88 AllTrac Re-Build
88 AllTrac Re-Build
Postby sandusky1977 » Mon Sep 28, 2015 1:04 pm
Ok,. so I've had it less than a month, and I've been able to find a fender, hood, headlight, and am on the way to getting this thing road ready. I even took it for a short drive yesterday to see what else it needs.
Here is what it looked like when I picked it up,...
It's coming along, I've straightened the subframe so I could mount the fender and hood,.
More to come, I've got a new side skirt coming from a member, and I'm still looking for a replacement grille, and passenger side marker. I'm also trying to decide on cutting and welding in a rear quarter, or having the body shop go to town on repairing it. At the moment I have to figure out whey it's running rough.
Took it for a drive yesterday and everytime you push the gas pedal beyond 10% it backfires, if you are careful to use sparingly you can hear it start to make boost and it will accelerate. Time to start reading up on the EGR delete and a few other things as it's been done and I'm sure it wasn't quite right. Also need to get my hands on a set of the books from ebay for this car.
More to come,...
sandusky1977
Re: 88 AllTrac Re-Build
Postby mkernz22 » Tue Sep 29, 2015 1:30 am
I'll trade you a full quarter panel for that black supra ;)
mkernz22
1995 Toyota Celica
Postby sandusky1977 » Tue Sep 29, 2015 1:58 am
I'm building the Supra over the winter. Busy finishing a Solara so I can fund the build.
sandusky1977
Postby Dan McBoost » Tue Sep 29, 2015 11:32 am
Fantastic choice of turbo toyotas. I am a Supra owner too:D
Dan McBoost
McBoost.comMA70.COMFB: DanMcBoost
Dan McBoost
Postby Bempa » Tue Sep 29, 2015 5:08 pm
Good to see it being rescued rather then scrapped. Good luck with rebuild. I actually have a NOS rear right quarter panel for a ST162. I think the shipping would be a killer though
AE92 4age 20v Engine rebuilding
KE70 4age 16v In progress
ST165 3sgte Brum Brum
ADT251 2ad-fhv Daily
AE92 4age 16v Bigport What to do with this one?
ACM20 1az-fe Wife´s daily
Instagram Benny_Gustavson
Bempa
Postby sandusky1977 » Tue Sep 29, 2015 5:15 pm
Where are you located? I have alternative shipping from a lot of locations and may be able to have it picked up and brought to me.
sandusky1977
Postby Bempa » Tue Sep 29, 2015 5:17 pm
I live in another country, Sweden to be more specific. So it's a long way for it to travel.
Bempa
Postby mkernz22 » Wed Sep 30, 2015 11:10 am
Might be able to get some parts from this guy since his car just got totalled... :/
viewtopic.php?f=44&t=50740&start=15
mkernz22
1995 Toyota Celica
Postby Bempa » Sat Nov 14, 2015 6:33 pm
How is it coming along with this one?
Bempa
Postby sandusky1977 » Sat Nov 14, 2015 6:38 pm
Just have a grille to buy, and need to find a rear quarter.
I've just figured out my over boost issues that had been throwing it into limp mode. So now it is drivable again.
Still want a couple other odds and ends but it should be good to drive for winter and off to the body shop this spring.
sandusky1977
Postby Bempa » Sun Nov 15, 2015 7:34 am
Nice that you found the overboost problem. What was the problem with that?
Those grilles seems hard to find nowadays in good shape, almost everyone is busted.
Keep it up
/Benny
Bempa
Postby sandusky1977 » Sun Nov 15, 2015 12:47 pm
First problem was an electronic boost gauge that wasn't working right, second was not knowing that the vehicle was going to limp mode once it overboosted and that you need to shut off the car to get back out of it. So I was making adjustments to the MBC while it was in limp mode and still having the problem.
I've found that the dealerships can still get you the grille, new old stock, however it's pricey so I've been holding off on it for the moment.
sandusky1977
Postby Anoo21 » Sun Nov 15, 2015 1:14 pm
Hey do you happen to know the part number for the grill? I need a new one too just haven't found anything.
sandusky1977 wrote:First problem was an electronic boost gauge that wasn't working right, second was not knowing that the vehicle was going to limp mode once it overboosted and that you need to shut off the car to get back out of it. So I was making adjustments to the MBC while it was in limp mode and still having the problem.
Anoo21
Postby mkernz22 » Sun Nov 15, 2015 10:15 pm
http://toyotaparts.bochtoyotasouth.com/ ... nents-scat
Anoo21 wrote:Hey do you happen to know the part number for the grill? I need a new one too just haven't found anything.
mkernz22
1995 Toyota Celica
Postby sandusky1977 » Sun Nov 15, 2015 10:55 pm
Now that I have boost I can tell the clutch is also shot. Time to order more parts.
sandusky1977
