88 alltrac restoration Caldina swap
Postby 88gt4White » Thu Jan 29, 2015 2:58 pm
Hi everybody,
I brought an st165 from a buddy of mines recently and already started the build. I plan to update this thread with pics of my progress.
Sanyantho-
88 alltrac project, Caldina swap
88gt4White
Re: 88 alltrac restoration Caldina swap
Postby 88gt4White » Thu Jan 29, 2015 3:20 pm
So far, i removed the turbo manifold and down pipe to replace the "hoses from hell" with new oem part and wrap it with heat guard tape. Changed spark plugs, to new denso. Remove valve cover to change gasket, but still waiting for the gasket to arrive in mail. Its a nightmare to find simple part for this motor! :cry:
Valve cover gasket, hard to find
Hoes from hell
Caldina st215 motor
88gt4White
Postby GT4_DRED » Thu Jan 29, 2015 3:41 pm
88gt4White wrote: Its a nightmare to find simple part for this motor! :cry:
That's mainly because that motor never came to the states. Prime usually has or can get whats needed and are stateside, so give them a look.. http://www.primemr2.com/
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby 88gt4White » Thu Jan 29, 2015 5:37 pm
Thanks so much the info, i will difinitly give them a look... Nice ride btw
Sanyantho-
88gt4White
Postby 88gt4White » Thu Jan 29, 2015 10:26 pm
Hack sawed the rubber out of the stock motor mount and insert the durable poly insert...also bought aluminnum crossmember bushing to replace the weak rubber stock one.
Sanyantho-
88gt4White
