92 ST185 E85 project
Re: 92 ST185 E85 project
Postby kilt88 » Wed Jun 04, 2014 4:21 am
kilt88 wrote:Does anyone offhand know the size and thread pitch of this water fitting I pulled out of the 5s block intake side?
It's the water drain cock. On the 3s, it's just a basic plug, but I guess the 5s put a valve and port on it. Threads look the same.
Josh
from 185 Performance, many moons ago
92 ST185
Current Project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=46970
Duluth, GA
kilt88
Postby kilt88 » Fri Jun 06, 2014 1:28 am
Found out it's 1/4" BPT. So I tapped it to 1/4" NPT. I found and bought a 5S oil cooler today, too. slow progres....
Josh
92 ST185
Duluth, GA
kilt88
Postby psipwrd » Fri Jun 06, 2014 2:25 pm
Nice build you got there. Anxious to see the results. Good luck!
psipwrd
Postby kilt88 » Fri Jun 06, 2014 2:47 pm
I'm anxious, too! Haha
Josh
92 ST185
Duluth, GA
kilt88
Postby CSAlltrac » Sun Jun 08, 2014 7:58 pm
Build is coming along nicely! Love the engine work, all looks proper and precise. I'm subscribed.
Postby kilt88 » Sun Jun 08, 2014 9:28 pm
Thanks everyone. I'm mating the engine and transmission today. I had to run out to get some loctite for the fw bolts, and soon the fun will begin.
After I get the transmission on, I'll have to drill and tap the holes for the right side transmission support.
Here is a pic of the fw in place.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Mon Jun 09, 2014 5:57 am
So more progress -- and full size pictures this time.
Here's the clutch I'm using. It's a Clutch Masters twin disc with a steel flywheel. This isn't a dedicated race car, and I'll be sitting in some traffic regularly. So yes, a heavy flywheel.
The flywheel put in place. I used OE Toyota 5S flywheel bolts. They fit perfectly. Yes, I used all 8 -- I just don't have a [clear] picture of it.
Here's the whole clutch
Clutch bolted to the flywheel
See the two discs
This has got to be my least favorite part of all this .... getting the transmission mated to the engine. I fought with it for about 1.5 hrs. But I had to be careful -- this time, there's a shiny Moroso oil pan that cannot be scratched. So I finally punted and pulled it apart, and shoved the clutch alignment tool back in. Ugh --- it wouldn't slide past the first of the two discs. So I loosened up the clutch cover, re-aligned everything, and tried again. Then it went together like butter ... well, almost like butter ... you know how this process goes. I really should have learned by now, and tried MWP's missile silo method.
Here it is, bolted together. That's enough for today.
My drill bit and tap arrive from Fastenal tomorrow, so I can mount the RHS transmission support to the block. Hopefully I'll be mounting this in the car tomorrow night.
Time for tonight's GOT episode -- if I can keep my eyes open.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Mon Jun 09, 2014 6:07 am
I also picked up a gasket set at Autozone for my A/C lines today. I hope I can remember how all those lines go back together. I'm really going to need A/C in Atlanta. ugh...
Josh
92 ST185
Duluth, GA
kilt88
Postby CSAlltrac » Mon Jun 09, 2014 7:08 pm
Got clutch?! Shouldn't ever have to worry about running out of flywheel grab. The missile silo method is the only way to go. Little bit more setup time and caution to be given as to not break anything like the timing cover but well worth it in the end. Keep it up man!
Postby kilt88 » Fri Jun 13, 2014 6:15 am
Ooh exciting day! The engine is back in the car. CVs are in, front brakes are on, propeller shaft is on, and the clutch is bled (and yes, the pedal feel is awesome with this CM twin disc).
Josh
92 ST185
Duluth, GA
kilt88
Postby ATS_Scott » Fri Jun 13, 2014 3:17 pm
Looking good Josh!
But stock cam gears? No Phenolic spacer? It's ok, that stuff is easy to swap out in the car...;-)
Scott McClendon
88 ST165 (long gone)
91 SW20 766HP, 698FT/LB on E85 PTE 6266 @ 43psi ID2000
Scott@atsracing.net
http://www.ATSRacing.net
940-293-1338
ATS_Scott
Postby kilt88 » Fri Jun 13, 2014 3:51 pm
ATS_Scott wrote:Looking good Josh!
Don't worry, TVIS has been gutted for many years. And we can talk about cam gears later. Remember, for now, I have to get this car running to get it moved to Georgia.
Josh
92 ST185
Duluth, GA
kilt88
Postby msanders2 » Fri Jun 13, 2014 11:25 pm
And us Georgians can't wait till you get here! I'll be glad to see another Beautiful Alltrac.
msanders2
Postby kilt88 » Sat Jun 14, 2014 1:26 am
msanders2 wrote:And us Georgians can't wait till you get here! I'll be glad to see another Beautiful Alltrac.
Nice! I'm eager to meet you guys. Is anyone around Suwanee or Lawrenceville?
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Sat Jun 14, 2014 1:31 am
So we got the brakes bled today, the AE midpipe installed, the L-R crossmember installed, and some randomness in the engine bay done. I'm breaking for some food, then will get back to it.
Josh
92 ST185
Duluth, GA
kilt88
