The White '88 Alltrac Camry 3S-GE BEAMS swap
• Page 3 of 5 • 1, 2, 3, 4, 5
Re: The White '88 Alltrac Camry 3S-GE BEAMS swap
Do want! Nice job man. It looks factory
CSAlltrac - Established Member
So many little adjustments! Its so nice when you finally have it all in place. My 3s-gte Alltrac Camry has been perfect for the last ~30k miles or so...CTechBlueDragon wrote:Yeah!! Awesome first start is the best feeling!
Can you explain why the relay? I am having trouble getting my starter wiring figured out myself. It clicked a couple times then now it wont do jack, not sure if I got everything wired right inside the cabin. I need help! lol
Way to go, every little annoying adjustment and grind down and tweak will all be worth it when your rolling!
As for the starter wiring, I bet the Celicas have the same issue... The starter solenoid needs lots of power/voltage to fully engage and turn on the starter motor. This is just an extra relay that pulls power directly from the battery and helps with that problem. Here's the Toyotanation writeup on it: http://www.toyotanation.com/forum/102-1 ... relay.html
'99 4Runner SR5 4WD 5VZ-FE
phattyduck - Established Member
phattyduck wrote:As for the starter wiring, I bet the Celicas have the same issue... The starter solenoid needs lots of power/voltage to fully engage and turn on the starter motor. This is just an extra relay that pulls power directly from the battery and helps with that problem. Here's the Toyotanation writeup on it: http://www.toyotanation.com/forum/102-1 ... relay.html
Indeed we do... viewtopic.php?p=298170#p298170
As always fantastic work Charlie, I'm counting the days till I can do the first start on my camry's swap now too... exciting times
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
1992 White turbo4WD
athousandleaves - Established Member
Cool stuff you got going on. Did you see the private message I sent you
- BonzaiCelica
- Newbie
I did now! For some reason, I never get emails notification when I get a PM (yes, I have the option to email me turned on...).BonzaiCelica wrote:Cool stuff you got going on. Did you see the private message I sent you
-charlie
Hi Charlie. I wrote to you again. Hope you can get back to me
- BonzaiCelica
- Newbie
Would you have time for me to stop by to check out your setup
- BonzaiCelica
- Newbie
A friend trailered the car down to his house (yay, 6 car garage, lift and welder...) and we got to work on the exhaust yesterday.
First, you can see the clearance that we were working with for the BEAMS header to the transfer case. You can tell the exhaust would just go right through where the transfer case is on this car.
Here the stock exhaust tacked up to front section of the BEAMS b-pipe. Sorry, no pictures of it back on the car. It looks like an exhaust.
From there, I drove the ~30 miles home, problem free. Cruise control works, the AC works, the sunroof works (and is surprisingly quiet at freeway speeds!), it even shifts pretty well for a 175k mile transmission... The cat-back on the car is already 'upgraded' so the exhaust note isn't the greatest (think quiet Civic exhaust with a little rasp). Decent power (yeah, I've been ruined by the 3s-gte) and loves to rev.
Now it needs one heck of an interior cleaning!
I love what you've done. I'm also wanting to put the redtop in my Corolla alltrac with an st205 transmission. I read on the 6gcelica site that a guy had to grind the block on his gen. 3 3sge to get it to fit over the transfer case of his st205. I read in your post that you said it fit. But I just want to ask. did you have to grind the block at all to get it to mate with your transmission? You obviously have an earlier model transmission. If the redtop fits on your transmission, do you think it will also mate to the st205 without any interference?
If anybody else has put the redtop and st205 together, I'd love to hear how yours fit.
1989 Corolla Alltrac Sedan. 4afe planning a BEAMS redtop swap
2010 Volkswagon CC
2010 Volkswagon CC
- Silky Smooth
- Newbie
- Images: 1
1989 Toyota Corolla
No grinding at all needed. Any 3s (fe, ge, gte) block should bolt up to any of the AWD manual transmissions. You can see in a few of the photos that the E56F trans has the same casting for the transfer case as the ST205 - in fact, all the vacuum actuated center diff lock stuff makes much more room above the transfer case than an ST205 box. This BEAMS motor even had all the mounting locations drilled and tapped for the two transfer case stiffeners. The 5s block that came out of the car, on the other hand, was missing some mounting bosses and had to get ground down to clear the transfer case.
Thanks you for the response duck. That sounds even better than I was hoping for.
2010 Volkswagon CC
2010 Volkswagon CC
- Silky Smooth
- Newbie
- Images: 1
1989 Toyota Corolla
I just fired up my 215 swap for the first time I am so happy!!! Time to revive the swapped Camry thread! I would make my own but I never keep up on that kinda thing. lol
- CTechBlueDragon
- Images: 50
I've been pretty bad at keeping things updated recently too - The car has been smogged. Tomorrow morning, I'll be getting a VIN problem fixed and hopefully it will be actually be legal to drive on the streets. Gotta love it when the title has a VIN that doesn't match the car - but the car isn't legal to drive on the street to go get updated/verified because the registration is out of date.CTechBlueDragon wrote:I just fired up my 215 swap for the first time I am so happy!!! Time to revive the swapped Camry thread! I would make my own but I never keep up on that kinda thing. lol
phattyduck wrote:I've been pretty bad at keeping things updated recently too - The car has been smogged. Tomorrow morning, I'll be getting a VIN problem fixed and hopefully it will be actually be legal to drive on the streets. Gotta love it when the title has a VIN that doesn't match the car - but the car isn't legal to drive on the street to go get updated/verified because the registration is out of date.CTechBlueDragon wrote:I just fired up my 215 swap for the first time I am so happy!!! Time to revive the swapped Camry thread! I would make my own but I never keep up on that kinda thing. lol![]()
Can't you get the one day pass from the DMV
-1990 Corolla sedan (sky blue) totalled by my brother
•Daniel
•Daniel
- Awesome-Trac
Yup. Already did, though I did it through AAA, of course. Get there at 9am, out of the door by 9:10am... hopefully the VIN inspection/correction goes as fast tomorrow.Awesome-Trac wrote:phattyduck wrote:I've been pretty bad at keeping things updated recently too - The car has been smogged. Tomorrow morning, I'll be getting a VIN problem fixed and hopefully it will be actually be legal to drive on the streets. Gotta love it when the title has a VIN that doesn't match the car - but the car isn't legal to drive on the street to go get updated/verified because the registration is out of date.CTechBlueDragon wrote:I just fired up my 215 swap for the first time I am so happy!!! Time to revive the swapped Camry thread! I would make my own but I never keep up on that kinda thing. lol![]()
I had an issue when I started the title transfer process when I bought the car - I knew the VIN was wrong and (somewhat stupidly) wanted to correct it at the time of title transfer. Of course, without the car there, they can't verify the VIN and correct the title. I had to go to the next AAA office to start the process over and not tell them to start the title transfer. Sadly, its now 2 1/2 years later and here I am again. At least this time I can bring the car in to get the error fixed.
