What did you do to your car today?
Postby fwame_dwagon » Sun Dec 21, 2014 5:19 pm
I'm always working on my car, pretty much every weekend now that the engine is out. Today I pulled apart my distributor to find my mag pickups were cracked. I did a little research and found its from overheating, so I'm looking for a new dizzy housing.
(37.34 KiB) Not downloaded yet
fwame_dwagon
Re: What did you do to your car today?
Postby Mr Alltrac » Sun Dec 21, 2014 8:36 pm
Stared at it sitting in the street with a broken axle, and realized how bad the clear coat is starting to peel. :/
Mr Alltrac
Postby buffalohunter7321 » Sun Dec 21, 2014 8:55 pm
Thought about how to make a DIY Flex Mid Pipe for My Three (") exhaust; Than wondered if I should apply thread lock to one of my exhaust manifolds bolts, that keeps working it's self loose, which the exhaust gases then burns through my exhaust gasket.
But was just thinking about it.
buffalohunter7321
Postby Hotrodhendrix » Mon Dec 22, 2014 4:19 pm
Moved pile of upgrade parts laying on the left side of the car to the right. Yup feel pretty good about the progress today. . .
~James
Postby warracer » Mon Dec 22, 2014 4:30 pm
Changed the diff oil at -15Celsius in the driveway on ice... So much fun haha but it was whining sooo...
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby CMS-GT4 » Mon Dec 22, 2014 5:25 pm
Did some research on moving my strut tops above the strut tower for more travel.
Postby underscore » Mon Dec 22, 2014 6:06 pm
Hotrodhendrix wrote:Moved pile of upgrade parts laying on the left side of the car to the right. Yup feel pretty good about the progress today. . .
~James
:lol:
Postby fwame_dwagon » Mon Dec 22, 2014 11:29 pm
You guys are doing better than I am this week. I got my new(ish) dizzy last night. Gonna swap housings on it tomorrow
fwame_dwagon
Postby FC Zach » Tue Dec 23, 2014 5:19 am
I looked at the oil spots on the driveway as I left for work tonight :x The leak that I thought I had fixed when I had then engine out last week. . . Seems to be worse now :(
Guess I know what I'll be working on later when I'm off
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby buffalohunter7321 » Tue Dec 23, 2014 5:27 pm
Ordered a new stainless flex pipe for the one all-trac. And about to go out side to use it as a visual reference on how to hook up all the vacuum hoses and the wires along with the sensors on my other All-trac. Than try and start this one for the first time since the rebuild.
buffalohunter7321
Postby anothergt4 » Tue Dec 23, 2014 5:36 pm
FC Zach wrote:I looked at the oil spots on the driveway as I left for work tonight :x The leak that I thought I had fixed when I had then engine out last week. . . Seems to be worse now :(
I feel you, every time I fix an oil leak on my brothers trac, it leaks from somewhere else, it is getting an all new motor and turbo setup this winter, so I'm hoping she seals up nicely, but for today we are chasing wiring issues on the tow rig.
anothergt4
Postby UtahSleeper » Tue Dec 23, 2014 11:31 pm
I moved all the junk of the roof of my trac so I can pull it out of the garage and turn it around tomorrow. All this to give me space to finish mounting the body kit.
UtahSleeper
Postby fwame_dwagon » Thu Dec 25, 2014 9:49 am
It's Christmas and I feel empty inside [SLEEPY FACE]
fwame_dwagon
Postby fwame_dwagon » Tue Dec 30, 2014 12:20 am
Got the flywheel resurfaced and got my new exedy clutch
fwame_dwagon
Postby fwame_dwagon » Tue Dec 30, 2014 7:04 am
Ready to drop it in tomorrow
fwame_dwagon
