1993 st185 with st205 swap nearing completion
Re: 1993 st185 with st205 swap nearing completion
Postby fhalperformance » Sun Apr 26, 2015 11:31 pm
I have to daily driver her right now so Its hard to get anything done on her. I picked up some non abs parts from a mr2 that im curious to know how it would work on the alltrac. They were free with some other parts I bought so even if they dont work its not a big deal. Ill have to see if I can find some more information on how that might work in my car.
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby fhalperformance » Wed Dec 09, 2015 3:22 am
Picked up some ST205 rear axles and arms to gain some much needed camber in the rear. Will have to realign and set ride height again as I may go to a larger tire/need more clearance.
-some water proofing work
-st185 on left st205 arms on rear.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby fhalperformance » Wed Dec 09, 2015 3:28 am
Picked up an ABS delete off of a 5th gen which I plan to install without removing the motor. This will be fun lol. Going to go proportioning valves for the rear in cockpit so I can get the brakes sorted. I will probably upgrade to racing compound brakes like I did on the circuit mr2 maybe Project Mu although I havent looked into it.
I have a problem with front brake pads burning off in less then a half an hour of track time. It has to do with my suspensions design and factory brake system. The rear brakes have never needed replacement so Im sure its a pressure issue.
The st205 arms was to even out the large difference in negative camber front to back. I only took her to the track once and only found the grip limit in the wet, then had that frustrating tire blow out.
Rims and tires will be next. I am also picking up another st185 to build a 5vz turbo powered rocket ship with my nascar dash motor. AND my mk3 mr2 2gr swap sits and stares at the other vehicles getting all the attention lol. Hopefully when I sell my audi I will be able to finish everything.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby fhalperformance » Tue Jan 19, 2016 3:22 am
I finally found some ST205 rear arms and got them installed a couple of weeks ago. I got ST205 rear axles but the ST185 rear axles seem to be perfect with the extreme drop. I definitely have more camber out back but I havent got a chance to get it aligned being winter and all, and im not driving it.
I may be putting the st205 swap in my 90 alltrac new winter toy and dropping a v6 in this car to compete with my buddys new 93 2gr awd turbo swap hes working on. 2500 lbs is the target weight with 500+ hp. I still have to test fit the motor I have chosen. It should be epic I just have to find time and stop hurting myself on accident so I can actually get something done lol.
Stay tuned for more updates this winter!
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
