Pipedreams":27gw1ojn said:Found a crack in cyl 2 also In the same spot. So the next block will get a good block filler treatment.
abraxxa":zf578oht said:Why did you go for the single-VVTi head instead of the Altezza Beams Dual-VVTi?
I'm running a Gen 4 3S-GTE with BC stroker and EFR7064 and like to make it spool better, currently 1.8bar @~4000rpm.
Love to know if a Altezza head would fit the 3S-GTE Gen 4 block from the Caldina ST215 (which had sleeves from the factory :shrug: ).
sleeper":3im39bqq said:abraxxa":3im39bqq said:Why did you go for the single-VVTi head instead of the Altezza Beams Dual-VVTi?
No 3s block had sleves...
