Alltrac rescue project #3: 1992 ST185
Re: Alltrac rescue project #3: 1992 ST185
Postby fhalperformance » Fri May 27, 2016 12:11 am
Rotten mount coming out and replacement mount going in. Hoping to get a starts on patching the holes cut in the body by the former owner. The panels that came with the car already cut are pretty close I should be able to use them. Otherwise Ill cut the rockers off the RHD donor chassis when I get the firewall and window cowl out of the rhd donor.
'93 trac - V6TT project.
'92 trac - RHD conversion coming.
'91 trac - 564awhp.
'90 trac - fab car/snow build coming.
'91 mr2 - parting out.
'00 celica gts - custom wide body.
'01 mr2 - crazy build in progress.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby fhalperformance » Thu Jun 02, 2016 12:47 am
Got the RHD firewall cut out of the donor car so I can get started on the conversion, got some RHD stuff ordered from europe should be shipping soon, stole the widebody fenders off the 93 as its body is getting modified, also gonna run the genuine RC aluminum bar and bumper cover on this car so it doesnt get damaged at the track which is likely on the 93.
-RHD firewall cut out of donor car
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby fhalperformance » Tue Aug 09, 2016 12:09 am
Havent had time to touch this but have made some progress parts wise.
-My RC conversion off my 93 is going on this car so I can do something more racey once I have time. I also will be cutting the mint floors out of my RHD donor car to eventually put in this vehicle.
-I also got a ST205 rear subframe to install in this car complete with LSD/axles and may possibly run one of my two pending ACPT carbon fiber driveshafts in this one.
-Gota figure out the motor solution as the 205 motor that was going in here is going in the 90 st185 instead once the guy pays me for it. Prob will pick up a 205 head, build my 98+ 5sfe or ST215 block and maybe throw one of my BW turbos from my 93 build in this car as Im not building the v6 right now just too many projects.
-Going to get some new rubber for the Volk GT-7s and put them on this car as they are just sitting around. Dont want to go as extreme with the body modifications on this car as I did with the 93.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby underscore » Tue Aug 09, 2016 5:40 pm
I thought the RHD car was a JDM front clip welded onto a 2WD USDM coupe? In which case the floors should be different from an Alltrac. I'm likely wrong though, massive props for keeping track of all the stuff you have going on, I know I couldn't.
Postby fhalperformance » Tue Aug 09, 2016 6:16 pm
I don't need the complete floors I just have small pieces I need. Id just be using it for sheet metal not direct replacement. They look similar enough outside of suspension/sub frame mounting but ill see when I actually get to it. The donor chassis is mint no rust anywhere so any part I can reuse I will.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Users browsing this forum: Bing [Bot] and 6 guests
