Sv25 Project Daily
Sv25 Project Daily
Postby Tecker185 » Mon Mar 14, 2016 3:34 am
I figured id start a project thread of my own. I was waiting to do one for my st185 but this project is kinda first priority and in the way so ill start this one first.
Picked the car up for $600, included in the price was a new exedy clutch. Ive been looking for an awd, manual trans, 4-door, toyota, for quite sometime. This car fits the bill to a T. The only thing that i could ask for is flip up headlights.
This is what she looked like when i picked her up.
Threw my 7th gen gts wheels on to see how she looked
Found some patch panels on fixmyrust.com
Motor coming out
Out
New heart
A frankenstein of parts i had around the shop. So far its got a 92 celica 5sfe block with oil cooler, 00 camry head, 00 camry oil pump, and 00 camry tubular exhaust manifold. The rest is 89 camry 3sfe off the old block. I did the water pump and t-belt while i was in there. New cam seal, valve cover gasket, and intake manifold gasket.
I also picked up 4 new strut inserts and strut mounts. To freshen up the old suspension. Ive got a set of eibach springs off a celica im going to try putting on when i do the suspension. Also have new rear rotors, pads, parking brake cables, and parking shoes.
I should have the motor backnin next weekend fingers crossed. All thats left now is to grind the block and install the trans and it can go in. More pictures when i have more progress.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Re: Sv25 Project Daily
Postby underscore » Mon Mar 14, 2016 2:25 pm
Cool project! I like how the engine bay itself is clean, but every bracket attached to it is rusted to hell.
Postby Tecker185 » Thu Mar 17, 2016 4:17 pm
A little grinding on the block and she is ready to go in.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby fhalperformance » Thu Mar 17, 2016 11:59 pm
Awesome project. Cant wait to get a ride in that beast.
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby Tecker185 » Sat Mar 19, 2016 11:56 pm
Motor back in
It lives! Needs parking brake shoes, cables, rear brakes, and has a return line leak by the tank.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby fhalperformance » Sun Mar 20, 2016 1:24 am
You still have the body stuff to take care of right? I never saw a mention.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Sv25 Project Daily
Postby Tecker185 » Sun Mar 20, 2016 7:29 pm
Body work will wait till summer time when i can paint it after.
Pulled the tank, rust lots of rust. Fuel pump bracket was shot. So i drilled out the old lines and inserted NiCopp line in its place. Used gas tank repair putty to seal around the line where i stuck it threw.
Looks like this now after some POR15
Ill get it installed as soon as i hve time and take it for my first drive.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby Tecker185 » Fri Mar 25, 2016 4:34 am
Drove the car down the road for the first time today. Need to adjust the tps sensor and the ignition timing.
I found an interesting bit of info. While redoing the rear brakes i found my self in the need of some calipers. The ones on the car sized solid. I had new rotors, pads, parking shoes, and cables but no calipers. Got to thinking ive got some new calipers off a 90 celica gt-s i parted out last year. I figured what the hell ill see if they fit. Turns out they bolt right on, the pads are even the same. Check it out
Pics comparing the celica rotor to the camry
Celica
Camry
I ended up going with the celica calipers and camry rotors. The camry rotor sat centered in the celica's caliper bracket. So fyi 90-91 celica gt-s calipers and brackets bolt on.
Next on the agenda for this weekend is replace all 4 struts, strut mounts and hopefully the springs with the eibachs I've got from a celica. More pics soon hopefully with a drop.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby Tecker185 » Mon Mar 28, 2016 12:33 pm
Got the suspension freshened up. New sway bar links, strut mounts, eibach springs and strut inserts. Results
Its warming up now ill get the rest of my cars out and take a group photo.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby Tecker185 » Sun Apr 10, 2016 3:12 pm
Group photo of my collection
Pictured is my 86 Corolla hatch sr5 with gts 4age swap, 92 Celica GT hard top, 86 MR2 2zzge 6 speed, 89 Camry Alltrac, and way in the back side ways on the rotisserie 93 Celica Alltrac. I have a pretty beat st165 but its not worth pictures and i could push it across the street on my own.
After i cleaned the garage.
The camry and my 02 Supercharged Tacoma. Its in the shop getting new knock sensors.
Ive also got this sweet 88 Dually Pickup. Its going to replace the tacoma when i finish converting it to 4wd and 1uz swapping it. Too many projects not enough time!
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby underscore » Mon Apr 11, 2016 4:51 am
Oh the things I would do for that much shop pace. Nice collection!
