Bempa´s Celica ST165 -89
Re: Bempa´s Celica ST165 -88
Postby Bempa » Sun Oct 12, 2014 4:57 pm
AE92 4age 20v Engine rebuilding
KE70 4age 16v In progress
ST165 3sgte Brum Brum
ADT251 2ad-fhv Daily
AE92 4age 16v Bigport What to do with this one?
ACM20 1az-fe Wife´s daily
Instagram Benny_Gustavson
Bempa
Postby 88gt4DE » Sun Oct 12, 2014 10:34 pm
Ahhh ok. I'll have to look into that bezel clip thing again. US models the bezels are both big. At least on mine they are ... 5 Toyotas ... I remember having 3 at one time and a jeep. The up keep killed me ...
Postby Bempa » Wed Jan 28, 2015 6:54 pm
Sorry for not updating, but life is busy with family, little daughter and cars.
Have been doing some work on the car, sorted aout some exhaust leaks and oil leaks from turbocharger, fixed a oil leak from oilpan aswell. And mainly fixin small stuff that have been tempered with trying to get car ready for some winter abuse.
Bad news is it seems like center coupling is not working, only one front wheel is spinning. have anoyne managed to rebuilt a center coupling. I know that Toyota says it´s not rebuildable, but have anyone tried?
Also got a coolant leak from water radiator for interccoler and a bad misfiring when engine gets up to operating temperature.
ImageOil pan installed by Benny_Gustavson, on Flickr
Oilpan back on to fix that oil leak.
Cleaning som oily bolts
ImageDSC_0118 by Benny_Gustavson, on Flickr
Painted water lines
Bempa
Postby underscore » Thu Jan 29, 2015 3:27 am
The only person I've ever heard of rebuilding the viscous coupler is Mario, and from the sounds of things it's a very complex procedure. You're probably best off getting a used one from someone parting out their car. I'd do a quick check on the drive selector under the car to make sure someone didn't leave it in 2WD mode by mistake first.
Postby Bempa » Thu Jan 29, 2015 4:27 am
Sad to say it's not in 2wd mode. Is the coupler operating with own oil or the same oil as the gearbox?
Bempa
Postby underscore » Thu Jan 29, 2015 7:01 am
Its own, it's a completely sealed unit.
Postby Bempa » Thu Jan 29, 2015 7:09 am
No good for changing oil in gearbox then, seems like I need to find att used one. How does you check that it is ok when you have it out of the gearbox "on the bench " so to speak
Bempa
Postby underscore » Fri Jan 30, 2015 6:18 am
Mario would be the one to ask about that, I think it requires some specialty tools though.
Postby Bempa » Fri Jan 30, 2015 6:34 am
Thank's I shall ask him
Bempa
Postby Bempa » Thu Feb 05, 2015 6:16 pm
Underscore - Is Mario his username? Can´t seem to find any user with that name when I search in the member list.
/Benny
Bempa
Postby underscore » Thu Feb 05, 2015 6:40 pm
His username is st185-sainz, here's the thread about the upgraded ones viewtopic.php?f=43&t=36743
Postby Bempa » Thu Feb 05, 2015 7:29 pm
Thanks! I have sent him a pm :D
Bempa
Postby st182er » Fri Feb 06, 2015 1:29 pm
far out. fell off my chair after seeing that toilet roll hahah
st182er
Postby Bempa » Sun Feb 08, 2015 6:21 pm
Hi guys!
Put my car of the ground to test out center coupling. The outcoming was not in my favour! As you can hear in the video I got a very "nice" sound in my transfer case! And rear wheel is not spinning at all. But I do not hear that sound when I drive the car, only when it is of the ground.
Link to video
https://www.flickr.com/photos/95326785@N04/16283646508/
Bempa
Re: Bempa´s Celica ST165 -89
Postby Bempa » Sun Feb 15, 2015 5:24 pm
Today I went down to the garage to try to figure out what´s going on with that bad noise from transfer case.
Luckily enough it was not the transfer case, it was the wheel studs that were banging back and forth in the holes in the brake disc.
So that was a relief, but still got problem with to much slip between front and rear axle.
Bempa
Users browsing this forum: Baidu [Spider] and 3 guests
