Project ST165-ST205 Swap
Re: Project ST165-ST205 Swap
Postby zaluss » Wed Mar 29, 2017 5:07 pm
JRWperformance wrote:I looked through the previous posts to see if there are any specs on those wheels. I am looking at the same wheels for my 88. Did you get them from TireRack? What tire size did you use?
No longer available on TireRack in white but I see it in grey.
16x7 ET35. Tire size is 205/50/16.
zaluss
Postby zaluss » Mon May 01, 2017 12:02 pm
I stumbled upon a freshly restored set of OZ wheels wrapped in Pilot Sport Cups in the UK and snagged them. They arrived in a week :D
zaluss
Postby zaluss » Sun May 07, 2017 11:34 pm
Time to finally drop the rear end for a refresh.
Ordered new bushes and fresh control arms.
Dropped rear end.
Subframe stripped to bushings to prepare for bushing removal.
Bushing removal process.
All ready for powdercoating.
Dropped the gas tank while I was here to upgrade to a Supra TT pump and see why my tank is leaking when I fill it more than 3/4...
Well thats not so ba--oh...
Now to fix this. I'm tossing up between stripping it down entirely and taking it to a radiator shop for refurbishment or just applying some JB Weld Stik.
zaluss
Postby underscore » Mon May 08, 2017 10:39 pm
What would cause all that spider webbing on the tank?
Postby GT4times2 » Tue May 09, 2017 2:40 am
Loving the progress. Keep it up. The webbing could be due to age/heat or both. I'd empty the tank and take it to a specialist, or check Eastwood products. Then later apply something that would keep moisture away and protect it from the elements. Something like a truck bed-liner coating. That's what I'm doing to my gas tanks.
Frantz
12 Toyota Sienna LE (The Daily Pacifier)
05 Toyota Avalon XLS
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby MST Engineer » Wed May 10, 2017 1:52 pm
Looks like you have a aluminum radiator. Any idea on the brand and part number?
MST Engineer
Postby zaluss » Fri May 12, 2017 1:57 am
MST Engineer wrote:Looks like you have a aluminum radiator. Any idea on the brand and part number?
Ebay special. http://www.ebay.com/itm/All-aluminum-ra ... 1824134713
zaluss
Postby MST Engineer » Fri May 12, 2017 2:14 pm
How was the fit and finish? Was going to buy a new rad for mine but worth the extra $40 for a AL on if its decent quality.
Also if you ever stumble across anymore of those wheels let me know would love some of those for mine :)
MST Engineer
Postby zaluss » Sun May 14, 2017 3:10 pm
Fitment is good. Highly recommended. Wheels were a rare find indeed.
I was originally going to go with a RENU but after stripping the tank and looking at the inside, I think I'm just going to have the crack welded.
Tank stripped
Not too bad. Some corrosion just needs to be cleaned up
Bit of rust here
But otherwise very clean
Subframe powdercoated (among some other things :))
Bushings and diff installed
Can't forget the new hardware
New trailing arm bushings as well. These were a major PITA
Installed
zaluss
Postby MST Engineer » Fri May 26, 2017 10:59 am
What is the diameter, width and offset of the Sparcos that you had? The only ones that I can find are the grey ones.
MST Engineer
Postby zaluss » Fri May 26, 2017 4:38 pm
MST Engineer wrote:What is the diameter, width and offset of the Sparcos that you had? The only ones that I can find are the grey ones.
They are discontinued in white :(
16x7 ET35.
zaluss
Postby zaluss » Sat May 27, 2017 1:21 pm
Got my fuel tank back from Performance Radiator :)
Supra TT fuel pump upgrade.
All new bolts and gaskets.
Installed.
Added wheels and dropped on ramps to torque suspension. Rear end completed.
zaluss
Postby tHeGeeK » Sat May 27, 2017 5:24 pm
Just curious if you have the boots and gasket part numbers handy?
tHeGeeK
Postby zaluss » Sat May 27, 2017 8:15 pm
tHeGeeK wrote:Just curious if you have the boots and gasket part numbers handy?
Which boots? The gaskets for the gas tank?
77179-16010 Evap Gasket
77169-14010 Fuel neck/inlet and fuel pump gasket (same gasket so need 2)
77169-14020 Fuel sender gauge gasket
zaluss
Postby tHeGeeK » Sat May 27, 2017 10:32 pm
Sorry bolts. Disregard, I see the number in your picture. Thanks for the part numbers.
tHeGeeK
