluth, GA
kilt88
Postby kilt88 » Mon Feb 03, 2014 12:21 am
Well, I got the fuel pump ordered. Lol....big accomplishment!
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Tue May 13, 2014 3:24 am
The rear left upgrade is complete.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Tue May 13, 2014 10:24 pm
Both sides of the rear are done now, and the parking brake shoes adjusted.
Josh
92 ST185
Duluth, GA
kilt88
Postby ALLensTRAC » Tue May 13, 2014 11:16 pm
Those 205 brakes turned out nice! Where did you source the DBA discs from?
Allen
ALLensTRAC
Postby kilt88 » Wed May 14, 2014 12:47 am
Thanks. When I still ran 185 Performance, I was a dealer for Stillen, and they had the DBA relationship.
Josh
92 ST185
Duluth, GA
kilt88
Postby phattyduck » Wed May 14, 2014 4:17 pm
ALLensTRAC wrote:Those 205 brakes turned out nice! Where did you source the DBA discs from?
I was gonna ask that same question! Sounds like they are still difficult to find (if DBA even makes them anymore?). Really, I'd just like a set of OEM quality (and blank) rear ST205 rotors...
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby ALLensTRAC » Fri May 16, 2014 12:14 am
Not to thread jack but you can get them on eBay Australia. Shipping kind of sucks and DBA is no longer making them. Here is a set for 300 shipped although not DBA they're blanks.
http://www.ebay.com.au/itm/140684838515
Allen
ALLensTRAC
Postby kilt88 » Mon May 19, 2014 12:20 am
I test fit the transmission today and found one more spot to grind down. So back off with the transmission to prep for paint.
Here are the freeze plus installed.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Thu May 29, 2014 2:57 am
First coat of paint applied.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Sat May 31, 2014 7:48 pm
Over the last couple of days, I added two more coats of paint. The paint is now dry, & I have begun engine assembly.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Sun Jun 01, 2014 4:53 am
More done.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Mon Jun 02, 2014 12:17 am
More progress on the engine today.
I got the oil pickup baffle modded (bent) so the Moroso oil pan would clear it. The pan is now mounted, oil and water pumps are on, and the timing belt and covers are on.
fun fun!
pics...
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Tue Jun 03, 2014 4:32 am
More progress tonight. Got the ATS fuel rail and ID2000 injectors installed, as well as the PS pump.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Wed Jun 04, 2014 3:47 am
Does anyone offhand know the size and thread pitch of this water fitting I pulled out of the 5s block intake side?
Josh
92 ST185
Duluth, GA
kilt88
Users browsing this forum: Google [Bot] and 3 guests
