1991 Corolla All-Trac / The 3SGTE swap no one does
Re: 1991 Corolla All-Trac / The 3SGTE swap no one does
Postby underscore » Mon Apr 07, 2014 3:49 pm
Nice! What do the notes on the fender say? I'm guessing the vent and scoop get some funny looks being on that car.
Postby mk1spyder » Tue Apr 08, 2014 5:04 pm
The notes are just paint pen to remind me to do things when I was building it hah. The scoops are hilarious, HVAC mailboxes for furnaces turned into HP makers. The intercooler also has a fan underneath it. Wired some huge LED 12v strips across the dash as shift lights.
On the back it still has the original bumper stickers from the last owner, trouts unlimited, I love mountains, and I heart bluegrass. Then I put a lower case i between the DX logo, and then below that part of a 4 runner emblem. So it says DiX RUNNER lol. On the other side I scratched out the all-trac and put BLESSENEM below corolla. So stupid people think it is FWD.
mk1spyder
Postby Chuck.hudson » Tue Apr 08, 2014 5:58 pm
Man this is probably one of the coolest Rat Rods ive ever seen! I wish I could see peoples faces when that thing walks on em.
Chuck.hudson
Postby Chuck.hudson » Tue Apr 08, 2014 5:59 pm
Any chance you got any videos?
Chuck.hudson
Postby killemalltrac » Tue Apr 08, 2014 8:13 pm
mk1spyder wrote:Well its in and done, go to start it, nothing. I've got fuel but no spark. Code 14 no IGF signal. Tested everything, ECU is good, tried 2nd ignitor no change. Tweak'd fucked up this harness and they got rid of the intercooler pump connector so I can't do anything about losing code 54 unless I cut open the hearness, Tweak sucks.
I had them do my harness and its in and runs and what not but I still have code 54. They left out the wiring for the intercooler (im using the stock WTA) but a few phone calls later and Joshua asked me for my shipping address so that he could get it taken care of.
#80sMurderCar
killemalltrac
Images: 10
Postby mk1spyder » Wed Apr 09, 2014 8:08 pm
They wired my code 54 fix wrong, they suck. I had to redo it. They hooked 12v switched to the starter feed.
mk1spyder
Postby mk1spyder » Thu Apr 10, 2014 12:54 pm
I will post a vid after tonight.
mk1spyder
Postby mk1spyder » Fri Apr 11, 2014 10:45 am
Went to the 1/4, ran a 13.4 @ 103mph with a slight misfire problem. .201 60ft time, videos coming soon.
mk1spyder
Postby phattyduck » Fri Apr 11, 2014 3:25 pm
mk1spyder wrote:Went to the 1/4, ran a 13.4 @ 103mph with a slight misfire problem. .201 60ft time, videos coming soon.
Stock boost still? If so, you'll get that thing into the 12's without much more work!
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby mk1spyder » Fri Apr 11, 2014 3:31 pm
That was running lean at 15psi, I have a fuel issue with the stock corolla fuel system (only change is a LS400 pump).
Good launch vs a Civic, but misfiring under 20psi due to lean condition
https://www.youtube.com/watch?v=kna_deI0K_w
Bad launch vs a Challenger R/T running Eh under 15psi still lean
https://www.youtube.com/watch?v=HSwKNQ6i5xo
mk1spyder
Postby GT4_DRED » Fri Apr 11, 2014 5:04 pm
Sure the R/T didn't see that one coming :shoots: ..
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby LEEJODA » Mon Feb 09, 2015 5:42 pm
I've actually purchased my own '91 corolla alltrac in hope of this same swap. excited to hear what you have lined up still.
LEEJODA
Postby Awesome-Trac » Sat Feb 14, 2015 7:44 am
LEEJODA wrote:I've actually purchased my own '91 corolla alltrac in hope of this same swap. excited to hear what you have lined up still.
Is it the sedan or wagon?
•Daniel
Awesome-Trac
Postby LEEJODA » Sat Feb 14, 2015 11:38 am
it's a wagon all right. Pretty rough shape when I got it, but i refinished the interior so far. My wagon came with a parts bin of a car, so i swapped the interiors. Paint job is coming soon.
I'm waiting on a suspension kit from Fortune Auto currently be finished and mailed off. Searching for an engine/trans combo in the mean time. Bugger all for local selection.
LEEJODA
Postby tomasito » Fri May 01, 2015 5:14 am
Wonderful build! I am currently starting on a similar project. I have a 1990 Corolla All Trac, am going in the same route with the 3SGTE. Glad to see that it will work!!! Thanks! :notworthy:
tomasito
1990 Toyota Corolla
