88 Alltrac - Restore
Re: 88 Alltrac - Restore
Postby zaluss » Tue Mar 18, 2014 1:46 pm
Tecker184 wrote:The engine is non interference so you will not damage anything.
Phew. I thought only the 3s/5sfe motors were non interference.
zaluss
Postby zaluss » Thu Mar 20, 2014 10:27 pm
Annddd head comes off...not too bad.
Untitled by MP.Hill, on Flickr
^Funny this picture makes it look like theres a hole above the valve but its actually oil reflecting from the light.
zaluss
Postby 88gt4DE » Fri Mar 21, 2014 1:12 am
Yes looks very clean :twisted: , It's about time you found something good in all that :smokes:
Postby zaluss » Sun Mar 23, 2014 11:03 pm
Today made some progress. Engine removed:
Disconnected everything and used the hoist to drop the motor on a rolly thing I bought.
Roll her out after I raised up the car. No pictures while it was in progress sadly.
I forgot about this as it slide out of the drive shaft. Left a nice huge puddle of fluid all over my garage.
Rear engine shot. The passenger side axle bolts were all stripped so I left it on during removal.
Minor surface rust near the battery area. Everything else looks pretty damn clean.
My apartment manager stopped by and watched me do this in utter awe. She laughed and said she definitely wants to see the finished project. Until next weekend...
zaluss
Postby 88gt4DE » Mon Mar 24, 2014 12:23 pm
I'm sure that's not what yer Apartment manager was really thinking :lol: Those axles pop out so you dont have to mess with those bolts if yer axle boots look ok ...
Postby zaluss » Mon Mar 24, 2014 1:11 pm
I thought they popped out too but man they wouldn't budge. Maybe I'll give it more force.
zaluss
Postby 88gt4DE » Tue Mar 25, 2014 1:23 am
Gently pull out on the axle like your using a slider hammer on them. Sometimes they will come out that way. You have have to move it around in quarter turns as you pulling outward to make it pop out ...
Postby phattyduck » Tue Mar 25, 2014 9:54 pm
zaluss wrote:I thought they popped out too but man they wouldn't budge. Maybe I'll give it more force.
You can use an extra clutch fork and a hammer to pop them out pretty quickly/easily... You need to find something thank can 'grab' the axle and put force on it directly outward from the transmission.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby zaluss » Sat Mar 29, 2014 2:29 am
Upon further examining the cylinder head for my 2nd gen 3SGTE I've seen several gouges along the cylinder head and marks along the cams. I'm not sure if the marks on the cams are normal though.
Cylinder head damage
zaluss
Postby 88gt4DE » Sat Mar 29, 2014 1:11 pm
I'm not sure those spots are damage or just casting ... Planning on a machine shop check on it ?
Postby Chuck.hudson » Sat Mar 29, 2014 2:24 pm
Ive got brand new hks cams in mine and if I remember correctly they have the same marks on them. I just assumed that they were some kind of tooling marks maybe from whatever held the cam while the lobes were being milled or whatever they do to them.
Chuck.hudson
Postby zaluss » Sat Mar 29, 2014 9:18 pm
Started to disassemble front suspension.
Steering rack removed. Dirty engine bay.
Pile o' suspension/steering
Broke whatever this was connected to the drivers side hub.
Started to clean all the dirt off. The engine bay is unusually pink.
Mmmm rusty brake booster.
zaluss
Postby 88gt4DE » Sat Mar 29, 2014 10:02 pm
Broken ABS sensor ... deleted mine and pulled the fuse and bulb .... don't need that old crap system. Steering Rack looks wet on one side ...
Postby zaluss » Sat Mar 29, 2014 10:16 pm
88gt4DE wrote:Broken ABS sensor ... deleted mine and pulled the fuse and bulb .... don't need that old crap system. Steering Rack looks wet on one side ...
Ah well thats useless. The whole ABS system wasn't there anyway. The steering rack looks wet? It'll be replaced with a reman anyway.
zaluss
Postby zaluss » Sat Mar 29, 2014 10:19 pm
Duplicate
zaluss
