update
update
Postby nickgt4185 » Mon May 13, 2013 10:46 am
its been a while since i updated on here so here it goes :D
decided to rebuild engine :)
engine removal process started!
Engine out 8)
TVIS gone
side inlet manifold ,ported by louis
more great work from my mate louis :thumbsup: :D
hole drilled and now tapped for aquamist water injection jet
water injection pressure activated switch installed
cylinder head skimmed , head ready for re-assembly now :D
st205 gearbox as replacement
just have to swap over the poly mounts and get the new connectors for the braided lines for the gearbox cooler ,also renewing the 3 seals
got the crank balanced
my machinest told me it was pretty much in balance but he just took a little metal off the webs
installed clevite main bearings and st215 crankshaft
installed the acl big end bearings ,eagle rods, je pistons,oil cooler,water pump,thermostat
installed oil pump
got the D2 coilovers :D
Head went on last night :D
Head gasket
got superpro front wishbone bushes kit
One of the bucket seats I got.
rear main seal installed
new release bearing
flywheel installed with arps
clutch installed
finally gearbox and engine back together :D
Fitted clutch slave cylinder and the metal pipe snapped :x:x:x so if anyone has a spare metal clutch pipe they don't want please let me know 8-)
Changed the shorter slave cylinder pushrod for a longer one which will make using the clutch a bit easier on my left leg:grin:
just need to do a few other things and then its all ready to go back in :D :D :D
nickgt4185
Re: update
Postby nickgt4185 » Mon May 13, 2013 10:49 am
dont know why this hasnt carried on from my project thread but could the mods put this on my project thread ?thanks nick
nickgt4185
Re: update
Postby nickgt4185 » Mon May 13, 2013 11:14 am
I have also removed the power steering pump and converted to electric power steering, will post some pics up once all the pipes are connected and the electric pump is mounted 8-)
nickgt4185
