Project ST165-ST205 Swap
Re: Project ST165-ST205 Swap
Postby CSAlltrac » Thu Oct 15, 2015 4:37 pm
You left out the phase between anti seizing the output shaft and back together. I know theres a lot of cussing in that phase. :pissed:
Everything looks awesome, should be nice to get all your power to the ground.
Postby AlltracAvenger » Sun Oct 18, 2015 5:31 pm
Awesome seeing all of this coming together! Admittedly I'm sometimes tempted with swapping mine, but the original, low-mileage engine is what's keeping me from doing more than dream, haha. How do you like the Ceika coilovers?
'88 ST165 #2914- Sold 12/21/06 :(
'88 ST165 #3784- Bought 05/08/15 :D
'05 Corolla XRS- Daily Driver
AlltracAvenger
Postby Ghooble » Sun Nov 01, 2015 8:19 pm
Another 205 swap in Western Washington!
Question; does your cold idle up work? Mine has never worked since the swap and I can't figure it out. I'm going to try cleaning my IACV for a second time..
-Ghooble
Ghooble
Postby zaluss » Sun Nov 01, 2015 9:18 pm
AlltracAvenger wrote:Awesome seeing all of this coming together! Admittedly I'm sometimes tempted with swapping mine, but the original, low-mileage engine is what's keeping me from doing more than dream, haha. How do you like the Ceika coilovers?
Awesome so far!
Ghooble wrote:Another 205 swap in Western Washington!
-Ghooble
Cold idle works fine. I had an issue where it would idle around 500 when warmed up only but cleaning the IACV fixed that up. Does your car not hold idle when cold?
zaluss
Postby TRDTurko » Sun Nov 01, 2015 10:26 pm
Awesome build! you are super lucky to find a car in that great of shape! have to say I hate the wheels but then I never really liked tri spokes but to each his own lol. Isn't a stage 3 clutch a lil much for your power goals?
88 Celica GTS - RIP
93 Honda Civic - RIP
85 Honda Civic - Sold
08 Mazda 3 - Daily
TRDTurko
Postby Ghooble » Tue Nov 03, 2015 4:57 pm
It will hold idle when cold but it won't idle up to 1500 or whatever. It will sit at about 500 like yours. I've cleaned the iacv twice and the door moves pretty freely...
It might be an air bubble in the coolant in the iacv itself..I'll try to slide the line off for a second to purge any air that might be hanging out in it.
Ghooble
Postby zaluss » Sat Nov 14, 2015 8:25 pm
Long time no update (again). Clutch finished, engine mounted, etc. Started her up today and smoke starting pouring out of the engine bay. I thought I messed up the clutch install until...
https://www.youtube.com/watch?v=Gr2Nmn9xLo8
I guess I'm picking up that ebay exhaust afterall.
zaluss
Postby CTechBlueDragon » Mon Nov 16, 2015 12:04 am
Yeah the flex section is gone but I don't think that will fix that smoking problem... do you think the turbo seals are going bad maybe? I know there is a little smoke sometimes on a startup after it sits for a while but damn...
CTechBlueDragon
Images: 50
Postby zaluss » Mon Nov 16, 2015 12:19 am
CTechBlueDragon wrote:Yeah the flex section is gone but I don't think that will fix that smoking problem... do you think the turbo seals are going bad maybe? I know there is a little smoke sometimes on a startup after it sits for a while but damn...
I guess I should of mentioned that I forgot to drain the oil from the motor when I pulled it so a bunch of oil got in places it shouldn't. Tool about ten minutes of running for all the oil to burn off.
zaluss
Postby zaluss » Sun Nov 22, 2015 8:26 pm
November 22nd 2015
So after burning through all the oil in the exhaust, I took an angle grinder to cut out the sections and disconnect it from the down pipe. The muffler was already rusted through and disconnected so it simply fell off once removed from the exhaust hangers. Still had a Toyota part number stamped on it so it could of been original. Probably was.
It was starting to show its love.
I had a few choices at this point: 1) HKS ST185 Catback+Trackforge midpipe. Pricey as it would put me over $1500. 2) Custom exhaust. 3) Ebay Exhaust for $250...
I went with the Ebay option.
Arrived in good condition. Seems high quality.
I was anticipating having to mange this thing in there with some hammerlike persuasion but much to my surprise, it fit really well.
The most difficult part to bolt together.
One of the exhaust hangers doesn't reach. I'll need to get a longer one.
Autozone exhaust clamp. Leaked so I'll need to get a better quality one.
https://www.youtube.com/watch?v=p3zrl569pIw
Overall I'm satisfied with the fit and finish. I'll have to do a proper test once I get a new exhaust clamp.
zaluss
Postby zaluss » Mon Dec 07, 2015 3:03 pm
Went to NW Toy Run. Drove the car the farthest I've ever taken her with the engine swap, which was scary as hell.
zaluss
Postby CTechBlueDragon » Sun Dec 13, 2015 3:37 am
Congrats on the successful trip! The e-bay exhaust is a super sweet deal. I paid 275 for mine years ago and it came with a downpipe also! The fit and quality are pretty damn good even if it was twice as costly. I got the single tip "Motoria" one and I love the sound without the silencer. What turbo pressure are you running? I be your confidence level will go way up now after that trip!
CTechBlueDragon
Images: 50
Postby GT4times2 » Mon Dec 14, 2015 6:43 am
Nice!! Congrats on finishing up with the swap. Looks good! Body is clean. Going Ebay only makes sense. $1500 for an exhaust system is crazy, especially in this day in age :crazy: .
Going custom 3" Mandrel Bent cost about mid $400s with muffler, locally. Bringing the muffler of your choice will cost even less. The Ebay piece is really nice for what you're getting. I may go that route myself on my gray ST165, when all is said and done. Do you have any rear shots to share?
Keep up the great work.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby GT4_DRED » Mon Dec 14, 2015 1:33 pm
Congrats on the trip! Great to see another 165 being driven..
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby zaluss » Wed Dec 16, 2015 3:31 am
CTechBlueDragon wrote:Congrats on the successful trip! The e-bay exhaust is a super sweet deal. I paid 275 for mine years ago and it came with a downpipe also! The fit and quality are pretty damn good even if it was twice as costly. I got the single tip "Motoria" one and I love the sound without the silencer. What turbo pressure are you running? I be your confidence level will go way up now after that trip!
12 psi for now until the clutch fully breaks in.
GT4times2 wrote:Nice!! Congrats on finishing up with the swap. Looks good! Body is clean. Going Ebay only makes sense. $1500 for an exhaust system is crazy, especially in this day in age :crazy: .
No rear shots yet. Sneak peak of my new wheels and mudflaps.
zaluss
