1992 ST185 Carlos Sainz #4353 - code name ICICLE
Re: 1992 ST185 Carlos Sainz #4353 - code name ICICLE
Postby SAS0662 » Wed May 27, 2015 5:54 pm
Exactly! GT4-play diff...
SAS0662
Postby SAS0662 » Fri May 29, 2015 4:59 pm
Test fitting components in the centre console before it is modified and Hydro-printed...
SAS0662
Postby Mr Alltrac » Fri May 29, 2015 5:16 pm
That looks pretty sweet! You should try to to fill the gap around the bottom where the ashtray went.
Awesome looking car btw!
Mr Alltrac
Postby SAS0662 » Sun May 31, 2015 10:41 am
Rear diff replacement
Repaired and reconditioned pump in place! Thanks, Steve...
Test fitting the battery...
Door speaker mount...
SAS0662
Postby XLarge » Sun May 31, 2015 6:35 pm
Tell Uwe that the diff don´t have to come out to replace the bracket :P Unbolting it and push it to the front brings enough space to take the bracket out and the new one in.
XLarge
Postby SAS0662 » Sat Jun 20, 2015 5:20 am
Soundproofing started and more parts arrived from Japan...
Battery relocated
First water printed carbon trim sample
SAS0662
Postby SAS0662 » Sat Jun 20, 2015 5:31 am
Subwoofer enclosure
SAS0662
Postby SAS0662 » Mon Jun 22, 2015 5:32 pm
Sound check #1
Sound check #2
SAS0662
Postby SAS0662 » Wed Jun 24, 2015 7:09 pm
Subwoofer enclosure done!
And Soundproofing continues...
SAS0662
Postby SAS0662 » Sun Jun 28, 2015 2:31 pm
more progress...
SAS0662
Postby SAS0662 » Sun Jun 28, 2015 2:34 pm
SAS0662
Postby msanders2 » Mon Jun 29, 2015 12:48 am
Where did you get the Teins? I've been trying o find a place that sells them.
msanders2
Postby SAS0662 » Mon Jun 29, 2015 3:28 am
Ordered through Nengun from Tein factory in Japan. Still made new to order...
SAS0662
Postby msanders2 » Mon Jun 29, 2015 10:11 am
Thanks I'll check it out!
msanders2
Postby SAS0662 » Thu Jul 09, 2015 7:28 pm
Toyota goodies...
Mishimoto radiator with Spal fan
Finally, Compomotives (17x8 35s) unboxing ...
SAS0662
