Pipedreams ST205, 5S-GTE BEAMS
Re: Pipedreams ST205, 5S-GTE BEAMS
Postby BADNEWS » Thu Feb 18, 2016 5:28 pm
How is the car coming along? Is the motor back together yet?
865AWHP, 591 torque
BADNEWS
Postby Pipedreams » Thu Feb 18, 2016 6:17 pm
Haven't touched it since June. Been working abroad alot. And now I'm waiting to move to a new garage and it's taking alot longer than expected for the old tenant to move out. We started discussions in December and I don't want to tear it apart to much before the move.
Pipedreams
Postby Pingman » Sat Apr 30, 2016 8:06 pm
Been following your build from a far for a while now Pipedreams, amazed at what you achieved, totally inspiring can't wait to see further progress :)
Pingman
Postby gunt » Wed May 04, 2016 8:19 pm
are you starting with new block
gunt
Postby Pipedreams » Sun May 08, 2016 1:56 pm
Thanks Pingman :-)
I have only stripped down the new block. The garagemove is getting closer so I might get on with it soon.
Pipedreams
Postby abraxxa » Mon Jun 27, 2016 5:59 am
I'm still waiting on what is required to make the Beams fit an ST205 and E154F gearbox and make the VVTI work, thanks!
facelift ST205
abraxxa
Postby Pipedreams » Mon Jun 27, 2016 6:25 am
The engine bolts right in. And getting the engine and vvt to work is all down to wiring and engine management. Since you mentioned you have a haltech ecu I'm not sure what you are asking? It reads camposition from the camsensor and controls it with a solenoid.
Pipedreams
Postby abraxxa » Mon Jun 27, 2016 6:31 am
Good to know that there are no mechanical problems with the center diff, thanks!
You mentioned earlier that some modifications are required to the VVTi oil line.
facelift ST205
abraxxa
Postby Pipedreams » Mon Jun 27, 2016 8:48 am
That's if you're not using the beams block.
Pipedreams
Postby abraxxa » Mon Jun 27, 2016 2:11 pm
Ah great!
Anything against using it? Any weaknesses or other issues?
facelift ST205
abraxxa
Postby Pipedreams » Mon Jun 27, 2016 2:36 pm
It's cast excactly the same as a 3sgte except the vvt oilfeed.
Pipedreams
Postby Pingman » Thu Jan 18, 2018 1:38 pm
Pipedreams wrote:Bosch 2200cc injectors
Random question, Do you know what max duty cycle you saw on those 2200cc injectors?
(Also, Any project update?)
Pingman
Users browsing this forum: CMS-GT4 and 2 guests
