Q's 88 st165 Daily driver
Postby 91Atrac » Mon Aug 03, 2015 6:33 pm
Hey everyone, new member as 91atrac, old member as celigts
Bought the car fully race ready but the seller wanted to keep his rare parts. So we have so far swapped out the front suspension setup as he had custom ground control on camber/caster pillow mounts.
Next is rear suspension and rear sway bar. Then she's done for my ownership.
At this point tho we have a charge or idle problem.
Parts list:
-Gen2 3sgte engine with gen1 Water to air intercooler
-Catch can
-Smaller coolant overflow reservoir
-2.5" down pipe to 2.5" full exhaust with Apex'i N1 muffler
-Upgraded front swaybar with poly mounts
-Poly rear swaybar bushings
-Nylon rear subframe bushing kit with poly diff mount
91Atrac
Re: Q's 88 st165 Daily driver
Postby zaluss » Mon Aug 03, 2015 8:17 pm
91Atrac wrote:Hey everyone, new member as 91atrac, old member as celigts
Damn! Want to put me in touch with that seller so I can buy those parts? :D
zaluss
Postby 91Atrac » Mon Aug 03, 2015 8:21 pm
Haha! He won't sell for sure! Like he's keeping the rear white line adjustable sway bar, front white line swaybar with poly mounts, rear strut tower bar, mr2 twin entry turbo, ground control suspension.
91Atrac
Postby 91Atrac » Mon Aug 03, 2015 8:23 pm
91Atrac
Postby 91Atrac » Sat Aug 08, 2015 5:04 am
Great progress so far. Fixed the alternator charging issue. Turned out to be the alt fuse being obliterated in it's harness.
On a new note tho, my rad fan is weak sauce and having trouble keeping the engine cool. I've wrapped the down pipe which has helped out a lot but the fan is just so weak I wanna cry haha! Going to be ordering one asap tho.
91Atrac
Postby 91Atrac » Sun Aug 16, 2015 12:54 am
Update.
Front wheel bearings are replaced, rear caliper problem fixed, boost issue still the same and over boosting to 14psi between 4-6k rpm.
Also found the part I'll be in need to replace.
91Atrac
Postby 91Atrac » Sun Aug 16, 2015 12:56 am
Update.
Also found the part I'll be in need to replace on the driveshaft
91Atrac
Postby mkernz22 » Sun Aug 16, 2015 5:08 am
I've heard that whiteline front swaybar is super rare!
I'm just happy I have a rear one for mine though :)
Good progress so far!
mkernz22
1995 Toyota Celica
Postby 91Atrac » Mon Aug 17, 2015 1:35 am
Yea apparently they are and he has an adjustable rear whiteline sway bar!
91Atrac
Postby underscore » Mon Aug 17, 2015 10:44 pm
I knew you wouldn't be gone for very long! :wink:
Postby 91Atrac » Tue Aug 18, 2015 12:08 am
underscore wrote:I knew you wouldn't be gone for very long! :wink:
Damn rights man. Always looking for one and this was a deal I couldn't pass up.
91Atrac
Postby 91Atrac » Mon Aug 24, 2015 10:21 pm
91Atrac
Postby 91Atrac » Tue Sep 08, 2015 10:54 am
Well the car has overheating issues atm so managed to find a new daily driver for now until it gets resolved. I have ordered two mishimoto slim electric fans for the rad. If that doesn't work then I'll also be replacing the thermostat and rad cap. I will also be cleaning my heater core to see if that helps.
Fingers crossed it's something along those lines
91Atrac
Postby Awesome-Trac » Fri Sep 11, 2015 4:32 am
91Atrac wrote:Well the car has overheating issues atm so managed to find a new daily driver for now until it gets resolved. I have ordered two mishimoto slim electric fans for the rad. If that doesn't work then I'll also be replacing the thermostat and rad cap. I will also be cleaning my heater core to see if that helps.
I'm having the same issues so I just replaced the radiator, thermostat, water pump but ended up being the fans
•Daniel
Awesome-Trac
Postby warracer » Fri Sep 11, 2015 7:38 pm
Air in the system? T-Stat should help, but my guess is on the Water-Pump...
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
