89 st165 restoration and upgrade
Postby GriptionGT4 » Fri Feb 10, 2017 1:35 am
Been after this particular 165 for a few years and finally got it. Has a 185 engine and trans with a 205 a/w intercooler. Walbro 255. Small list of things i need to replace. Hood, both fenders, grill piece and passenger light cover. Need to find oem fog lights. And i need new struts.
For the performance aspect. I ordered the ecumaster det3 piggyback ecu with a boost control solenid. I have a set of rev3 540cc injectors. The clutch will need to be replaced im sure. And from what i understand the engine will have to come out. Ill address the turbo and manifold then. If i can find a clean looking aftermarket manifold that will allow the use of a stock flange turbo. Havent decided between a 57trim ct26 (more top end and a little more lag) or the ct20b. (Quicker spool and more low to mid power). 300whp is where id be happy. I have a Mk3 supra for my high horsepower needs.
If someone could point me to the area where i could post for parts to buy that would be great!
Thanks for your time!
1990 Mk3 Supra 1jz Single Turbo
1989 Celica Alltrac (underconstruction)
GriptionGT4
Re: 89 st165 restoration and upgrade
Postby puppet623 » Fri Feb 10, 2017 8:08 am
I recommend a 20B just cause the much quicker response but welcome and happy Tracing :). Can't help you with parts though.
Instagram: Oddball_8
1988 Celica Alltrac
2004 Mazda Rx8
1990 4X4 Dodge Dakota
puppet623
Postby Tomas » Sat Feb 11, 2017 12:24 am
GriptionGT4 wrote:Been after this particular 165 for a few years and finally got it. Has a 185 engine and trans with a 205 a/w intercooler. Walbro 255. Small list of things i need to replace. Hood, both fenders, grill piece and passenger light cover. Need to find oem fog lights. And i need new struts.
I can probably help you with some of the parts you need, pm me a list of what you need. Just curious, what made you go with the ecu master det 3, i am thinking of getting the EMU for my ride.
regards,
Tomas
Tomas
Postby GriptionGT4 » Sat Feb 11, 2017 4:41 am
I didnt want to get a full on standalone. And honestly i was gonna use the safc so i could run 540cc from a gen3. I was actually shopping for the emu for my supra and i saw the tab for the piggybacks. I looked at it and has a crap ton of features including modifying the maf signal so you can eliminate the maf meter and the det3 has a built in 2.5 bar map sensor. It was only $420.
GriptionGT4
Postby GT4_DRED » Mon Feb 13, 2017 8:05 pm
Marketplace > Parts Wanted..
Any pics of the car?
'00 SC300 - "Big Butt"
'88 ST165 - "Rahtid"
'88 ST165 - "Supah Cyat"
'88 ST165 - "Cornbeef"
'88 ST165 - "Redhead"
'91 MR2-T SMG
'92 MR2-T Nautical Blue
GT4_DRED
