All-trac build HELP!!
Postby Allenm301 » Mon Aug 18, 2014 2:21 pm
Okay, so I bought myself a 1988 Celica All-Trac and I'm currently taking it apart for body work and paint. But my problem is I'm not sure where to go after that. I want to build a car that i can cruise around on the weekends, but be able to throw on some gravel tires and take to an scca rally cross every once in a while. And I want good performance but nothing ridiculous. What should I do, what are the best brands, where can I find them? Any suggestion would help! Thanks
Allenm301
Re: All-trac build HELP!!
Postby UtahSleeper » Mon Aug 18, 2014 3:33 pm
I would start with getting it back together first :)
After that, upgrade/replace all bushing and suspension items. Drive it for a bit and get a feel for how she is and you can start seeing what you want to improve.
UtahSleeper
Postby underscore » Mon Aug 18, 2014 4:55 pm
^ what he said. Get it back together, drive it, take it to a rallycross or two and see what you like/don't like about the current parts before you bother changing anything up.
Postby Allenm301 » Mon Aug 18, 2014 11:39 pm
Is there any thing I should do while I'm putting it back together?
Allenm301
Postby UtahSleeper » Tue Aug 19, 2014 4:12 pm
Just all maintenance stuff. Fuel filter, ignition, every damn bushing, wheel bearings, struts, etc. Just try and get the car to "new" before upgrading anything. Now, if you upgrade the bushings, struts, etc while doing it, thats fine, I just wouldn't start upgrading everything else till you have driven it for a bit.
Think you will find the best upgrades being the poly motor mounts and bushings and maybe solid mounts for the rear end.
UtahSleeper
Postby Allenm301 » Tue Aug 19, 2014 4:54 pm
Where can I find all those parts? I've been having trouble searching for a lot of things... Maybe I'm just looking in the wrong place I guess
Allenm301
Postby Overtriped » Fri Nov 14, 2014 8:45 pm
Xiimotorsports is where I got my bushings, engine mounts, and rear dif mount. Knowing the condition of the car you'll need to pull the engine and trans out, fix the gear box, steering rack, fix any other leaks it may have, rebuild the distributer, drop the rear subframe and under coat the floor, fix any rust, change the rear dif oil, replace the bushings, and exhaust. If your having trouble posting photos download photobucket and use their program. Pics are going to help us help you a lot. Hope all is well.
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Postby UtahSleeper » Fri Nov 14, 2014 9:02 pm
Overtriped wrote:Xiimotorsports is where I got my bushings, engine mounts, and rear dif mount. Knowing the condition of the car you'll need to pull the engine and trans out, fix the gear box, steering rack, fix any other leaks it may have, rebuild the distributer, drop the rear subframe and under coat the floor, fix any rust, change the rear dif oil, replace the bushings, and exhaust. If your having trouble posting photos download photobucket and use their program. Pics are going to help us help you a lot. Hope all is well.
What he said for mounts and such.
Also I think alot of people use rock auto for stock stuff.
Any luck on the rebuild?
UtahSleeper
