FC Zach's AllTrac
Re: FC Zach's AllTrac
Postby FC Zach » Mon Feb 05, 2018 8:07 pm
underscore wrote:That's what happens when you interfere with the patented Toyota Constant Rustproofing System (tm).
Ha ha, first time I've heard that one :rofl:
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby underscore » Tue Feb 06, 2018 4:31 am
VW actually did that on purpose back in the day (their history of terrible ideas will never end). One of the oil seals or gaskets was designed with a tiny leak, so that it would constantly cover the underside in a layer of oil to keep things from rusting.
Postby FC Zach » Tue Feb 06, 2018 4:43 am
underscore wrote:VW actually did that on purpose back in the day (their history of terrible ideas will never end).
Ha Ha, I just watched a Netflix docu-series (Dirty Money) and one of the episodes was about VW and their diesel cheat. . they thought they were clever.
underscore wrote:One of the oil seals or gaskets was designed with a tiny leak, so that it would constantly cover the underside in a layer of oil to keep things from rusting.
Well my driveway/garage doesn't agree with this method but at least there's not rust :)
FC Zach
Images: 9
Postby pintoBC_3sgte » Sat Feb 10, 2018 5:17 am
FC Zach wrote:
pintoBC_3sgte wrote:Hey, was wondering how you mounted your fogs. Looks like the same as I just ordered.
I bought a pair of inexpensive six LED lights off Amazon I believe. I secured them to thick scrap aluminum I had laying around that I bent to the angles I needed and then secured with galvanized screws (the holes may or may not have already been there, I don't remember).
Sorry, another question about your fogs, Did you happen to wire it to use the stock switch, or did you use a aftermarket switch it came with?
pintoBC_3sgte
Postby FC Zach » Sat Feb 10, 2018 9:15 am
Stock. . I also attached OE connectors to the lights so they were plug and play. Another thing I did was reroute the fog light wire (in the passenger kick panel) so the lights would work independently from the headlights as long as the switch is on. I can share that diagram I used if you wish.
FC Zach
Images: 9
Postby pintoBC_3sgte » Sat Feb 10, 2018 1:37 pm
Sure, thanks ! That would be awesome
pintoBC_3sgte
Postby FC Zach » Fri Feb 16, 2018 10:59 am
mx6er2587 wrote:premium or performance series? I have the performance series in mine, and while I love the look the accuracy and durability wasn't great. I was thinking of trying out the premium line
FC Zach wrote:Premium, so far I really like these.
Update on these: I have a Premium boost and I presume a performance oil press and water temp. . The boost works great, I really like the peak memory and the high boost warning light/beep. However, the oil pressure gauge isn't functioning properly and initially scared the crap out of me because the pressure dropped! After a little searching I found that the senders they use are junk! At least for the performance line, I can't say anything about the premium oil pressure gauge.
I'm replacing my gauges with the AutoMeter Spec Pro line. . well, one at a time at least (they're a little more expensive than the ProSports). First up is the oil pressure gauge (P32532) https://www.autometer.com/2-1-16-oil-pressure-0-120-psi-spek-pro-black-black.html
These gauges will clash with the stock instruments much less than the Prosport gauges I currently have, it's a plus that these have a green backlight option too.
FC Zach
Images: 9
Users browsing this forum: No registered users and 8 guests
