my 1988 celica idles when cold and wont idle when warm.
Postby MeesterPatrick » Mon Aug 25, 2014 6:58 pm
First morning start. It starts up and idles well then when it begins to warm you can hear it want to cut out & die... eventually it does. But it will start right back up.
Here is another issue. I have 3 vacuum lines off two suck and one doesn't.
One of the vacuum lines are on the intake. The other one is below it and the last line is on a vac/ act I don't know what that is.
If anyone has any pointers it would be appreciated.
MeesterPatrick
Re: my 1988 celica idles when cold and wont idle when warm.
Postby ___Scott___ » Mon Aug 25, 2014 7:02 pm
On the idle issue, you answered your own question... vacuum leak. At the very least, cap the leaks.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby MeesterPatrick » Mon Aug 25, 2014 9:16 pm
Yeah I'm sure the leaks are the issue.
Does anyone know where to find a good vac diagram?? Very detailed ..
MeesterPatrick
