polm's 280whp 92 jdm GT-Four build
Postby polm » Tue Jul 02, 2013 4:53 am
Hey guys,
First off let me introduce myself. I'm 18 and I'm from Quebec, Canada. I'm a student currently on vacation, heading for university this september. I've owned a red JDM 92 GT-Four since July 2012 and I really like the car. I'm confident I have the patience and determination to go through this project! My experience with cars is limited, yet surprising for a guy of my age (I think). This is my 3rd car, the 2 others being a 99 tercel and a 90 civic with a b16a, for which I did an engine rebuild and lots of suspension and chassis work last year. I learned a lot with these cars and I'm really looking forward to working on the GT-Four! I've been stacking parts since January and am finally ready to start my build! My goal is 280whp on 94 pump gas and water methanol injection while also improving handling. I will be doing the chipped honda ecu conversion as per the guide by scarecrow on mr2oc and some other good diy stuff like running modded wrx injectors (750cc) on a 5sfe fuel rail! ;) I have until the end of summer to complete this build, but I hope I'll be done before that so I can enjoy the car a bit! Here's my mod list and the first day of progress.
Mods, current mods are listed as "installed" (will update the list as I go through the build!): https://docs.google.com/spreadsheet/ccc ... oSXc#gid=0
The car (pictures were taken a couple of months ago):
Day 1:
Not much happened, got a lot of stuff out of the way, pictures aren't really relevent.
That's it for now!
Pierre
polm
Re: polm's 280whp 92 jdm GT-Four build
Postby brutekiller787 » Tue Jul 02, 2013 3:01 pm
Wanna make me a patch harness lol.
brutekiller787
Postby polm » Tue Jul 02, 2013 10:37 pm
brutekiller787 wrote:Wanna make me a patch harness lol.
It's not very hard actually you can do it yourself in an afternoon! I'll post links when I get home :)
polm
Postby polm » Wed Jul 03, 2013 12:47 am
Oops repost
polm
Postby warracer » Wed Jul 03, 2013 1:26 am
Sweet build cannot wait to see it :)
P.S Tu peux me text si t'as besoin d'aide! ;)
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby polm » Thu Jul 04, 2013 1:19 am
warracer wrote:Sweet build cannot wait to see it :)
Thanks! Your's looks sick too :) I'll be pulling the engine tomorrow! Only thing left to undo is the axles and damn they're tight lol I mean it's crazy how hard the bolts are to remove. I'll have to rent a stronger impact wrench!
Here are the promised links. This is the guide for the ecu conversion: http://www.mr2oc.com/showthread.php?t=381639
And here are the pinouts I used:
3sgte (find your ecu in the list): http://gt4.mwp.id.au/Electrical/All%203 ... iagram.png
OBD1 Honda: http://technet.ff-squad.com/wiring.obd1.htm
Progress today was pretty straightforward and not worth posting picks imo because there is nothing to see, except for some wires hanging around :p
Cheers!
Pierre
polm
polm's 280whp 92 jdm GT-Four build: Bolts for engine stand?
Postby polm » Fri Jul 05, 2013 3:24 am
So I got the engine out today! Finally! Those axle bolts were tight as f***, I rented a monstrous impact wrench that makes 720lbs of torque which is nearly 3 times the power of the one I had and man I still had to beat the shit out of it! I'll be starting to work on the engine tomorrow. I have a question for you guys, what bolts do you use to hold the engine on the engine stand and where do you screw them?? Thanks!
polm
Postby donte88st165 » Fri Jul 05, 2013 2:42 pm
nice man. I need to do that to my st165! just take engine out and clean everything up!
donte88st165
Postby warracer » Sat Jul 06, 2013 8:02 pm
damn no time is wasted! :)
____________
ST185H A-Spec:
warracer
Postby polm » Tue Jul 09, 2013 12:44 am
So! Forgot to post progress from Friday so here's a larger update! I started dismantling the block. Here are some pics. The block is dirty as hell and the hg is destroyed lol I'm glad I'm fixing this before something happens!
Cheers!
polm
Postby warracer » Tue Jul 09, 2013 9:43 pm
That burnt prestone :D
____________
ST185H A-Spec:
warracer
Postby polm » Tue Jul 09, 2013 11:31 pm
Yup lol you can see the engine's 20 years old! A good cleaning will do it some good!
polm
Re: polm's 280whp 92 jdm GT-Four build UPDATE 25/07!
Postby polm » Thu Jul 25, 2013 4:25 am
So, I haven't posted much progress (I'm lazy), though there has been some work done! The block is at the machine shop and I'll get it back in 2 weeks (I know it sucks :( ). For now here's a mixed update of everything I've done lately!
Cleaned the valve cover, fuel rail and misc supports so they're ready for paint
Looks kind of pink, but it's a lot better in person. I'll see if I can play with the lighting to get a better shot
Here's a link to the paint used, good stuff! http://www.rustoleum.com/en/product-cat ... /high-heat
Modded the wrx injectors. Here you can see the filing of the pins so they fit in the oem connectors
Compared to stock
Filed the cap off, the stock flow rate is 440cc, with the cap off they're 750cc, it's a common mod in the subaru scene
Compared to stock
Then I cut off the caps on the stock fuel rail
Fitted a mitsubishi dsm injector seal
And it seals perfectly, like it was meant to be there originally!
Next I welded and painted an extension for my kinugawa wastegate which was about 3 cm too short (very poor fitment, at least it works well) Looks good imo
Here's the IAT I'll be using, it's from an audi/vw 1.8t engine. Got it off ebay brand new for 9$, good deal! Best part is it uses the same connector type as the cold start injector so all I did was jump that wire in my patch harness to the IAT input of the ecu
Made this adapter plate out of scrap aluminum I had lying around
Sealed using the oem gasket and some liquid silicone gasket maker. Looks good imo
Here's a pic of the modded ignition wires. I used the 3sgte rubber seal cap or whatever you call it and a honda wire because they're required to fit the honda distributor for the ecu conversion
While we're at it I figured I should post a pic of the patch harness I made about 2 months ago, I was ready :p
So that's about it for now, though I have a bunch of parts I should just take pics of and post, I'll do so when I'm not lazy :twisted:
Hope you enjoy!
Cheers! :D
Pierre
polm
Postby quieter » Thu Jul 25, 2013 6:19 am
nice!
2011 BMW 535xi M pack (daily)
-Simon
quieter
