Project ST165-ST205 Swap
Re: Project ST165-ST205 Swap
Postby Redrkt01 » Wed Dec 16, 2015 4:12 am
So did you ever use the suction valve trick I told you about for the AC comp?
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
Postby zaluss » Wed Dec 16, 2015 4:52 am
Redrkt01 wrote:So did you ever use the suction valve trick I told you about for the AC comp?
I did not. I accidentally dropped the ST205 ac compressor, bending the pulley pretty bad. It was at that point I removed all of the AC components, installed an OEM Toyota pulley in its place with a shorter belt, and installed a larger heat exchanger. I made a note earlier in the thread somewhere about switching the suction valves should I ever need to revisit installing AC.
zaluss
Postby zaluss » Sat Dec 19, 2015 3:17 pm
I had to snap some pics to insure my car with Hagerty. Agreed value of $15,000 for around $500/yr isn't too bad considering all the money I've poured into this (around $14,000 on my spreadsheet :eek: but a lot of that was maintenance). Got my policy approved today so I'm fairly happy with that. I don't want to be in a situation where some asshat nails me at an intersection or sitting at a light on something that is pretty much irreplaceable with nothing to show for it.
Sparco wheels and Rokblok mudflaps. I'm not 100% on the mudflap placement.
zaluss
Postby underscore » Sat Dec 19, 2015 3:56 pm
Beautiful setup! What kind of insurance coverage does that get you exactly? I pay double that to have full "daily driveable" insurance on my car and the insurance agency still thinks it's worth $500 (I'm gonna get it properly assessed like yours once it's done at the shop though).
Postby zaluss » Sat Dec 19, 2015 4:06 pm
underscore wrote:Beautiful setup! What kind of insurance coverage does that get you exactly? I pay double that to have full "daily driveable" insurance on my car and the insurance agency still thinks it's worth $500 (I'm gonna get it properly assessed like yours once it's done at the shop though).
I'm not sure how it is in Canada, but Hagtery (and most insurance companies) usually have an 'agreed value' policy. Basically you said it costs x much to replace and they insure for that amount. Period. No appraisal or assessment needed at the level I asked for. I'm sure if you asked for a $100,000, you'd need to prove it somehow.
In order to qualify, I had to meet four requirements:
1) Provide pictures of said car (sides, rear, trunk, and engine bay).
2) Car must be garage kept.
3) Less than 5000 miles a year (You can increase this for more money up to a certain point).
4) No coverage during competition events (racing, autocross, etc)
Agreed value on a daily driven car is probably tough though.
zaluss
Postby GT4times2 » Mon Dec 21, 2015 9:33 pm
If they charge you that much and say the car is worth $500, look elsewhere. That's crazy. Not daily driving a car helps lower the risk and costs. Most All Tracs are no longer daily driven.
Zaluss,
Will you race the car at all (with the insurance putting restrictions on what you can do)? If so, what forms of motorsports do you plan on participating in? The car is clean. Congrats on completing it in such short time. Definitely inspiring.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby underscore » Mon Dec 21, 2015 9:58 pm
GT4times2 wrote:If they charge you that much and say the car is worth $500, look elsewhere. That's crazy. Not daily driving a car helps lower the risk and costs. Most All Tracs are no longer daily driven.
I'd like to, but there's only the one option here. Someone along the line screwed up and lumped the Alltracs in with GTS', and there's definitely no listing for my RC, so it gets a very low book value.
Postby zaluss » Thu Dec 24, 2015 4:05 am
Zaluss,
Thanks! Maybe. I haven't decided yet.
I noticed there was quite a bit of dirt coming from the rear of the car so I took a peak and saw a TON of dirt packed into the rear body kit. I cleaned it all off to discover that rust has taken the thin metal used to secure the kit to the car. It still seems secure but I probably won't be able to remove it without breaking it should I need to in the future. The metal pieces are naturally discontinued so I'll have to fabricate something in the future. While I was back there I discovered that the passenger side rear wheel bearing may need to be replaced.
https://www.youtube.com/watch?v=5DFVi5lbrxs
https://www.youtube.com/watch?v=Hafsokz2ztw
zaluss
Postby zaluss » Sat Dec 26, 2015 11:28 pm
Pulled the passenger hub off and discovered whoever was there before me crossthreaded and mushroomed the axle. As soon as I broke the nut loose, it was a struggle to get it off. What a mess. The hub is getting a fresh bearing and seal. The bushings look pretty good so I'll leave those alone for now (plus I really don't want to do the other side). Since I'm already under here, I decided to crack open the torsen diff to make sure everything looks good on the inside before I swap it out with the factory open diff. It was very gooey inside.
The hell...
This bushing isn't looking too hot. Seems a bit leaky as well.
zaluss
Postby zaluss » Sun Jan 17, 2016 10:08 pm
January 17th, 2016
ST205 torsen diff is prepped with new seals and Toyota red FIPG. BRD diff mount ordered so its time to drop the factory diff.
Dropping the diff was a bigger pain than I anticipated but it came off after about an hour of wrestling.
Cruddy factory differential.
Cracked open after draining. It had a bit less than a quart of fluid. Factory calls for 1.1 quarts.
Factory open diff vs torsen LSD.
ST165 vs ST205 diff cover.
zaluss
Postby CTechBlueDragon » Fri Apr 22, 2016 5:38 pm
So what kind of fluid do we use in these 205 diffs? I have 2 I am about to service hoping you already did the leg work for me! =D
CTechBlueDragon
Images: 51
Postby zaluss » Fri Apr 22, 2016 9:44 pm
CTechBlueDragon wrote:So what kind of fluid do we use in these 205 diffs? I have 2 I am about to service hoping you already did the leg work for me! =D
http://www.amazon.com/Red-Line-57904-Sy ... =75w90+gl5
Same stuff I use in the ST205 trans.
zaluss
Postby zaluss » Sat Apr 30, 2016 2:57 pm
Long time no update. I've been driving the car on the weekends only for the past few months, ironing a few issues here and there.
Forgot to post the pictures of the diff installation in January.
ST205 Torsen diff installed. Not a terrible job. Also picked up a poly diff and replaced the factory rubber.
BRD poly mount installed.
Diff installed.
Now to yesterday.
I started overboosting and hitting 20-22 PSI then my CEL came on for fuel cut. I spent the whole day trying to figure out why until I found that the nipple cap on the wastegate to the turbo VSV blew off. Guess I forgot to secure it :laugh:
Other than that, here is how she sits for now. I'm about at the 400 mile mark since the swap to give you an idea of how much i've driven her. One or two shows in that time as well. At around 500 I'll be sending an oil analysis to Blackstone to see how the engine looks.
zaluss
Postby GT4times2 » Sat Apr 30, 2016 4:32 pm
Looking good!! How do you like BRD products? Who's blue ST165 is in the background? Any more pics from the car meet/show?
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
Postby zaluss » Sun May 01, 2016 4:15 pm
GT4times2 wrote:Looking good!! How do you like BRD products? Who's blue ST165 is in the background? Any more pics from the car meet/show?
BRD is great.
I forget his name...Michael something. Not sure if he is on the forum.
I have some more pics but none of the other Alltracs. 3 ST165's (including mine) and 1 ST185.
zaluss
