Pipedreams ST205, 5S-GTE BEAMS
Re: Pipedreams ST205, 5S-GTE BEAMS
Postby gunt » Tue Oct 13, 2015 8:37 pm
so what solution are you looking at
gunt
Postby Pipedreams » Wed Oct 14, 2015 9:18 am
Blockfiller only. If the pistons are damaged I will probably buy them with full round skirt instead of the FSR.
Pipedreams
Postby gunt » Thu Oct 15, 2015 5:50 pm
would you not put liners in it / dry ones , do you mean concrete block filler
gunt
Postby Pipedreams » Fri Oct 16, 2015 12:28 am
I think it's too expensive to put liners in. Such a waste if a piston or rod brakes. So I will try "concrete" block filler.
I forgot about your email, but to answer that I don't believe this is a cooling issue as two cylinders cracked at the exact same spot, the corner of the piston skirt so I guess it's the cylinder wall flexing. And I have seen other cracking cylinder walls with this type of piston design. It doesn't seem to work well with very high power.
Pipedreams
Postby gunt » Fri Oct 16, 2015 7:32 pm
Liners here in evo's to correct damage only 80 euro per bore
gunt
Postby abraxxa » Thu Oct 29, 2015 7:38 pm
Hic wrote:Gen4 is without sleeves Alex
I finally took the time to upload the photo:
You can clearly see the edge between block and sleeve where the block has been milled.
@Pipedreams: I could get a Redtop Beams for a good price, can you please tell me what else is needed to make it fit a Gen 4 3S-GTE block? Thanks! :notworthy:
facelift ST205
abraxxa
Postby Pipedreams » Fri Oct 30, 2015 5:23 am
That block did not come with sleeves from the factory. It's been repaired.
If you can get a complete beams engine, use the beams block.
But please, enough of littering in my build thread :-)
Pipedreams
Postby Pipedreams » Fri Oct 30, 2015 5:26 am
gunt wrote:would you not put liners in it / dry ones , do you mean concrete block filler
And I don't believe dry liners will do anything to the strength, rather the opposite.
Pipedreams
Postby abraxxa » Fri Oct 30, 2015 6:27 am
The engine is straight out of an automatic Caldina so I doubt anyone in Japan would repair a stock 3S-GTE with sleeves there.
So far it holds the ~500HP fine.
@Pipedreams: sorry for hijacking your thread, can you still answer my questions?
facelift ST205
abraxxa
Postby BADNEWS » Sat Dec 26, 2015 10:28 pm
What's going on currently with this car?
865AWHP, 591 torque
BADNEWS
Postby Pipedreams » Sat Dec 26, 2015 11:25 pm
Not much. Haven't had time for it due to work. But I will have it running again for the summer and if I can find the time I will put in a cage and lighten it. And I woule really like to put in a SQS gearkit.
Pipedreams
Postby gunt » Tue Dec 29, 2015 7:29 pm
whats your plan to fix the block/ problem
gunt
Postby Pipedreams » Tue Dec 29, 2015 7:45 pm
Just blockfiller and if the pistons are damaged I will get full-round instead of the assymetric, on a new block.
Pipedreams
Postby gunt » Wed Dec 30, 2015 8:53 pm
will block filler not leave you unable to drive around on road fuel or long journeys , also do you not have to start with a good block if so why not try liners , hks have goods results for years too
gunt
Postby Pipedreams » Wed Dec 30, 2015 9:24 pm
I'm not worried about cooling, the waterjackets are more than 110mm deep and with 91mm stroke the bottom of the block won't be getting much heat from the combustion. I will be filling just a little above the bottom of the freezeplugs.
I already have a new block as the 5sfe is very common here and I got a complete engine for about 300EUR. I don't belive dry liners would be an improvement so the better option would be wet liners and that's alot of money compared to a 5sfe engine.
And E85 is road fuel here in Sweden :-) But I've given up on having it as a roadcar. It will only see track and maybe some late night drag :-P
Pipedreams
