Project ST165-ST205 Swap
Re: Project ST165-ST205 Swap
Postby audiodjmp77 » Mon May 02, 2016 1:14 pm
The BRD contact is Louis, I thought. His products look first rate and he is approachable. Not sure he is on here, but on the drivers club / enthusiasts club he is mixer74. Drop him a PM
Sent from my phone. Sorry for any mistakes
audiodjmp77
Postby zaluss » Mon May 02, 2016 2:09 pm
audiodjmp77 wrote:The BRD contact is Louis, I thought. His products look first rate and he is approachable. Not sure he is on here, but on the drivers club / enthusiasts club he is mixer74. Drop him a PM
It is Lou. Sorry I was referring to the blue ST165 :)
zaluss
Postby audiodjmp77 » Mon May 02, 2016 2:10 pm
Sorry fella. I should have read the post properly. Whoops
audiodjmp77
Postby zaluss » Mon Jun 13, 2016 2:44 pm
Last weekend I pulled into the garage after a short drive and noticed only one of the fans working. I took a peak at the wiring and saw one of the spade connectors had been pulled out of the fuse holder. Instead of reconnecting it, I decided to redo them entirely with room for expansion as it was just a bunch of wires I stuffed behind the battery :banghead:.
Taking some inspiration from here https://www.youtube.com/watch?v=BvFHA1xY10w.
First I wired it up.
Then had my fiance wire it to the fans and the battery. She also stole my celica shirt for this :laugh:
Temporary place until I get a smaller Odyssey battery.
In-cabin relays for future gauge expansion in the passenger footwell.
And of course a quick rear end shot.
zaluss
Postby 88st165 » Tue Jun 14, 2016 2:22 am
Nice work!
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby zaluss » Fri Jun 17, 2016 4:33 am
Picked up a PLX wideband and oil temp/pressure sensors. More pics to come!
Sent from my SAMSUNG-SM-G935A using Tapatalk
zaluss
Postby JRWperformance » Sat Jun 18, 2016 2:00 am
Im going to be doing this same swap on my 88 soon. How was wiring up the 205 engine harness? Is there anything special to modify, or was it just providing power/ground? I come from the BMW/Audi/Volvo world of cars and Im not too familiar with toyota.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Postby zaluss » Sat Jun 18, 2016 3:52 am
JRWperformance wrote:Im going to be doing this same swap on my 88 soon. How was wiring up the 205 engine harness? Is there anything special to modify, or was it just providing power/ground? I come from the BMW/Audi/Volvo world of cars and Im not too familiar with toyota.
I paid wiregapinc.com to do it. $450 for plug n play.
zaluss
Postby JRWperformance » Sun Jun 19, 2016 10:06 pm
That actually sounds pretty good. I know I can wire up the car myself, but this would take the pain in the ass factor down a big notch. Thanks.
88 Celica Alltrac
78 Honda GL1000
JRWperformance
Postby zaluss » Mon Jun 20, 2016 1:45 am
Due to the lack of room between the oil pressure sensor and the intercooler, I have to remotely mount the sensor. I stumbled upon this thread on the MR2OC forums and went ahead and bought the parts. http://www.mr2oc.com/58-3sgte-mk1-5/466 ... ssues.html.
Parts ordered:
Order received from Jegs (Summit was OOS on the brake line).
Installed into the head.
Remote installed using some galvanized hanger brackets I had laying around.
Installing the oil temp sensor was a breeze. The Gen3 3SGTE block conveniently leaves three open 3/8 BSPT ports above the oil filter housing. May have been used/leftover for racing use. Who knows? Either way, I removed the threaded insert with an allen wrench. I had the worse time looking for a 3/8 BSPT to 1/8 NPT adapter until I stumbled across 42 Draft designs EVO adapter. Since it was the only one available, I went ahead and ordered that one.
Better reference.
Installed.
Wired up.
zaluss
Postby zaluss » Tue Jun 21, 2016 3:09 am
I was bored tonight so I decided to cut open my OEM Toyota filter to look for metal chunks and overall curiosity. I've cut open cheaper store brand filters so I did not expect all these components.
zaluss
Postby zaluss » Sun Jun 26, 2016 12:05 am
zaluss
Postby zaluss » Sat Jul 09, 2016 7:27 pm
On the 4th of July I was cruising along with my buddy when all of a sudden the car started to loose power. I glance at my AFR and its pegged at 10, even at idle. Giving it ANY power made it nearly die, along with a sputter of backfires. Essentially dumping fuel. I pulled into a parking lot and code 31 popped up, which is a vacuum sensor fault for gen3. I unplugged the battery, blew out the MAP sensor, and babied the car home.
Thanks to PrimeMR2, I acquired a brand new gen3 map sensor which included the MR2 bracket. The bracket allowed me to mount the boost sensor to the firewall instead of being zip tied under the power steering high pressure hose.
I also needed an alignment so I took it to Meisterwerks in Renton, WA. They opened up a new shop with a fancy alignment machine so I took the car down.
zaluss
Postby zaluss » Thu Jul 28, 2016 2:12 am
Manual boost controller stopped working. Picked up a Turbosmart EBoost Street and cranked her up to just under fuel cut for the MR2 ECU.
10.5 AFR @ WOT.
zaluss
Postby zaluss » Sat Jul 30, 2016 10:05 pm
Finally picked up a set of JDM corners. Needed some polishing so I polished and then wired it up.
Moved the placement of my turbosmart boost controller to a mounted position on the factory BOV.
Also took a few interior shots in the sun because why not?
zaluss
