SkagTits165 ST205 GenIII 3SGTe into ST165 VERY PIC HEAVY
Re: SkagTits165 ST205 GenIII 3SGTe into ST165 VERY PIC H
Postby yyonline » Tue Sep 29, 2015 7:12 am
What downpipe and exhaust is that?
yyonline
Postby SkagTits165 » Tue Sep 29, 2015 1:16 pm
I bought the downpipe 4 years ago, dont remember the brand
SkagTits165
Postby zaluss » Tue Sep 29, 2015 1:40 pm
SkagTits165 wrote:[url=http://s1315.photobucket.com/user/noguchi77/media/obx_zpskcadlqsj.jpg.html]
I was looking at the same exhaust. Seems to be a lot of variations at different price points for the same thing.
Think you could snap some more pictures of what it looks like from the back and underneath? I'm also curious about how much 'love' was required to get it to work correctly.
zaluss
Postby SkagTits165 » Wed Sep 30, 2015 1:08 pm
A full day it took to fit. You cant really tell in the pictures, but i had to deform certain sections of the exhaust. I built a jig to hold the exhaust to bench, while i beat with rubber mallet. The largest deformity was maybe 2mm deep. When i first assembled pieces under car, i never thought that it would fit without cutting and welding, but it did. I had 2mm wood spacers to insert between the exhaust and the suspension/body where the clearances were tight. then as i tightened from front to back i would see where i needed to deform. It was quite the job
I built a new hanger to help hold the exhaust where i wanted it ahead of the rear suspension. The ss wire is holding up my driveshaft until the rear diff is back in.
I had to build the nut in this picture that would hold itself, as i couldn't get a wrench to hold it
SkagTits165
Postby zaluss » Thu Oct 01, 2015 2:02 pm
SkagTits165 wrote:A full day it took to fit. You cant really tell in the pictures, but i had to deform certain sections of the exhaust. I built a jig to hold the exhaust to bench, while i beat with rubber mallet. The largest deformity was maybe 2mm deep. When i first assembled pieces under car, i never thought that it would fit without cutting and welding, but it did. I had 2mm wood spacers to insert between the exhaust and the suspension/body where the clearances were tight. then as i tightened from front to back i would see where i needed to deform. It was quite the job
<Pics>
Oi. Maybe I'll be heading down to the exhaust shop afterall. I also inquired to Klue about a Bully clutch as it appears my ST205 swap needs one.
zaluss
Postby SkagTits165 » Thu Oct 01, 2015 9:50 pm
<Pics>
If you are going to a generic muffler shop, be prepared for some gross looking bends, not nice mandrel bends.
Probably look like this
SkagTits165
Postby SkagTits165 » Thu Feb 11, 2016 4:50 am
Dug out my old gtech pro and went out on wet streets with my winter rubber. Heavy spinning in first gear, and running 15lbs boost
SkagTits165
Postby athousandleaves » Fri Feb 12, 2016 9:04 pm
Quick note on the ebay exhaust, on one of my cars I was able to install it without having to deform the pipes or cut anything. Just putting a few washers under the E-W crossmember gave me enough clearance to sneak it by.
Car is looking great though! :smokes:
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby SkagTits165 » Sat Feb 13, 2016 3:31 am
Damn, maybe mine was just not in the jig correctly, because it took a lot of work.
And on a second note, I LOVE THE GENIII 3SGTE. If anyone out there is contemplating spending a bunch of money on their GENI, don't waste your time or money. These GENIII's are so much more refined in their driveablility and performance, for a reasonable price. Every time i fire her up it feels like im starting a new car. So much fun to drive. Just like a 2-stroke dirtbike, a quick fan of the clutch and its spooling hard
SkagTits165
Postby athousandleaves » Sat Feb 13, 2016 2:05 pm
Yeah, the bigger runners on both sides of the head really change the 3S, way more modern feeling. Even the stock tune is good for plenty of fun too.
1992 White turbo4WD
athousandleaves
Postby 801Alltrac » Tue Feb 16, 2016 4:37 am
Skagtits
Big changes last time i seen this beauty looking good love the I/c hard pipe, glad you made the jump to the 3rd gen
801Alltrac
Images: 13
Postby SkagTits165 » Sat Feb 27, 2016 8:17 pm
Still too much spinning, but decent times
SkagTits165
Postby pintoBC_3sgte » Sun Feb 28, 2016 4:39 am
Nice work!! You should try and make it out to the ogopogo this August !
pintoBC_3sgte
Postby zaluss » Sat Jul 09, 2016 11:33 pm
Anymore info or detailed pictures of your airbox? I'm looking to do something similiar.
zaluss
