Project IG-88 (91AT) **PICS**
Re: Project IG-88 (91AT) **PICS**
Postby celica_gtx » Mon Jan 26, 2015 3:21 pm
pics of the tear down.
head wasnt warped but plenty gunked up.
HG failed at # 2 & 3
#4 was on its way out
ARP head studs and Cometic goods
had a shop clean the head up for me and pressure tested and replace valve seals as well..
I have a KO Racing DP on its way as well as a Bored fuel rail..
im sure i wont notice the bored fuel rail but i guess its a good add
with boost being set a 1bar.
should i pair it w a adj FPR?
I definitely want to get it tuned esp w the avcr and might as well see some dyno results in the future. But ill take it easy till then.
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby celica_gtx » Thu Feb 12, 2015 4:04 am
alright im rounding 3rd base on this hick-up!
got the parts i was waiting on from KO Racing
stock rail.
Bored to 8mm
And KO down pipe bolted on
Small clearance issue with the AC line touching but its touching the thick insulated part of the line.. so ill keep an eye on it.
just gotta do timing n wire up my oil prs gauge that wire up off the head.
wasnt aware the this adapter is what i needed to get my sending unit to bolt on! had in sitting in the garage for 4 years! :bangshead:
1/8-27 NPT Female to 1/8 BSPT Male
has anyone else tapped into there?
what kind of readings should i be seeing?
hopefully this weekend ill be back on the road n the n to the exhaust shop
celica_gtx
Postby Redswan » Thu Feb 12, 2015 1:31 pm
Sweet! Let's get this show on the road!
-Mike
2005 4Runner V6 4x4 URD S/C'ed (Mojave)
1990 Celica GT4 RC (Revanche)
1990 Celica GT4 RC Conv-Sold 2008 (Redswan)
Redswan
Postby celica_gtx » Mon Feb 16, 2015 3:34 am
man the last couple of days is has been nothing but issues!!!
got the car back together and started right up!
peaking around for leaks & the oil pan gasket is leaking... :x
first the cam seals in the kit wouldn't fit they were a bit to big!
then this! everything was torqued! so off with the x-members
re-sealed it with high temp copper rtv which has never failed me!
then as i was tensioning the alternator and the bolt head freaking snapped!
and that was the last thing i has to do!! before putting her on the ground!
freaking A man!!!1 :bangshead:
celica_gtx
Postby FC Zach » Mon Feb 16, 2015 6:34 am
I feel your pain brother! I bought a timing component kit which had parts that caused me many headaches! With that being said I highly recommend that no one purchase the DNJ branded kit! But anyways, one of the issues I finally resolved was my oil leak which seemed/s a lot like yours. . mine was leaking from both cam seals that I conveniently replaced while I had the engine out but the seals weren't OEM and leaked so I had to re-replace them with the engine now installed (major PITA)!
If you have another leak after reinstalling everything I would double check your cam seals, it's hard to see them through the small gap from the metal plate for the upper timing cover but could at least get a hand in there and feel through the spokes of the cam gears to find oil.
Good luck!
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby celica_gtx » Mon Feb 16, 2015 2:28 pm
Yea I learned how difficult it was to do! The cam seals.
But in a stroke of genius I made a seal press just for me and it worked perfectly and went in even!
I have spare metal around n tubing
I took basically fencing poles cut to length after measuring what I needed. Make sure it cleared the cam n sits on the seal centered
Smooth it out, grabbed a big flat washer n bolt and wrenched it in..
Worked out really good!
celica_gtx
Postby FC Zach » Mon Feb 16, 2015 2:39 pm
Yeah I did the same but with a large socket.
FC Zach
Images: 9
Postby celica_gtx » Mon Feb 16, 2015 3:25 pm
I didn't have mine as it was loaned out!!
celica_gtx
Postby celica_gtx » Tue Feb 17, 2015 1:19 am
****need help!!
So after the rtv cured I added oil and started the car.
I noticed that the valve train sounds a bit louder than it did before
I maybe just from everything getting settled back in..
I pop the oil fill cap to see if I could hear it better.
And I felt pressured air with every stroke and to fallow rough idle and it wanting to die..
Wtf..!?!?
I know compression is good as I checked it before tear down
All within spec.
Is this normal?
Im aware that these motors are known PCP, but that much
Read up on other forums and some refer to pcv or rings. N some say normal..
*note that my car was on jack stands so it was at an angle if that matters...
And a jdm motor.
celica_gtx
Postby celica_gtx » Tue Feb 17, 2015 5:59 pm
Figured out why some answers.
Freaking oil pump decided to died..
FmL :x
celica_gtx
Postby Redswan » Tue Feb 17, 2015 8:47 pm
celica_gtx wrote:Figured out why some answers.
FmL :x
Tough break Nick, hopefully it is a quick turn around
-Mike
Redswan
Postby celica_gtx » Wed Feb 18, 2015 1:26 am
FmL :x
Thanks dude!! Literally I had the car on the ground ready for its glorious return. When I noticed it. Praying nothing else was damaged!..
I went ahead and got a 98+ camry /solar oil pump. And I'll use my 3s gear t-belt according to some other threads it'll be a high volume pump.
And at half price. Yoda wanted $226 n I got an oem for $116 shipped. So we will see.
I have an oil pressure gauge wired up now as well. I thought I installed it wrong but I guess it was working if it read 0!!
lol
So hopefully I'll see some better numbers?
Bgb says 4.3psi at idle and 36-71psi @3k.
So I won't know for a couple of weeks as I planned to do it this weekend and that just got filled w other stuff.
celica_gtx
Postby celica_gtx » Mon Feb 23, 2015 4:28 am
for those who have fallowed, it wasnt a bad pump i have a blockage in the oil passage..
see here in this tread
viewtopic.php?f=21&t=50230&p=467191#p467191
celica_gtx
Postby celica_gtx » Wed Feb 25, 2015 3:54 am
Good news problem is solved and I'm only a good hour or two from being off jack stands!!
Peep link to see what happened.
But yea only crappy part is I probably won't be able to touch it for a week or 2. I hope not.!
celica_gtx
Postby celica_gtx » Wed Mar 02, 2016 3:51 am
Alright.. time to revive this.. alot has changed since the last update..I've decided to go the caldina route. I found that no 3 was was low in comp as I was getting ready to go with an aem standalone, so I tossed it.
Finally sold off most of the parts and raised funds to get my swap done. Well now that I have most of my parts in or on the way I'd do an update.
So pics to come.. can't wait to get back on the road after missing az beautiful boost season..
celica_gtx
