All ST165's left in North America
Postby Ryan » Tue Aug 02, 2016 5:40 pm
a log book i'm starting to see how many ST165s are left.
-Ryan
Template below.
Chassis number:
color/colour:
condition:
specs:
pictures:
Ryan
Re: All ST165's left in North America
Postby Ryan » Tue Aug 02, 2016 5:59 pm
Chassis number: ST165~0002795
Color/Colour: Red/originally black
Condition: I'd call it survivor 6.5-7.5
Specs: All original, tear-away spec, red int, no sunroof, no a/c
Pictures: Non ATM hope to get some nice shots soon
Ryan
Top
Ryan
Postby monkey8oi » Tue Aug 02, 2016 7:44 pm
Chassis number: unavailable at the moment
color/colour: red
condition: 7.5-8
specs: Gen 1/3 hybrid with forged bottom end, 800cc injectors, pump, front mount IC, garrett gt3071r turbo, and hydra nemesis standalone. currently at 318awhp on e85..
pictures: Image
monkey8oi
Postby monkey8oi » Tue Aug 02, 2016 7:46 pm
color/colour: white
condition: 7-7.5
specs: stock gen2 3sgte
pictures:Image
monkey8oi
Postby JRWperformance » Thu Aug 18, 2016 7:17 pm
Color: originally white but now has horrible yellow paint and orange flames. At least it was done well.
Number: 002525
Condition 6 out of 10. Working on that.
Specs: stock 88 celica all trac. Swapping 3rd Gen drive train this winter.
No current pictures I want to put up due to embarrassment.
Edit: here is the ugly paint job. The front also had a car bra thing for years, so the bumper is a bit crunchy. But if you look past the ugly paint you'll see that it was at least sprayed pretty smooth. It will get a white plasti dip job in the future.
Last edited by JRWperformance on Fri Aug 19, 2016 6:36 pm, edited 1 time in total.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Postby 88_ST165 » Thu Aug 18, 2016 10:58 pm
Chassis number: ST165~0005239
Colour: 040 White/Blue Leather
Condition: Very nice/Original - 8/10
Specs: All original, bone stock, no sunroof, Ice Cold A/C
Right Click "View Image" for full size - Firefox...
Dave MacLaurin
- 1999 Toyota 4Runner SR5 V6 (5mt)
- 1971 Datsun 240Z (Series 1, EFI, 5mt)
- 1972 Toyota Celica ST (4AGE Bluetop, 5mt)
- 1988 Toyota Celica Turbo 4WD
- 1989 Toyota Celica GT-S
88_ST165
Postby buffalohunter7321 » Fri Aug 19, 2016 3:07 am
Two St 165's in Dayton Ohio
condition for both is one rust free but needs a new paint job. The other has bubble rust on right rear on the front of the wheel well. Other than that, it also needs a new paint job.
Names of cars are "The Black" named after the show of The Black Stallion and the other is "Blue"
"The Black" has been modded by brute killer and is currently at his house being put together in N.Y.
The "Blue" has a bearing knock and is waiting for a new complete rebuild this winter. No mod's just back to stock with all damaged part replaced.
Since this is only for St 165's I won't mention the St 185 that is going to Brute Killer as payment for his work on "The Black"
buffalohunter7321
buffalohunter7321
Postby Awesome-Trac » Fri Aug 19, 2016 9:03 pm
Chassis number:don't remember but will get it later
color/colour:Black
condition:7 out 10
specs: -1st Gen 3SGTE -326mm "STI rotors"
-Brembo Calipers "Porsche 911"-KO downpipe 2.5in
-CT26A 50Trim 7MGTE Turbo-SSR GT-2 18x8 42 offset
-25mm spacer/adapters-Power by Max neo-chrome luguts
-HKS Blow off valve -ST185 2nd Gen transmission
-JDM Rear Vented Post-facelift tails-Exedy Clutch Kit w/OEM Throwout Bearing
-JDM Folding mirrors -Custom Rear Deck Lid Spoiler
-Quick Release Steering Wheel-Hella H3 Headlight Housing
-Rally Armor Red UR Mud Flaps-Yakima Gutter Roof Rack w/Basket
-Subaru Lamco Boost gauge-Apexi Turbo Timer w/HKS harness
-Megan Racing Coilovers Street series -Cusco Catch Can
-Prius inverter Radiator "water to air setup"
-Hayden power steering cooler-Mishimoto 12" slim fan
-Blox 12" slim fan-Low Temp Thermostat 170 degree
-ASI aluminum Radiator -Energy Front sway bar bushings
pictures:
•Daniel
Awesome-Trac
Postby 801Alltrac » Thu Aug 25, 2016 1:56 am
Chassis number:0003436
color/colour: gray hardtop
condition: 8.9/10
specs: 130k on factory gen1 then went down 2013 (30 year old plastic radiator finally popped)
basic run down whats happen
gen 1 with a 3sge head (factory specs) but shimover buckets conversion
gen 1 block fully built
5858 .64 vband turbo
haltech platiuam 1000 (racepak)
ID 1000cc
044 bosch pump
xiiimotorsports soild rear diff kit & motor mount kit
racer x side feed intake
racer x C.O.P & trigger wheel
(hope a C.F. drive shaft)
pictures:
801Alltrac
Images: 13
Postby puppet623 » Fri Aug 26, 2016 12:02 am
Chassis number: ST165-0003786
color/colour: Black/sunroof model
condition: 6.3/10
specs:1st gen 3sgte original motor I do not know if motor work was done so far Plan for a gen 4(<---most likely this)or 3 swap when it goes if it doses.
120 amp alternator
Previous owner work
EMUSA intercooler
G reddy BOV
Custom exhaust and header
Battery relocated to trunk (horrible installation)
Wish she was tuned for the BOV
welded rear diff (-_-)
25mm rear spacers (no fender roll -_-)
Stock ct26 but suspicious its from a supra mk3 (exhaust is damn horrible to remove)
Later down the road (waiting install)
2nd gen transmission
st205 rear differential and crossmember
Pictures no pics as of this moment for this but My instagram has some. Its down below.
Instagram: Oddball_8
1988 Celica Alltrac
2004 Mazda Rx8
1990 4X4 Dodge Dakota
puppet623
Users browsing this forum: Google [Bot], Junctrac and 6 guests
