Pipedreams ST205, 5S-GTE BEAMS
Re: Pipedreams ST205, 5S-GTE BEAMS
Postby sleeper » Fri Aug 28, 2015 7:17 am
Pipedreams wrote:Found a crack in cyl 2 also :-) In the same spot. So the next block will get a good block filler treatment.
So you are going for a filler and not new sleeves?
Maybe go for a small fill, and sleeves? should be bullet proof.
btw: do you have a dyno graph with some more info on it now? ( would be fun to see what data the chart you posted was based on, ( corrections,temps,gear ratio and so on.. )
Also: why didn`t you rev it past 7300rpm?
sleeper
Postby Pipedreams » Fri Aug 28, 2015 9:40 am
I feel that it's to much money for sleeves. And they still break if a piston or rod goes. So I'd rather just get a new cheap block.
I haven't had time to look for more info on the dyno. I've been abroad for work the last two months.
They were a bit careful at the dyno and didn’t want to put to much strain on the engine with longer pulls and higher revs than that. It was reved to 7500 and I have the limiter at 8000.
Pipedreams
Postby gunt » Mon Aug 31, 2015 8:18 am
im not long on this is there a way to send a private message
gunt
Postby Pipedreams » Mon Aug 31, 2015 8:45 am
You can email me at hakan@pipedreams.se
Pipedreams
Postby abraxxa » Mon Sep 07, 2015 6:02 pm
Why did you go for the single-VVTi head instead of the Altezza Beams Dual-VVTi?
I'm running a Gen 4 3S-GTE with BC stroker and EFR7064 and like to make it spool better, currently 1.8bar @~4000rpm.
Love to know if a Altezza head would fit the 3S-GTE Gen 4 block from the Caldina ST215 (which had sleeves from the factory :shrug: ).
facelift ST205
abraxxa
Postby Hic » Mon Sep 07, 2015 6:09 pm
It is much harder to fit dual vvti.
Hic
Postby abraxxa » Mon Sep 07, 2015 6:22 pm
Hi Hic!
Any more infos?
I'd use a Haltech Elite 1500 to control it, so electronics shouldn't be a problem
facelift ST205
abraxxa
Postby Hic » Mon Sep 07, 2015 6:23 pm
Many problems alex :):):)
Hic
Postby abraxxa » Mon Sep 07, 2015 6:29 pm
That doesn't help me. What is needed to make it work? Mechanical incompatibilities? Water and oil passages?
facelift ST205
abraxxa
Postby sleeper » Mon Sep 07, 2015 8:32 pm
abraxxa wrote:Why did you go for the single-VVTi head instead of the Altezza Beams Dual-VVTi?
No 3s block had sleves...
sleeper
Postby Hic » Mon Sep 07, 2015 8:33 pm
Alex, just search mr2oc, guy tried with limited success. There is an engine mount that you need to rework, plus some extra stuff, I can't remember. Use the search.
Hic
Postby fussellbug » Mon Sep 07, 2015 8:36 pm
This thread explains what is needed to make the Blacktop Beams head (RWD, upright motor) work on a Redtop Beams FWD, motor tilted). Aside from making the head ready for use with the motor tilted, there is still the issue of how the passages on the head would line up with the 4th Gen GTE block.
http://www.mr2.com/forums/threads/93957-Adapting-Blacktop-head-to-Redtop-block
BTW: The guy who was working on this project decided it wasn't worth the extra money and effort to use the Blacktop head instead of the original head on his Redtop Beams. The gains for a turbo application may be slightly better than the redtop head, but there are probably easier/less expensive ways to reach the same goals.
fussellbug
Images: 36
Postby Pipedreams » Sun Sep 13, 2015 4:54 pm
Finally got the clip from the testdrive.
https://www.youtube.com/watch?v=GTJ95X8O9Ng&feature=youtu.be
Pipedreams
Postby abraxxa » Sun Sep 13, 2015 5:43 pm
I know, but my Gen 4 has sleeves. I doubt that the previous Caldina owner had installed them so they must be OEM. My guess is Toyota used some weak Gen 3 blocks and installed sleeves instead of throwing them away. :shrug:
@Pipedreams: awesome! Did you fix the engine? New block?
facelift ST205
abraxxa
Postby Hic » Sun Sep 13, 2015 6:07 pm
Gen4 is without sleeves Alex
Hic
